AMS Software collection (05/04/2010)
V
Bình luận: 0Lượt xem: 1,460
vothanhtam19
AMS Software Collection (05.04.2010) | 617.32 MB
The collection consists of a short list - 41 - Unattended: silent installation of graphic programs from AMS Software
Name of Program: Collection of graphics software from AMS Software
Program Version: 05.04.10
Language: ENG | RUS
The author builds: wadimus
Treatment: not required
System requirements:
Windows 98 \ ME \ 2000 \ XP (pro \ home) \ 2003 \ Vista \ 7
Features of the collection:
- Installation packages downloaded from the home site and at the moment are the new versions,
- A collection assembled in the shell of Boa Software
- Cured by "greed"
- Put easily
- Removed correctly
- In the unpretentious,
How to install the program:
01- Run a shell (in the folder AMS Software file SETUP.EXE)
02- Choose from the list you're interested in the program and clicked on it
03- A brief description of the program is derived from the bottom shell window, if the mouse to click on the question mark? left of the selected program to open the program description in HTML-format
04- Went to install the program, all placed without user intervention, do not press other buttons!
05- After installation appears on the desktop shortcut to this program and the program menu (Start - All Programs) emerged folder for the program (eg PhotoBEST, there shortcuts to launch or remove this program)
The procedure for treatment:
- All programs are placed with the keys, no further action on the extension Trial No!
Language: ENG | RUS
- Cured by "greed"
- Put easily
- Removed correctly
Code:Full list of programs in assembly:
3D Frames v.1.25:
graphics editor, allowing you to create bright and stylish photo frames. Unlike other similar products, 3D FRAMES generates each frame in real time, sends the shadows, glare and other lighting effects. The program is very easy to learn: it is enough to open any photo frame to load the directory and click "Preview". Within seconds you can see the image in an entirely new form - as a more complete and harmonious
ART Frames v.5.57:
special graphics editor, designed to overlay frames and masks in the photo. Well-matched frame, not only decorates the photograph, but also gives it complete. In the frame of the image becomes much more impressive, producing a vivid impression. ART Frames has a tremendous level of framing any photo.
Auto Collage Studio v.3.0:
easy to use program that will help you to create collages from your digital photos, while making them works of art. Creating a collage - a relaxing pastime that helps to convert the collected photos into precious memories. With this program you can add text and apply different templates and effects to images. Also, you can easily print, save collages in one image, and even share your photos with friends and family.
Beauty Studio v.1.75:
Program for working with photos and improves the appearance of portraits, applying makeup directly on your photos. Care programs can eliminate minor imperfections and give an expressive look, and even change the shape of the face. Your photo will be worthy of any cover of a glossy magazine!
Frame Maker Pro v.3.61:
The program, through which you can add frames to your photos. You can choose from a variety of frames and add them to your images; full screen preview the result, save your framed images in popular formats for use in your projects, print your framed images. You can create hundreds of original and creative frames and save them.
Framing Studio v.2.97:
easy to use program for applying effects, masks and borders to photos, which combines compactness, easy to master, high performance and rich functionality. Advanced image processing technologies make it possible to achieve high quality results to any user. The choice between the classical and modern frames from a variety of materials, as well as masks of different shapes. You can also perform various manipulations with images, including cropping and resizing photos. In addition, this program has nine built-in effects to make unusual shapes and types of your images. The program included more than 70 frames for quick application on your pictures. The interface of this program is simple and easy to use.
Greeting Card Studio v.1.87:
easy to use program to quickly create high-quality greeting cards. With this program you can create greeting cards using your own images, background and text. The program contains a ready-made professional templates designed for quickly creating greeting cards. All you really need, just select the paper, the desired design, open the template you like, edit the card and print off its printer. Also, you can create your own unique design and lay on the thumbnails effects, frames, borders, make the background and superimpose different images on your card. In this case, you are given the opportunity to scale and turn the photos as you wish. Ready result, you can print off a printer or stored in a graphical format.
