WHAT IS A TURBOCHARGER?
Turbocharger là một quạt gió ly tâm được dẫn động thông qua tuốc bin sử dụng dòng khí xả của động cơ. Và được dùng để tăng áp dòng khí nạp cho động cơ.
IT IS SIMPLY AN AIR PUMP -
DIESEL ENGINE
How does the Turbo work?
TURBINE
COMPRESSOR
Turbocharger Gas & Air Flow
Turbocharger Gas & Air Flow - On Engine
Turbocharger Construction
1 Shaftwheel Assembly
2 Centre Housing
3 Thrust assembly - the thrust bearing
Sintered bronze or sintered iron
3 Thrust assembly - the thrust collar
Multi function
Compressor End Dynamic Seal
4 Journal bearings
6 The CHRA
- Forces more air into the engine at higher than ambient pressure.
DIESEL ENGINE
- More Air + More Fuel = More Power
- More Air + Same Fuel = Cleaner Exhaust
- (Gasoline engine has closer limits on air/fuel ratio)
TURBINE
- A turbine wheel is driven by the otherwise 'waste' exhaust gases. The turbine is connected to a compressor wheel and the whole assembly rotates at speeds up to 230,000 rpm.
COMPRESSOR
- Ambient air is drawn into the turbo via an air filter, then, as it passes over the compressor wheel it accelerates up to very high speed.
- Once past the compressor wheel it passes through a 'diffuser' which is formed between the face of the backplate (or centre housing) and the machined face of the compressor housing.
- As it passes through this area the air moving at high speed slows down and this continues as it passes though the 'volute' of the compressor housing (shaped like a snail's shell!). This turns the Kinetic energy of the moving air into high pressure air.
- The machined shaft and investment cast turbine wheel are joined by Inertia Welding or Electron Beam Welding
- Samples of the weld tested for hardness in heat affected area
- Weld penetration checked
2 Centre Housing
- Sand castings in various material grades
- Tested for porosity and for dimensional accuracy
- Bearing bore finish is critical surface
- Some use oil squirt hole for additional cooling
- Many different designs
- 270 degree or 360 degree
Multi function
- Controls axial movement
- Separates oil and gases (oil thrower or slinger)
- Piston ring dynamic seal
4 Journal bearings
- Most fully floating
- Some semi floating
- Both designs use two oil films.......................
- Rely on high speeds for efficiency
- Flatback and EBD
6 The CHRA
