Em đang gặp con nissan navara nổ một chổ đạp ga k quá 3000v nhưng chạy thì lại ga lên
Thanhhoang2001
Bình luận: 2Lượt xem: 1,468
Solipsism
Im thinking possibly an 02 sensor, or obstructed fuel filter perhaps....when you say "explode" im assuming you mean a backfire when applying the accelerator? If so id try to identify if the backfire is coming from the exhaust (possible lean fuel mixture) or if the backfire is from the intake side (possibly incorrect ignition timing) ...i would also ask if the engine temperature is within normal peramiters...just my thoughts