Home Photo Studio v.2.25:
convenient and powerful photo editor, opening unlimited possibilities for creativity. AMS Home Photo Studio allows you to quickly enhance and edit photos, view slideshows, add lots of special effects, create collages, cards and calendars. The program is perfect for both beginners and experienced users. Home Photo Studio is easy to learn and comes with a detailed help system. Now all you need to work with digital images are in one program! Home Photo Studio was created specifically for fast and high-quality photo processing. You can improve your images in one click the mouse, retouch portraits using special brushes, hold color correction, remove red eye, sharpen and many more!
Media Show Pro v.1.32:
AMS Photo Art Studio is a new software for decoration of photos. The set includes a package of five handy for creating greeting cards, collages, imposing frame and batch processing images. Within literally a few seconds, you can create a stylish frame, create a postcard or a collage. The program includes a handful of functions necessary for processing digital photographs: automatic enhancement and editing, creating special effects, framing, adding decorations and signs.
Photo Art Studio has a customizable user interface, which is easy and convenient to operate. Built-in help system online tutorial will help you turn your photos into a masterpiece.
Photo Art Studio v.2.55:
Photo BEST v.2.51:
effective program to improve the quality of photos. It is easy to open the photo fragments hidden in the shadows give a deep and rich color of the sky; eliminate the noise and vignetting. With PhotoBEST also possible to crop, change the quality of their size and, finally, to fine-manual processing
Photo Cards v.2.27:
handy tool to create beautiful greeting cards. With Photo Cards by clicking on the background, decorations, write a greeting text and effektanaya card is ready. You can insert in the draft, any photographs, making truly unique card.
The program also contains a large number of texts in verse greeting for any holiday
Photo Collage Creator v.3.51:
New version of Photo Collage Creator for creating photo collages and scrapbook, which turns ordinary digital pictures and text into personalized works of art. The program combines the scores of pre-designed fabulous collage templates, more than 50 photo frames, special effects, and flexible publishing formats. Photo Collage Creator includes everything one needs to turn regular digital photos and text into stunning collages, and creating great looking scrapbook pages suitable for printing, adding to a scrapbook, sharing with friends or hanging on the wall. The program enables you to assemble your precious photos into an artistic compilation, completely expressing your ideas. Using advanced features of this program, you achieve dazzling results.
Photo Collage Maker v.2.55:
easy to use program for creating original compositions, consisting of backgrounds and a few photos. Create beautiful collages in the program is fast and easy: just select the background image from a directory, add a couple of your own photos and experiment with different effects. The program allows you to add lettering and decorations. The resulting collage can be viewed on full screen, save or print. Provides the function faster than exports of collages in any of the popular image formats. With Photo Collage Maker you can create amazing compositions, without spending a lot of time and effort. Intuitive interface, plenty of graphic materials in the kit, as well as a large number of additional functions to help you create a really bright and beautiful collage.
Photo Enhancer v.1.51:
provides a quick and easy way to improve the quality of your photos. It reduces digital distortion, low-quality color corrects, improves contrast. AMS Photo Enhancer allows you to eliminate all the problems often faced in photographing, achieving a natural color copy, high detail and optimum color level. Using the program easy and convenient. A simple example program. Compact and convenient
Photo Frames Pro v.4.91:
Professional program for stylish design pictures in frames, which allows the image to make harmonious and give it a complete and spectacular view. Working with Photo Frames PRO easy: just open an image file and select the frame in one of 12 categories (about 150 frames, even in the trial version). You can also adjust brightness, contrast photos and impose a number of filters. At any time the result is available for full-screen viewing. After registering, users receive more than 200 frames and masks of excellent quality. Photo Frames PRO will fotogorafii truly beautiful!
Photo Frames v.6.0:
special graphics editor, designed to impose a variety of frames and borders to photos. In this function, Photo Frames also has a wide range of tools for processing and correction, which gives even greater scope for your creativity. The results can be viewed in full screen mode, save in different formats and print.
