Aircraft Wiring Diagram Ducati Tachometer for Rotax Two Stroke Engine
C
Bình luận: 0Lượt xem: 1,545
Ctrl+V
Here is Ducati tachometer wiring diagram for Rotax two stroke aircraft engine. One of the things that many pilots fail to realize is that the output wires from the engine to the tachometer need to be shielded if a radio is installed on their aircraft. In addition the ignition shut off wires and the charging system wires ALSO need to be shielded. Full Ducati tachometer aircraft wiring diagram here.
Chủ đề bác đang quan tâm
