Toyota Supra 1995 Service & Repair Manual
J
Bình luận: 2Lượt xem: 1,560
javaro_2405
HOW TO USE THIS MANUAL:
INDEX
An INDEX is provided on the first page of each section to guide you to the item to be repaired. To assist you in finding your way through the manual, the Section Title and major heading are given at the top of everypage.
GENERAL DESCRIPTION
At the beginning of each section, a general Description is given that pertains to all repair operations contained in that section. Read these precautions before starting any repair task.
TROUBLESHOOTING
TROUBLESHOOTING tables are included for each system to help you diagnose the problem and find the cause. The fundamentals of how to proceed with troubleshooting are described on page IN19. Be sure to read this before performing troubleshooting.
PREPARATION
Preparation lists the SST (Special Service Tools), recommended tools, equipment, lubricant and SSM (Special Service Materials) which should be prepared before beginning the operation and explains the purpose of each one.
REPAIR PROCEDURES
Most repair operations begin with an overview illustration. It identifies the components and shows how the parts fit together.
bostag3
INDEX
GENERAL DESCRIPTION
TROUBLESHOOTING
PREPARATION
REPAIR PROCEDURES
anh ơi! em cho em xin tài liệu được không? Em mới tham gia nên không có xăng ạ! Nếu được a gửi qua bostag3@gmail.com em xin cảm ơn nhiều ạ!
