WorkShop Manual Ford Motor Company USA 2006-2013/Rukovodstva for repair, maintenance and electrical
Year / Date : 2012 Version : 1.63 Developer : Ford USA Web Developer : www.motorcraftservice.com Language : English Tabletka : Not required Description : Language English ! The disc contains guidance on repair and maintenance of cars Ford from 2006 to 2013th model years. As there are electrical. Staged repair of units and descriptions anregatov. Adjusting data and reference material. Extras. Information : Distribution includes 6 images DVD (2006-2007, 2008, 2009-2010, 2011, 2012, 2013). To install the program with the correct model year to the corresponding disk image to burn to DVD or USB flash drive. You can create a virtual disk. So do as you prefer. Before installing change the date on the computer on July 15, 2012. Click on the icon for DVD-ROM, a window startup. Authorize the installation. After installation on the desktop icon "Sevice Information". Run the program and use. If you want to set all model years it was doing the above process for each DVD. I installed Win7 on it compatible with Win XP SP3. Basically three months to stop working due to set time code. Put the date July 15, 2012 and use further. The idea is not to work at the current time. But on my Win7 works. For normal operation requires Adobe Acrobat 5.0 or higher.
Download Now
WorkShop Manual Ford Motor Company USA 2006-2013.txt 0217 bytes · Xem: 79
