Audi RS4 Technical training guide is contain basic information of the Audi RS4 vehicle systems which needed for Audi Technician or Mechanical. Content Inside: Body, The Audi RS4 Slide, sills, front end, rear spoiler, brief summary, engine and gearbox, engine -RS1 crankcase/crank assembly, cylinder head, piston/con-rod, engine cooling system , injection system, fuel system, secondary air system, engine management, air cleaner with additional air valve, intake air change-over valve, charge air cooler, gearbox, running gear, front axle, rear axle, air conditioner.
Download Now
Audi RS4 Technical Training Manual.txt 0848 bytes · Xem: 84
