vothanhtam19
Content Inside :
This service manual includes : bracket, camshafts and rocker arms DOHC, crankshaft, flywheel and drive plate, cylinder head and valves - SOHC, cylinder head and valves DOHC, exhaust manifold and water pump, front case, silent shaft and oil pan, fuel and emission control parts, generator and ignition, intake manifold, piston and connecting rod, rocker arms and camshaft, turbocharger. Lubrication system oil pump type cooling system water pump type and number, throttle position sensor, closed throttle position switch. Total resurfacing depth both cylinder head and cylinder block, overall height. The camshaft identification mark is stamped on the rear end of the camshaft, fuel pump driving cam diameter journal diameter. Installation service point, distributor installation : Align the marks put at the time of disassembly, and install the gear to the distributor shaft. Drive belt tension adjustment, adjuster type.
Download Now
1992 Mitsubishi Engine 4G61, 4G63, 4G64 Service Manual.txt 0821 bytes · Xem: 151
