2003 S55
Safety Recalls
TSB Number & Issue Date TSB Title
2004050015 AUG 04 Recall - Trunk Lid Spring Replacement
Service Bulletins
P-88_70-39 MAR 05 Body - Outside R/V Mirror to Door Seal Damaged
P-32_50-24 MAR 05 Suspension - ABC Suspension Humming/Buzzing Noise
P-82_70-314C MAR 05 Cell Phone - High Pitched Whining Noises During Calls
P-68_60-37B JAN 05 Interior - Sun Visor Cover Broken
P-68_10-39 JAN 05 Interior - Unable to Open Glove Compartment
P-27_60-43 JAN 05 A/T - Rough Converter Engagement/Droning/Buzzing Noise
P-30_30-61 DEC 04 Cruise Control Inoperative
P-54_30-92A DEC 04 Instruments - Cluster Version Coding
P-82_10-419 DEC 04 Lighting - Condensation in Headlamps
P-32_25-19 DEC 04 Suspension - Shock/Strut Replacement Guidelins
P-18_00-17C DEC 04 Engine - Approved Engine Oils (Addition)
P-82_70-346B NOV 04 Cell Phone - Inoperative/Locks-Up
P-15_40-54 NOV 04 Charging System - Insufficient Charging
P-27_00-47A OCT 04 A/T - 722.6 Oil Leaks From Electrical Connection
P-77_10-24 OCT 04 Body - Sliding Roof Water Leaks/Rattles
S-07_61-38F OCT 04 Engine/Transmission Controls - SCN Coding
P-82_30-399 OCT 04 Windshield - Blistering Near Rain/Light Sensor
P-42_20-49 SEP 04 Brakes - Noise From Rear of Vehicle
P-91_10-52B SEP 04 Interior - Front Seat Cracking Noise During Adjustment
P-33_15-12 SEP 04 Steering/Suspension - Knocking/Rumbling Noise on Bumps
P-82_30-366 SEP 04 Wipers/Washers - Wipers Chatter/Noisy After Blade Change
P-77_20-25 SEP 04 Body - Sliding Roof Malfunctions/Code 414 Set
P-82_10-201B SEP 04 Lighting - Front Turn Signal Inoperative
P-82_00-260A AUG 04 Audio System - CD's Won't Play or Eject
P-83_00-70 AUG 04 A/C - Inoperative/Codes Set/AC OFF Lamp Illuminated
P-91_40-67A JUL 04 SRS - Warning Lamp ON/DTC's B9183/B91A3 Stored
P-91_60-74 MAY 04 SRS - Coding Unnecessary
P-82_85-324A MAY 04 COMAND (R) System - Vehicle Battery Low/Dead
P-82_95-322A APR 04 Communications - 'Tele Aid Not Active' Displayed
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
P-82_70-327 FEB 04 Cellular Phone - Cradle Kit Applications
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
P-33_15-10 FEB 04 Steering/Suspension - Alignment Requirements
P-82_00-228B FEB 04 Audio System - Mutes Randomly
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
P-82_30-316 DEC 03 Wipers/Washers - Erratic Intermittent Wipe Explanation
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
P-54_30-103 NOV 03 Instruments/Audio - Radio Control System Settings
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_85-288 SEP 03 COMAND(R) System - Unable to Enter New Destination
P-82_85-264 JUL 03 Navigation System - Inoperative/Erroneous Guidance
P-82_10-266 JUL 03 Lighting - Right/Left Low Beam Out Message Displayed
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-54_30-73A JUN 03 Instruments - Electrical System Voltage Displayed
P-27_60-37 MAY 03 Antitheft System - Cannot Shut Vehicle OFF
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-91_60-57A MAY 03 SRS System - Control Module Service Precautions
P-54_21-85 APR 03 Lighting - False Check Headlamp Message/DTC's Set
P-91_60-58 APR 03 SRS System - Post Collision Impact Sensor Replacement
P-54_65-86 APR 03 Parking Assist System - Apparent Erroneous Activation
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-54_21-67A FEB 03 Lighting - 'Check Left Low Beam' Message Displayed
P-54_30-76 JAN 03 Instruments - '00000' Displayed on Odometer
P-54_30-77 JAN 03 Instruments - 'Display Defective' Displayed/Lamps ON
P-83_55-65 DEC 02 A/C - Compressor Cycles Frequently
P-32_50-12 DEC 02 Automatic Suspension - Hydraulic Fluid Leaks
P-82_85-210 NOV 02 Navigation/GPS System - Various Malfunctions
P-54_30-72 OCT 02 Instruments - Incorrect Engine Rpm's Displayed
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
P-32_50-11 AUG 02 Air Suspension - Pneumatic Suspension Message Displayed
P-82_85-197 AUG 02 Navigation System - Poor Performance
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
P-83_00-61 FEB 02 Interior - Vinegar Like Smell in High Temperatures
P-82_30-178 FEB 02 Wipers/Washers - Wiper Blades Come loose
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
P-83_40-60 JAN 02 Automatic Temperature Control - Inoperative
Service Bulletins
