hyundai
Instructions for downloading and applying the DOC® update:
- Close the DOC® application.
- Click on the button below to begin the download process.
- A dialog box will be presented that will give you the choice to save the file to your hard disk, or open the file directly from the Internet.
- a) To open the file directly,
- If you are using Internet Explorer, choose "Run this program from its current location."
- If you are using Netscape, click the "Open Using" button, leave the text field blank, and click "OK."
- If you receive a Security Warning, click "Yes."
- The installation process with begin immediately after the download is complete.
- If you are using Internet Explorer, choose "Save this program to disk" and choose where you wish to save the update. Click "OK."
- If you are using Netscape, choose where you wish to save the update or accept the default location. Click "Save."
- Once the file has finished downloading, you will need to run the update from the location you specified.