Photo MAX v.1.31:
handy utility to quickly improve, edit and convert images, making it easy to prepare images dL quality print and publishing on the Internet. The latest processing algorithms will make any picture a bright, colorful and sharp. PhotoMAX supports all popular graphic file formats, includes a quick viewer, but also has features batch conversion and resizing of photos. The program is especially recommended for publishing photos to the Internet, when you want to make a picture smaller, but retain detail
Picture Combine v.1.45:
friendly graphical editor for batch processing images. The program has broad capabilities for the correction of images, add special effects and design of the photo using the framework, boundaries and labels. Any sequence of actions can be saved to a file and later used to process other sets of images. Picture Combine is simple to learn, and provides detailed help system
Virtual Makeup v.2.15:
simple and convenient program for retouching portraits and makeup in photos. Do not just make the photos are beautiful, but also change their style. The program includes more than ten unique tools for the transformation of the exterior of the photo. From traditional makeup to change the color of hair and plastic face!
Virtual Painter v.3.0:
Affordable and easy to use program to convert photos into drawings and create beautiful artistic effects. Virtual Painter lets you simulate watercolor, pencil drawing, cubism, mosaic, burning wood and even the illustrations in the style of comics! You can also choose the original canvas for painting and use the effect of uneven surfaces. Make the completeness of the picture can be created with the help of stylish frames.
Design Calendar v.2.91:
A new program to create beautiful calendars with photographs for any year or month. With it you can easily create stylish photo-quality. The program allows you to prepare hundreds of versions of calendars in a variety of styles: classic and modern, rigorous or elegant, business or romantic. The kit also includes a large selection of ready-made templates created by professional designers.
Convenient and powerful photo editor that opens unlimited possibilities for creativity. It allows you to quickly enhance and edit photos, view slideshows, add hundreds of special effects, create collages, cards and calendars. Home Photo Studio allows you to achieve excellent results even for beginners.
Master business card v.1.61:
handy software from AMS Software to quickly create business cards and badges. Includes more than 150 ready-made designs business cards on various topics, as well as the possibility of creating their own original styles. For the preparation of a beautiful business card is enough to enter contact details, select a template and edit the layout to your liking. Then you can print any number of cards on a printer or save the business card for later printing.
Master Collages v.4.57:
excellent program for creating original compositions, consisting of backgrounds and multiple photos. Create beautiful collages in the program is fast and easy: just select the background image from a directory, add a couple of your own photos and experiment with different effects. Master Collages can also add labels and decorations. The resulting collage can be viewed on full screen, save or print. Provides the function faster than exports of collages in any of the popular image formats.
Master Card v.5.0:
program of the new generation for fast creation of beautiful greeting cards. With the help of the wizard by clicking on the background, decorations, write a greeting text and spectacular card is ready. You can insert in the draft, any photographs, making truly unique card. The program also contains a large number of texts congratulations verses for any holiday.
Master of Cards Pro v.4.0:
Master Cards defense will create the most beautiful postcards with your favorite photos. With the help of Master Cards enough to choose the background, decorations, write a greeting text and spectacular card is ready. You can insert in the draft, any photographs, making truly unique card. The program also contains a large number of texts congratulations verses for any holiday.
Master Portrait v.4.17:
universal program for processing and presentation portraits. With it you can easily improve both portrait and a simple plot of photos: remove red eye, remove noise, enhance detail, change the white balance, etc. A wide range of functions for automatic and manual editing can achieve excellent results. You can also transform the image by the original effects, impose a stylish frames, masks and figure caption. Master Portrait has the ability to quickly change the background in photography and art processing fragments of a portrait. The program has a friendly interface and easy to learn.
Photo Effects v.4.57:
Photo Effects - a new program for processing photos with the help of various filters. With its help you can completely transform any image. The program allows you to use more than 50 effects, including both traditional and original ones. You can see their photos in the rain and snow, in fog and the clouds, add some sun light to it or swirl it in a typhoon ...
Studio Collage v.4.25:
handy tool for creating effective compositions from the set of photos that can be used as desktop wallpaper, posters or postcards. Create beautiful collages easy as using ready-made templates, and completely independently. Collage Studio allows you to add labels, decorations and special effects. The resulting image can be viewed on full screen, save or print. Provides the function faster than exports of collages in any of the popular image formats.
