bathinh
e có tìm dk cái này có thể có ích cho các cụ
2005 Mazda 6
1. Open drivers door and leave open.
2. Lock and Unlock the drivers door using the power lock switch on door panel.
3. Insert key into the ignition.
4. Turn key to the ON and OFF position 3 times in 10 seconds. Leave key in ignition.
5. Open and close drivers door 3 times ending with door in the open position.
6. Door locks should respond by locking and unlocking.
7. Press any button on remote 2 times. Doors should then lock and unlock.
8. If programming a second remote press any button onit 2 times and door locks
should lock and unlock.
9. Remove key from ignition and locks should lock and unlock again.
10. Test Remotes
2005 Mazda 6
10. Test Remotes
