PTC PRO Engineer Wildfire v3.0 M230 for Windows x86 - SHooTERS
C
Bình luận: 0Lượt xem: 1,804
Ctrl+C
PTC PRO Engineer Wildfire v3.0 M230 for Windows x86 - SHooTERS | 1.51GB
Integrated 3D CAD/CAM/CAE Solutions for Any Size Design Challenge
Customer requirements may change and time pressures may continue to mount, but your product design needs remain the same. Regardless of your project's scope, you need a powerful, easy-to-use, affordable solution.
Pro/ENGINEER is the standard in 3D product design, featuring industry-leading productivity tools that promote best practices in design while ensuring compliance with your industry and company standards. Integrated, parametric, 3D CAD/CAM/CAE solutions allow you to design faster than ever, while maximizing innovation and quality to ultimately create exceptional products.
Powerful, parametric design capabilities allow superior product differentiation and manufacturability Fully integrated applications allow you to develop everything from concept to manufacturing within one application Automatic propagation of design changes to all downstream deliverables allows you to design with confidence.
Complete virtual simulation capabilities enable you to improve product performance and exceed product quality goals.
Automated generation of associative tooling design and manufacturing deliverables.
Features & Benefits
* Powerful, parametric design capabilities allow superior product differentiation and manufacturability
* Fully integrated applications allow you to develop everything from concept to manufacturing within one application
* Automatic propagation of design changes to all downstream deliverables allows you to design with confidence
* Complete virtual simulation capabilities enable you to improve product performance and exceed product quality goals
* Automated generation of associative tooling design and manufacturing deliverables
Install
1.) unpack the files
2.) burn or mount the image
3.) install
4.) Check Readme.txt into Shooters Dir
Homepage: PTC - Pro/ENGINEER - 3D Product Design - CAD Software - CAD System - PTC
Download from Hotfile
Download from Uploading
