Link download
http://www.mediafire.com/?mmrnwe1oyyn
Nitrous Oxide
How Nitrous Oxide Systems Work ..................................................................... 2
Chemical Properties...............................................................................................................................................2
Combustion ............................................................................................................................................................2
Detonation..............................................................................................................................................................2
Nitrous to Fuel Ratio ..............................................................................................................................................2
Cooling Effects .......................................................................................................................................................2
Plate Systems ........................................................................................................................................................3
Nozzle Systems .....................................................................................................................................................3
Average Power.......................................................................................................................................................3
So Why Not Pure Oxygen?....................................................................................................................................3
Camshafts For Nitrous .................................................................................... 5
Choosing a Camshaft.............................................................................................................................................5
Pumping Losses.....................................................................................................................................................5
Cutting Pumping Losses ........................................................................................................................................5
Camshaft Specifications ........................................................................................................................................5
Cylinder Head Modifications for Nitrous.............................................................. 6
Intake to Exhaust Flow Ratio .................................................................................................................................6
Intake Port Work ....................................................................................................................................................6
Exhaust Port Work .................................................................................................................................................6
Combustion Chamber Modifications .......................................................................................................................6
Rocker Arm Studs..................................................................................................................................................6
Nitrous Oxide
