sơ đồ điiện đông cơ :C-9 Industrial Engine Electrical System
minhtupxcd
Bình luận: 2Lượt xem: 1,263
minhtupxcd
đây là sơ đò điên của c9 bao gồm đầy đủ danh điểm của các cảm biến (pdf )
Module Identifier (MID²)
(MID No. 036)
t n e n o p m o C D I C
0001 Injector Cylinder [HASHTAG]#1[/HASHTAG]
0002 Injector Cylinder [HASHTAG]#2[/HASHTAG]
0003 Injector Cylinder [HASHTAG]#3[/HASHTAG]
0004 Injector Cylinder [HASHTAG]#4[/HASHTAG]
0005 Injector Cylinder [HASHTAG]#5[/HASHTAG]
0006 Injector Cylinder [HASHTAG]#6[/HASHTAG]
0042 Injection Actuation Control Valve
0091 Throttle Position Sensor
0094 Fuel Pressure Sensor
0100 Engine Oil Pressure Sensor
0110 Engine Coolant Temperature Sensor
0164 Injection Actuation Pressure Sensor
0168 System Voltage
0172 Intake Manifold Air Temperature Sensor
0175 Engine Oil Temperature Sensor
0247 J1939 Data Link Communications
0253 Personality Module Mismatch
0254 Electronic Control Module
0261 Engine Timing Calibration
0262 5 Volt Sensor Supply
0263 Digital Sensor Supply
0268 Check Programmable Parameters
0273 Turbo Outlet Pressure Sensor
0274 Atmospheric Pressure Sensor
0320 Speed/Timing Sensor
0342 Secondary Engine Speed Signal
Event Identifiers (EID)
t n e v E D I E
E004 Engine Overspeed Shutdown
E005 Fuel Filter Restriction Derate
E006 Fuel Filter Restriction Shutdown
E015 High Engine Coolant Temperature Derate
E016 High Engine Coolant Temperature Shutdown
E017 High Engine Coolant Temperature Warning
E025 High Inlet Air Temperature Derate
E027 High Inlet Air Temperature Warning
E039 Low Engine Oil Pressure Derate
E040 Low Engine Oil Pressure Shutdown
E057 Low Engine Coolant Level Derate
E058 Low Engine Coolant Level Shutdown
E059 Low Engine Coolant Level Warning
E095 Fuel Filter Restriction Warning
E100 Low Engine Oil Pressure Warning
E190 Engine Overspeed Warning
¹ The CID is a diagnostic code that indicates which circuit is faulty.
² The MID is a diagnostic code that indicates which electronic control module
diagnosed the fault.