Beauty Studio v.2.25:
program to improve portraits and makeup directly on your photos. With it you can easily remove small defects of the skin, giving an expressive look, and even change the shape of the face. Beauty Studio will photograph any decent covers of glossy magazine. Beauty Studio different user-friendly interface and ease of use. It allows for a few minutes to improve as not very successful shots, and make perfect good photos. Clean and smooth skin, enchanting eyes, artfully superimposed makeup ... and your photo will be simply irresistible.
Studio Effects v.4.0:
program, which can easily transform your photos with hundreds of unique filters. Professional effects to photos are now available to everyone. Simply select the desired effect, and enjoy an excellent result!
Postcards Factory v.4.55:
program to quickly create stylish greeting cards. Now just a couple of minutes to prepare professional-quality postcard with your photo. The complete program includes more than fifty bright and original templates of cards and calendars. Postcards Factory allows you to impose a framework and apply special effects.
Picture Doctor v.1.15:
A new program to recover deleted photos from memory cards, USB flash drives, cameras and mobile phones.
It allows you to quickly find and save deleted files, with support as the restoration of all the found photos, and sample. FotoDOKTOR provides an opportunity to preview JPEG files directly during the search and filter the photos depending on the format. The program has a stylish interface in Russian, easy to learn and even includes a built-in Video Tutorial!
Photo Calendar 2010 X5:
easy to use program for creating calendars with photographs. Create beautiful calendars with your photos quickly and easily! Within minutes you can get the calendar right format and style - from pocket to wall, for a whole year or a month. Choose the original design of the calendar - strict or elegant, romantic or business .. The program generates a calendar grid, not only for 2010, but also to any other.
Photo Mixer v.3.0:
A new program for original registration of your photos. With it you can quickly and easily create bright, unusual and effective compositions. To do this, simply open the photo you want, select the appropriate type of registration and click "Finish", then you can view the result on the full screen, save or print. Photo Mixer will beautifully arrange a photo of your choice: Add a classic scope, create a greeting card or an expressive collage
Photos of the documents Express v.1.96:
update on the Russian program AMS Software for preparing photos for documents in the home or use in photo market, which will prepare the photos for professional-quality documents in just three steps. With a convenient marker system you can make a layout, edit photos and images ready to place on a sheet of paper. Then you can print photos at home and in the nearest photo shop ... but several times cheaper!
Photo Host v.1.25:
handy utility to upload photos to the Internet through a service Yandeks.Fotki. It allows you to quickly download large number of photos, to reduce the image before publication, and also has the function of express improve your photos. The program includes a built-in viewer, the possibility of batch processing and renaming photos. You'll also be able to quickly view and save any images featured on Yandeks.Fotkah.
FotoDEKOR v.4.75:
A new program for processing photos and create effects. Just a couple of seconds you can impose a stylish frame, create a greeting card or collage. The program includes all necessary functions for processing digital photographs: automatic enhancement and editing, creating special effects, framing, adding decorations and inscriptions. Set the program includes about three hundred different design options, and in the full version of their number increases up to a thousand!
The photo v.5.15:
A new program for stylish design photos, which suited both for beginners and for studios. Just a couple of seconds you'll be able to impose a beautiful frame, create a greeting card or a collage. The program includes all necessary functions for processing digital photographs: automatic enhancement and editing, creating special effects, calendars, framing, adding decorations and inscriptions. Set the program includes more than three hundred different design options, and in the full version of their number increases up to a thousand!
Download Links :
Servers: (HotFile)
HotFile:
hotfile.com AMS.Software.05.04.2010.part1.rar.html
hotfile.com AMS.Software.05.04.2010.part2.rar.html
hotfile.com AMS.Software.05.04.2010.part3.rar.html
hotfile.com AMS.Software.05.04.2010.part4.rar.html
hotfile.com AMS.Software.05.04.2010.part5.rar.html
hotfile.com AMS.Software.05.04.2010.part6.rar.html
hotfile.com AMS.Software.05.04.2010.part7.rar.html
