Tutorial SolidWorks 2005 - 3D Modeling LINKAGE Assembly
J
Bình luận: 0Lượt xem: 2,031
javaro_2405
Content Inside :
SolidWorks is a 3D solid modeling CAD program. SolidWorks provides design software to create 3D models and 2D drawings. Learn modeling techniques from others; create your own designs. A common manufacturing procedure for plastic parts is named the Injection Molding Process. In this project you created three parts, downloaded the AIRCYLINDER assembly and created the LINKAGE assembly. You developed an understanding of the SolidWorks User Interface: Menus, Toolbars, System feedback, Keyboard shortcuts, Document Properties, Parts and Assemblies.
You obtained the knowledge of the following SolidWorks features: Extruded Base, Extruded Cut and Linear Pattern. Features are the building blocks of parts. The Extruded Base feature required a Sketch plane, Sketch and Depth. Today’s automobiles utilize over 50% plastic components. Engineers and designers work with mold makers to produce plastic parts. Cost reduction drives plastic part roduction.
Download: Clickhere!
