Program Overview
-The computer program SteelWaterPipe has been developed to facilitate the design of fabricated steel pipe in accord with AWWA M11 (1989) or AISI Welded Steel Pipe Volume 3 (1996).
-The program has been written to run on Windows 95, Windows 98, Windows 2000, Windows XP, Vista and the latest versions of Windows NT operating systems.
-The Program consists of three main modules and nine secondary modules. The three main modules are primarily design modules. These modules are for Hydraulic Design of Pipe, Design of Above Ground Pipe Installations, and Design of Buried Pipes. The secondary modules have been arranged in nine modules of similar subject matter. They are used to analyze some special aspect of pipe design such as required size of weld, distance between expansion joints etc. Some secondary modules contain two or three subtopics to select from. The user selects the desired module from the Main Screen menu by clicking on the Toolbar Buttons or by selecting File Menu and then New Project Item and then clicking on the Icon of the module.
Main Modules
The program has three Main design and analysis Modules. These are:
1.) A module for Hydraulics design and analysis of pipes.
2.) A module for design and analysis of Above Ground Pipe
Installations.
3.) A module for design and analysis of Buried Pipes.
To start design or analysis, click on the desired Module Button on the Main Screen Tool Bar. Alternatively, on the Main Screen, select The File Menu, and then select New Project Menu Item. On the New Project Screen select the Main Modules Tab and click on the desired module Icon to open it. Enter the required input data in the Module Input Boxes, when finished click on the Calculate Button to see the results of the analysis.
Một số hình ảnh
Download tại đây
Pass: vinamain.com
Main Modules
Installations.
Một số hình ảnh
Download tại đây
Pass: vinamain.com
