Code OBD II của KIA
hyundai
Bình luận: 0Lượt xem: 3,062
hyundai
P0100Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103Mass Air Flow or Volume Air Flow Circuit High Input.
P0107MAP/BARO Circuit Low Input.
P0108MAP/BARO Circuit High Input.
P0110A/T Circuit Malfunction.
P0115Engine Coolant Temperature Circuit Malfunction.
P0116Engine Coolant Temperature Circuit Range/Performance Condition.
P0117Engine Coolant Temperature Circuit Low Input.
P0118Engine Coolant Temperature Circuit High Input.
P0120Throttle Position Malfunction - Circuit A.
P0122APP/TPP Sensor Switch Low Input - Circuit A.
P0123APP/TPP Sensor Switch High Input - Circuit A.
P0125Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
P0131Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170Fuel Trim Malfunction - Bank 1.
P0171System too Lean - Bank 1.
P0172System too Rich - Bank 1.
P0261Injector Circuit Low - Cyl. 1.
P0262Injector Circuit High - Cyl. 1.
P0264Injector Circuit Low - Cyl. 2.
P0265Injector Circuit High - Cyl. 2.
P0267Injector Circuit Low - Cyl. 3.
P0268Injector Circuit High - Cyl. 3.
P0270Injector Circuit Low - Cyl. 4.
P0271Injector Circuit High - Cyl. 4.
P0300Multiple/Random Misfire detected.
P0301Misfire detected - Cyls. 1-4.
P0302Misfire detected - Cyls. 1-4.
P0303Misfire detected - Cyls. 1-4.
P0304Misfire detected - Cyls. 1-4.
P0325Knock Sensor Circuit Malfunction
P0326Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335Crankshaft Position Sensor Malfunction - Circuit A.
P0336Crankshaft Position Sensor Range/Performance - Circuit A.
P0340Crankshaft Position Sensor Circuit Malfunction.
P0342Crankshaft Position Sensor Circuit Low Input.
P0343Crankshaft Position Sensor Circuit High Input.
P0400EGR Flow Malfunction.
P0403EGR Circuit Malfunction.
P0404EGR Circuit Range/Performance Malfunction.
P0420Catalyst System Efficiency below Threshold - Bank 1.
P0422Main Catalyst Efficiency below Threshold - Bank 1.
P0440Evaporative Control Malfunction.
P0441Evaporative Control System - Improper Purge.
P0442Evaporative Control System - Small Leak detected.
P0443Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446Evaporative Vent Control Circuit Malfunction.
P0447Evaporative Vent Control Circuit Open.
P0448Evaporative Vent Control Circuit Short.
P0450Evaporative System Pressure Sensor Circuit Malfunction.
P0452Evaporative Control System Pressure Sensor Low Input.
P0453Evaporative Control System Pressure Sensor High Input.
P0455Evaporative Control System - Large Leak detected.
P0470Exhaust Pressure Sensor Malfunction.
P0500Vehicle Speed Sensor Malfunction.
P0501Vehicle Speed Sensor Range/Performance.
P0505Idle Air Control System Malfunction.
P0506Idle Air Control System Malfunction - RPM Lower than expected.
P0507Idle Air Control System Malfunction - RPM Higher than expected.
P0510CTP Switch Malfunction.
P0561System Voltage Unstable.
P0562System Voltage Low.
P0563System Voltage High.
P0601Internal Control Module Memory Checksum Error.
P0604Internal Control Module RAM Error.
P0703Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706A/T Range Sensor Circuit Range/ Performance.
P0710Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715Input/Turbine Speed Sensor Circuit Malfunction.
P0722Output Speed Sensor Circuit No Signal.
P0726Engine Speed Input Circuit Range/ Performance.
P0727Engine Speed Input Circuit - No Signal.
P0731A/T Gear 1 Improper Ratio.
P0732A/T Gear 2 Improper Ratio.
P0733A/T Gear 3 Improper Ratio.
P0734A/T Gear 4 Improper Ratio.
P0740Torque Converter Clutch System Malfunction.
P0743Torque Converter Clutch Circuit Electrical.
P0750Shift Solenoid "A" Malfunction.
P0753Shift Solenoid "A" Electrical.
P0755Shift Solenoid "B" Malfunction.
P0758Shift Solenoid "B" Electrical.
P0760Shift Solenoid "C" Malfunction.
P1000Readiness Function Code.
P1115Engine Coolant Temperature Signal from ECM to TCM.
P1121Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170Front Heated Oxygen Sensor Stuck.
P1195EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196Ignition Switch "Start" Open or Short (1.6L).
P1250Pressure Regulator Control Solenoid Valve Open or Short.
P1252Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307Chassis Acceleration Sensor Signal Malfunction.
P1308Chassis Acceleration Sensor Signal Low.
P1309Chassis Acceleration Sensor Signal High.
P1345No SGC Signal (1.6L).
P1386Knock Sensor Control Zero Test.
P1402EGR Valve Position Sensor Open or Short.
P1449Canister Drain Cut Valve Open or Short (1.8L).
P1450Excessive Vacuum Leak.
P1455Fuel Tank Sending Unit Open or Short (1.8L).
P1457Purge Solenoid Valve Low System Malfunction.
P1458A/C Compressor Control Signal Malfunction.
P1485EGR Solenoid Valve Vacuum Open or Short.
P1486EGR Solenoid Valve Vent Open or Short.
P1487EGR Boost Sensor Solenoid Valve Open or Short.
P1496EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1497EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500No Vehicle Speed Signal to TCM.
P1505Idle Air Control Valve Opening Coil Voltage Low.
P1506Idle Air Control Valve Opening Coil Voltage High.
P1507Idle Air Control Valve Closing Coil Voltage Low.
P1508Idle Air Control Valve Closing Coil Voltage High.
P1523VICS Solenoid Valve.
P1586A/T-M/T Codification.
P1608PCM Malfunction.
P1611MIL Request Circuit Voltage Low.
P1614MIL Request Circuit Voltage High.
P1624MIL Request Signal from TCM to ECM.
P1631Alternator "T" Open or No Power Output (1.8L).
P1632Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633Battery Overcharge.
P1634Alternator "B" Open (1.8L).
P1693MIL Circuit Malfunction.
P1743Torque Converter Clutch Solenoid Valve Open or Short.
P1794Battery or Circuit Failure.
P17954WD Switch Signal Malfunction.
P1797P or N Range Signal or Clutch Pedal Position Switch Open or Short
