Autodesk Inventor Routed Systems 2009 Tutorial - Getting Started Guide
J
Bình luận: 0Lượt xem: 1,777
javaro_2405
Content Inside:
This manual book is a complete reference to learn Autodesk Inventor Routed Systems 2009 from the beginning. Here you’ll find information regarding: Tubes and Pipes, This add-in to the Autodesk Inventor assembly environment provides the capability to create complete tube and pipe systems in mechanical assembly designs. Route Basics, Setting Styles, Creating Rigid Routes and Runs, Creating and Editing Flexible Hose Routes. Cable and Harness, This add-in provides tools for creating and manipulating three-dimensional wire harnesses in the context of a standard Autodesk® Inventor™ assembly. Working With Harness Assemblies, This chapter provides basic information about the tools added by the cable and harness environment. It also tells how to create a harness assembly and set properties. Using the Cable and Harness Library, In this chapter, you learn how to navigate in the library and use the Cable and Harness Library tool. Working with Wires and Cables, In this chapter, you learn how to add wires and cables to an assembly and modify them. Working with Segments, In this chapter, you learn how to define and manipulate a segment, how to branch a segment, and how to change the segment display characteristics. Routing Wires and Cables, In this chapter, you learn how to use the different routing and unrouting methods. Working with Splices, In this chapter you learn how to create and manipulate splices, add properties to the splice or splice pins, and set embedded length to indicate splice type. Working with Ribbon Cables, In this chapter you learn how to add a raw ribbon cable definition to the Cable and Harness Library, create a ribbon cable between start and end connectors, and then modify it to control the shape and direction through the assembly. Generating Reports, In this chapter, you learn about the Report Generator user interface, and how to format and generate reports. Working Nailboards and Drawings, In this chapter, you learn how to create a nailboard drawing, manipulate the harness shape, annotate the drawing with dimensions, and add connectors and other key information. You also learn to create a simple assembly drawing with the harness objects represented as centerlines. This manual available to download in pdf format consist of 400 pages.
Download: Clickhere!
this tutorial available free to download at http://teknigroup.com/, we merely found it via google pdf search
