Cần giúp đỡ danh sách mã lỗi máy xúc kobeco -8-10
Con.nhan.gheo
Bình luận: 1Lượt xem: 753
Adonis17
Bác tham khảo xem nhé
Kobelco [SK-8] Fault Code
1 Kobelco SK-8 (engine system) sensor system:
P2228, atmospheric pressure sensor failure (LO).
P2229, atmospheric pressure sensor failure (HI).
P0192, common rail pressure sensor failure (LO).
P0193, common rail pressure sensor failure (HI).
P0191, common rail pressure sensor failure.
P0237, boost sensor failure (LO).
P0108, boost sensor failure (HI).
P0117, water temperature sensor failure (LO).
P0118, water temperature sensor failure (HI).
P0182, fuel temperature sensor failure (LO).
P0183, fuel temperature sensor failure (HI).
P0335, main speed sensor system failure, engine can not start / engine stop.
P0340, sub-speed sensor system failure, engine can not start / engine stop.
P2120, double throttle sensor system failure, speed drop (idle speed, speed is 800r/min).
P2121, the throttle sensor 1 voltage is abnormal.
P2122, throttle sensor 1 failure (LO).
P2123, throttle sensor 1 failure (HI).
P2126, throttle sensor 2 voltage is abnormal.
P2127, throttle sensor 2 failure (LO).
P2128, throttle sensor 2 failure (HI).
2 Kobelco SK-8 switch, relay system:
P0540, preheating device failure (open circuit / CND short circuit).
P0540, preheating device failure (+B short circuit).
P0617, start switch circuit failure.
P0686, main relay circuit failure. Fuel pump system:
P0629, fuel supply solenoid valve circuit failure (+B short circuit), engine can not start / engine stop.
P0628, fuel pump solenoid valve circuit failure (full output mode), output drop.
P2635, fuel pump abnormal pressure history.
P2635, fuel pump solenoid valve stuck.
P0088, common rail pressure is abnormal, output is falling.
3 Kobelco SK-8 fuel injection system:
P1211, injector solenoid valve drive system common rail 1 fault (GND short circuit), output down / broken cylinder operation (1 time, 4 times).
P1214, injector solenoid valve drive system common rail 2 fault (GND short circuit), output down / broken cylinder operation (2 times, 3 times).
P1212, injector solenoid valve drive system common rail 1 fault (+B short circuit / open circuit), output down / broken cylinder operation (1 time, 4 times).
P1215, injector solenoid valve drive system common rail 2 fault (+B short circuit / open circuit), output down / broken cylinder operation (2 times, 3 times).
P1601, injector multi-point correction anomaly, output drop.
P0201, injector 1 solenoid valve circuit open, output down / broken cylinder operation (1 time).
P0202, injector 2 solenoid valve circuit open, output down / broken cylinder operation (2 times).
P0203, injector 3 solenoid valve circuit open, output down / broken cylinder operation (3 times).
P0204, injector 4 solenoid valve circuit open, output down / broken cylinder operation (4 times).
P0263, cylinder correction fault 1.
P0266, cylinder correction fault 2.
P0269, cylinder correction fault 3.
P0272, cylinder correction fault 4.
4 Kobelco SK-8EGR system:
P0489, EGR valve linear solenoid valve 1 fault (open circuit / GND short circuit), output drop.
P0490, EGR valve linear solenoid valve 1 fault (VB short circuit), output drop.
P0404, EGR valve stuck 1, output decreased.
P0405, EGR valve safety sensor 1 failure (LO).
P0406, valve safety sensor 1 failure (HI).
5 Kobelco SK-8 Turbine System:
P0234, turbocharged too large, output dropped.
6 Kobelco SK-8 engine system (state judgment):
P0217, overheating, output drop.
P0219, engine speeding.
7 Kobelco SK-8 Communication:
U1001, CAN communication interruption (vehicle).
8 Kobelco SK-8ECU system:
P0611, ECU charging circuit failure (LO), output drop.
P0200, ECU charging circuit is bad (HI).
P0605, ROM abnormality. P0606, CPU failure, the engine can not start the engine to stop.
P0607, CPU monitoring IC error, output drop
Error code Fault description
P0617 Alarm is the start switch failure
P0404 The alarm is an EGR card issue alarm
P2635 The alarm is a diesel high pressure pump end common rail solenoid valve failure
P0405 The alarm is that the EGR valve safety sensor is working abnormally
