Tiêu Đề : Sách hướng dẫn sửa chữa của Samurai và Vitara
Ngôn Ngữ: Tiếng Anh
Đinh Dạng: pdf
Dung Lượng :3.3 mb
Content Inside:
Turbocharged engines are already something of a tradition at AUDI. The task now facing AUDI’s engineers was to develop a worthy
successor to the 5-cylinder turbocharged engine. One of the key development goals for the turbocharged engine was to achieve a good level of dynamic response, particularly at the bottom end of the rev band. The goal of AUDI’s engineers was to realise a
high “basic torque level“ and a torque characteristic that rises in direct proportion to engine speed to its peak. Engine: Technical data, crankshaft, cylinder head, camshaft timing, cooling circuit, engine lubrication, overview of components, air ducting, charging, exhaust system, pneumatically controlled systems, charge pressure control, air divert control in overrun, ACF system, crankcase
breather. Motronic ME 7.1, Subfunctions, system overview. Subsystems of the Motronic. Torque-oriented engine management, torqueoriented functional structure, Electronic throttle, exhaust gas temperature control. Sensors, Auxiliary signals/interfaces, Functional diagram, Self-diagnosis, Vehicle diagnosis, test and information system VAS 5051, test box V.A.G 1598/31. Transmission, Self-adjusting clutch, gearbox.
Ngôn Ngữ: Tiếng Anh
Đinh Dạng: pdf
Dung Lượng :3.3 mb
Content Inside:
Download Now
[www.oto-hui.com]Audi S4 Engine Design and Function Study Guide.txt 0869 bytes · Xem: 81
