Mitsubishi Lancer Evolution 8 Electrical Manual
V
Bình luận: 2Lượt xem: 1,600
vothanhtam19
This manual presents the electrical wiring and vehicle connector components in 3-dimensional format. It also contains circuit diagrams which describe the various types of wiring for each system, as well as information on individual component installations. Please refer to the information contained in this manual before carrying out inspection of or repair to any of the electrical equipment. Overview of circuit diagrams: Constitution and contents of circuit diagrams, Overview of harness configuration diagrams, Overview of circuit diagrams, Marking for connectors and earths, Wire colour codes, Abbreviation symbols. Harness configuration diagram:Overall harness configuration diagram, Engine compartment, Engine and transmission, Instrument panel, Floor and roof, Door, Luggage compartment. Component Installation positions: ECU, Fusible links, fuses, Sensors, Relays, Solenoid valves, Inspection connectors, spare connectors, Earth cables, Earths. Circuits Diagram: Centralised Junctions, Power Distribution, Starting System, Ignition System, Charging System, Engine Control System, Cooling System, Lighting, Signals, Meters, Door opening/closing control, Air conditioning, Field of Vision, Accessories.
