Nissan Patrol đời 2002 std nổi đèn báo lỗi hộp số A/T check
12TuongAnh
Bình luận: 26Lượt xem: 2,318
phamvanhieu280894
P1772 NISSAN - Low Coast Brake Solenoid Valve
Possible causes
Faulty Low Coast Brake Solenoid Valve
Low Coast Brake Solenoid Valve harness is open or shorted
Low Coast Brake Solenoid Valve circuit poor electrical connection
P1772 Nissan Description
Low coast brake solenoid valve is turned “ON” or “OFF” by the Transmission Control Module (TCM) in response to signals sent from the PNP switch, vehicle speed sensor and accelerator pedal position sensor (throttle position sensor). Gears will then be shifted to the optimum position.
phamvanhieu280894
U1000 NISSAN - CAN Communication Line - Signal Malfunction
Possible causes
- Controller Area Network (CAN) communication harness is open or shorted
- Faulty Engine Control Module (ECM)
- Poor harness ground connection.
When is the code detected?
When ECM is not transmitting or receiving CAN communication signal of OBD (emission related diagnosis) for 2 seconds or more.
U1000 Nissan Description
CAN (Controller Area Network) is a serial communication line for real time application. It is an on-vehicle multiplex communication line with high data communication speed and excellent error detection ability. Many electronic control units are equipped onto a vehicle, and each control unit shares information and links with other control units during operation (not independent). In CAN communication, control units are connected with 2 communication lines (CAN H line, CAN L line) allowing a high rate of information transmission with less wiring. Each control unit transmits/receives data but selectively reads required data only.
phamvanhieu280894
các anh chỉ dùm cho em vụ này với hic; E gặp con xe nissan patrol đời 2002 std nổi đèn báo lỗi hộp số A/T check. Hộp số lúc chuyển lúc không. máy báo lỗi p1772 và u1000. có anh nào gặp vụ này rồi chỉ dùm cho e với.
Em không phải thợ máy nên dịch sợ không đúng cứ copy tiếng anh cho cụ dịch chính xác
phamvanhieu280894
Em tạm dịch lỗi P1172 có thể do Van solenoi mở ít hoặc bị kẹt hay bị hư hỏng về hệ thống điện.
Mô tả hoạt động của van : Van được điều khiển đóng mở bởi hộp TCM nhờ các tín hiệu từ công tắc PNP, tốc độ xe, vị trí bàn đạp ga
ga_auto37
thế bác đã kiêm tra diện trở các van diện từ và kiểm tra chạm mát các van cũng như các dường dây diện lai van chưa
