vothanhtam19
đây là phần mềm đa dòng đi kèm với mấy máy chuẩn đoán của hãng scantool .
các bác cài đặt và sử dụng có vấn đề gì cứ pm chúng ta cùng thảo luận.
MyScanTool ProScan v5.9
MyScanTool ProScan v5.9 | 26.6 MB
MyScanTool ProScan is a combination of software and hardware, which convert any modern laptop or PC into a powerful, easy to use, OBD-II scanner for all vehicles not older than 1996.The Vehicle Connection Manager is what appears when you first launch ProScan. To connect to a vehicle, simply select the appropriate vehicle profile from the drop-down list and click the "Connect" button. A checklist alerts you of the connection process, and if any problems occur, a detailed troubleshooting dialog will appear and provide helpful information for correcting the problem.
Freeze Frame Data :
The new Freeze Frame tool allows you to read any freeze frame data stored on your vehicle. Freeze frame data represent a snapshot of critical sensors at the time of a detected problem (thrown diagnostic trouble code). Now you'll be able to know how your vehicle was being driven when the trouble code was thrown!
Oxygen Sensor Tests :
The new Oxygen Sensor tool allows you to view tests that your vehicle performs on each individual oxygen sensor. If you're having problems, this tool will allow you determine if your oxygen sensors are to blame, and if so, which one!
Diagnostic Report Generator :
With ProScan, you can generate a comprehensive diagnostic report for a vehicle with a single mouse click! You can provide your company information along with your client's details, and ProScan will quickly generate a printable and professional report for your client!
RapidShare:
rapidshare.com MyScanTool_ProScan_5.9.rar
HotFile:
hotfile.com MST.PS.v5.9.rar
Another HotFile:
hotfile.com MyScanTool_ProScan_5.9.rar
DepositFiles:
depositfiles.com /en/files/tz73dw9c1
SHaringMatrix:
http://sharingmatrix.com/file/6023403/MST.PS.v5.9.rar
Freeze Frame Data :
RapidShare:
HotFile:
Another HotFile:
DepositFiles:
SHaringMatrix:
