Thống số kĩ thuật Trooper 2002
P
Bình luận: 1Lượt xem: 2,730
phamhuy
2002 Isuzu Trooper S Sport Utility Performance & Efficiency Standard Features
3,494 cc 3.5 liters V 6 front engine with 93.4 mm bore, 85 mm stroke, 9.1 compression ratio, double overhead cam and four valves per cylinder
Unleaded fuel 87
Fuel economy EPA highway (mpg): 19 and EPA city (mpg): 15
Multi-point injection fuel system
22.5 gallon main unleaded fuel tank
Power: 160 kW , 215 HP SAE @ 5,400 rpm; 230 ft lb , 312 Nm @ 3,000 rpm
2002 Isuzu Trooper S Sport Utility Handling, Ride & Braking Standard Features -
Four-wheel ABS
4.3:1 axle ratio
Four disc brakes including four ventilated discs
Immobilizer
Limited slip differential
Fullsize steel rim rear spare carrier spare wheel
Wishbone front suspension independent with stabilizer bar and torsion springs , beam rear suspension rigid with stabilizer bar and coil springs
2002 Isuzu Trooper S Sport Utility Exterior & Aerodynamics Standard Features -
Argent front and rear bumpers
Chrome/bright trim
Driver and passenger power heated black door mirrors
External dimensions: overall length (inches): 181.3, overall width (inches): 72.2, overall height (inches): 72.2, ground clearance (inches): 8.3, wheelbase (inches): 108.7, front track (inches): 59.6, rear track (inches): 59.8 and curb to curb turning circle (feet): 38.1
Conventional lens halogen bulb headlights
Two-tone metallic paint , two-tone gloss paint , two-tone black paint , two-tone mica paint
Fixed rear window with defogger and intermittent
Rear platform step
Tinted glass on cabin , privacy tinted glass on rear , privacy tinted glass on side
Underbody protection for fuel tank, for transfer case and for engine
Weights: gross vehicle weight rating (lbs) 5,510, curb weight (lbs) 4,455, gross trailer weight braked (lbs) 5,000 and max payload (lbs) 1,055
Windshield wipers with fixed intermittent wipe
2002 Isuzu Trooper S Sport Utility Interior Standard Features -
12v power outlet: front and rear and 1
Air conditioning
Diversity antenna
Peripheral anti-theft protection
Front and rear ashtray
Manufacturer's own audio system with AM/FM and cassette
Cargo area cover/rear parcel shelf
Cargo area light
Cargo capacity: rear seat down (cu ft): 90.2 and all seats in place (cu ft): 46.3
Front seats cigar lighter
Clock
Full dashboard console , full floor console with covered storage box
Courtesy lights
Cruise control
Front seats and rear seats cup holders fixed
Door pockets/bins for driver seat, passenger seat and rear seats
Floor covering: carpet in load area
Floor mats
Driver and passenger front airbag
Bucket driver and passenger seat
Height adjustable 3-point reel front seat belts on driver seat and passenger seat
Front seat center armrest
Lockable glove compartment
Two height adjustable head restraints on front seats and rear seats
Illuminated entry system
Internal dimensions: front headroom (inches): 39.8, rear headroom (inches): 39.8, front hip room (inches): 53.7, rear hip room (inches): 53.5, front leg room (inches): 40.8, rear leg room (inches): 39.1, front shoulder room (inches): 57.3 and rear shoulder room (inches): 57.3
Low fuel level warning
Remote power locks
Vehicle speed proportional power steering
Front power windows with one one-touch , rear power windows
Front reading lights
3-point reel rear seat belts on driver side , 3-point reel rear seat belts on passenger side , lap static rear seat belts on center side
Rear seat center armrest
Three asymmetrical bench front facing reclining rear seats with zero adjustments
Rear view mirror
Remote fuel filler door release
Front seat back storage
Upgraded cloth/velour seat upholstery with additional upgraded cloth/velour
Seating: five seats
Six speaker(s)
Plastic steering wheel with tilt adjustment
Tachometer
Illuminated driver and passenger vanity mirror
Ventilation system with recirculation setting
http://www.motortrend.com/cars/2002/isuzu/trooper/specifications/index.html#ixzz0lNuaUmnf
tantien1697
Unleaded fuel 87
Four-wheel ABS
4.3:1 axle ratio
Immobilizer
Chrome/bright trim
Rear platform step
Air conditioning
Diversity antenna
Cargo area light
Clock
Courtesy lights
Cruise control
Floor mats
Remote power locks
Rear view mirror
Seating: five seats
Six speaker(s)
Tachometer
bác ơi, tài liệu xe này bác còn ko cho e xin ạ
