vothanhtam19
General information, specifications, service specifications, torque specifications, sealant, special tools, generator assembly, glow plug, cooling fan, v belt and water pump, water hoses and pipes, thermostat, egr valve assembly, intake manifold, turbocharger assembly, exhaust manifold, injection pump assembly, injection pum gear, rocker cover, camshaft holder assembly and camshaft, injection nozzle, cylinder head and valve mechanism, vacuum pump, timing gear case, timing gear and balance shaft, oil pump, oil cooler and oil filter oil pan, oil stainer and oil jet, piston and connecting rod, drive plate, crank shaft and crank case, balance shaft bush. Special tools, tools illustration, number and usage. Generator removal steps: Wiring harness, adjusting bolt, v-belt, generator. Engine exploded view, part list and step by step removal guide, with complete instruction and illustration. THis document available to download in pdf format.
Download Now
[O-H] 2000 Mitsubishi Pajero Diesel Engine 4M41 Service Manual.txt 0909 bytes · Xem: 52
