Toyota Engine List
Bình luận: 0Lượt xem: 1,163
haui
Type: 1331cc EFI DOHC 16-valve 4-cyl turbo
Power: 100kW @ 6400
Torque: 157Nm @ 4800
Sources: 90-95 Starlet GT (bolt into Aust Paseo and Jap SERA)
Type: 1587cc EFI DOHC 16-valve 4-cyl
Power: 88kW @ 6600rpm(1988), 100kW @ 7200 (1990)
Torque: 142Nm @ 5200 (1988), 147Nm @ 6000 (1990)
Sources: FWD GT Corollas, mid mount in early MR2, RWD sprinter, 1988 version had 9.4:1 CR, 1990 had 10.3:1 CR and different intake.
Type: 1587cc EFI DOHC 20-valve 4-cyl quad throttle bodies
Power: 119kW @ 7400
Torque: 162Nm @ 5200
Sources: 93-95 Trueno Apex GT coupe and Corolla GT (1996 Carina GT had 123kW)
Type: 1587cc EFI DOHC 16-valve 4-cyl supercharged
Power: 108kW @ 6400 ('90 123kW @ 6400)
Torque: 186Nm @ 4400 ('90 206Nm @ 4400)
Sources: 88-89 Levin GT-Z and MR2 GT, uprated in '90 Trueno GT-Z
Type: 1998cc EFI DOHC 16-valve 4-cyl
Power: 123kW @ 6800
Torque: 191Nm @ 3200
Sources: 92-95 Celica, Carina and Corona (96-97 model Celica SS3 and current ZS had 134kW version, current Altezza has 147kW VVTi version)
Type: 1998cc EFI DOHC 16-valve 4-cyl turbo
Power: 165kW @ 6000 (180kW in MR2 GT-S)
Torque: 304Nm @ 3200
Sources: Celica GT-Four and '90-on MR2 GT (early GT-Four has less power)
Type: 1988cc EFI DOHC 24-valve 6-cyl
Power: 119kW @ 6400 (auto 112kW @ 6200)
Torque: 180Nm @ 5600
Sources: As far back as the '83 Celica 2000GT
Type: 1988cc EFI DOHC 24-valve 6-cyl twin turbo
Power: 157kW @ 6200
Torque: 274Nm @ 3800
Sources: '88-on Corona GT and Soarer Twin Turbo
Type: 1988cc EFI DOHC 24-valve 6-cyl supercharged
Power: 127kW @ 6000
Torque: 225Nm @ 3600
Sources: 1990 Crown
Type: 2491cc EFI DOHC 24-valve 6-cyl
Power: 132kW @ 6000
Torque: 235Nm @ 4800
Sources: 91-93 Cresta and Supra (96-97 Chaser had 147kW version)
Type: 2491cc EFI DOHC 24-valve 6-cyl twin turbo
Power: 206kW @ 6200
Torque: 362Nm @ 4800 (378Nm @ 2400 in VVTi single turbo)
Sources: 91-93 MKII, Supra 2.5GT and Soarer 2.5GT-T, VVTi version from late 1995
Type: 2954cc EFI DOHC 24-valve 6-cyl turbo
Power: 179kW @ 5600
Torque: 343Nm @ 3200
Sources: 89-90 Supra 3.0GT and Soarer GT
Type: 2994cc EFI DOHC 24-valve V6
Power: 157kW @ 5400
Torque: 289Nm @ 4400
Sources: 96-97 Windom (Lexus ES300)
Type: 2997cc EFI DOHC 24-valve 6-cyl
Power: 166kW @ 6000
Torque: 284Nm @ 4800
Sources: Supra SZ-R, Aristo S
Type: 2997cc EFI DOHC 24-valve 6-cyl sequential twin turbos
Power: 206kW @ 5600
Torque: 430Nm @ 3600 (451Nm for VVTi version '96-on)
Sources: 96-97 Supra Turbo and Aristo V
Type: 3968cc EFI DOHC 32-valve V8
Power: 191kW @ 5400 (206kW @ 6000 in current VVTi version)
Torque: 353Nm @ 4600 (402Nm @ 4000 in current VVTi version)
Sources: 1989-on Celsior, Soarer, Crown Majesta
đang tiếp tục cập nhật!
