Tài liệu Biến tần Rich Electric EI-MINI Series
E
Bình luận: 0Lượt xem: 1,666
Escape
Features
  • Solid state reversing
  • 2-wire or 3-wire control inputs
  • Digital output for "Drive Healthy"
  • Constant torque or variable torque V/HZ patterns
  • 100/120 Hz maximum frequency
  • +15Vdc power supply for external devices
  • External inputs for drive enable and fault reset
  • Electronic motor overload protection
Protection Features
  • Over-temperature
  • Under-temperature
  • Over-voltage
  • Under-voltage
  • Input AC MOV (Oxide Variable Resistor)
  • Over-current @ 200%
  • Electronic Timed Over-load ('lxt')
Link download: http://www.mediafire.com/?9n6td07nen3isik
