[0001610] Hitachi ZX-450-3 / 450 / 470 / 500 (Zaxis) Technical Manual
hyundai
Bình luận: 8Lượt xem: 5,797
hyundai
Hitachi ZX450-3,450LC-3,470H-3,470LCH-3,500LC-3,520LCH-3 Technical Manual Troubleshooting
(ID 168123353)
This manual contains technical information needed for operational performance tests, and troubleshooting procedures. Make sure you understand the contents of this manual and use it to full effect at every opportunity.
APPLICABLE MODELS :
Hitachi Zaxis 450-3 / Hitachi ZX-450-3
Hitachi Zaxis 450LC-3 / Hitachi ZX-450LC-3
Hitachi Zaxis 470H-3 / Hitachi Zx-470H-3
Hitachi Zaxis 470LCH-3 / Hitachi ZX-470LCH-3
Hitachi Zaxis 500LC-3 / Hitachi ZX-500LC-3
Hitachi Zaxis 520LCH-3 / Hitachi ZX-520LCH-3
TABLE OF CONTENTS :
OPERATIONAL PERFORMANCE TEST
Group 1 Introduction
Group 2 Standard
Group 3 Engine Test
Group 4 Excavator Test
Group 5 Component Test
Group 6 Adjustment
TROUBLESHOOTING
Group 1 Diagnosing Procedure
Group 2 Monitor Unit
Group 3 Dr. ZX
Group 4 ICF
Group 5 Component Layout
Group 6 Troubleshooting A
Group 7 Troubleshooting B
Group 8 Electrical System Inspection
File Format : PDF
Language : English
Total pages : 580+
* This Manual PDF Compatible with All version Windows PC OS, MAC OS and Linux OS.
* Compression utility needed to extract it first, if PDF locate in the archive (e.g. 7-zip).
Illustrations used throughout this manual are used only as a representation of the actual piece of equipment, and may vary from the actual item.
NgoHoangHa
(ID 168123353)
APPLICABLE MODELS :
TABLE OF CONTENTS :
Group 2 Standard
Group 3 Engine Test
Group 6 Adjustment
TROUBLESHOOTING
Group 3 Dr. ZX
Group 4 ICF
File Format : PDF
Language : English
Total pages : 580+
tài liệu này có sơ đồ điện có mã màu dây của rắc màn hình và hộp ecu không vậy cụ
