Chân ECU
Bình luận: 0Lượt xem: 2,867
thanhluanauto
ECU Pinout
1. black/white, front ignition coil
2. blue/green, ground
3. N/C (locating key)
4. black/gray, kill button
5. green, Axone pin 1
6. white, crankshaft position sensor, pickup 1
7. blue/green, ground
8. yellow/pink, +12V power in
9. red/blue, "ECR" relay contacts
10. yellow/black, rear ignition coil
11. N/C
12. gray, TPS (wiper?)
13. brown, water temperature sensor
14. yellow, Axone pin 2
15. red, crankshaft position sensor, pickup 2
16. white/red, to dashboard, MPH signal
17. blue/white, to dashboard, pin "ECU" (engine light?)
18. red, Axone pin 3
19. violet, gear position sensor
20. pink, intake air temperature sensor
21. blue/green, ground
22. green, tip over sensor
23. brown/yellow, wheel speed sensor, signal
24. green/white, to dashboard, neutral light
25. brown/white, to dashboard, RPM signal
26. blue/black, "ECR" relay
27. N/C
28. violet/black, headlight relay
29. N/C
30. orange, TPS (likely +5V)
31. black/orange, front injector
32. black/pink, rear injector
33. black, fan
34. black/brown, fuel pump
Hệ thống chân từ thiết bị vào
1. turn indicator, right (<-->)
2. turn indicator, left (<-->)
3. neutral (neutral light)
4. high beam (high beam light)
5. MPH
6. scroll
7. oil pressure sending unit (oil light)
8. N/C
9. fuel level sensor (fuel light)
10. N/C
11. key +
12. RPM
13. ground
14. battery +
15. N/C
16. N/C
17. N/C
18. ECU (check engine light)
