Mio 125 2010 hàng thái !
O
Bình luận: 1Lượt xem: 6,813
oto@
haui
thông số kỹ thuật tham khảo :
Engine. Form. 4-stroke SOHC 2 valves with water cooling.
Volumetric cylinder. 124 cc.
Compression ratio is. 10.90: 1.
Cylinder x term seizure. 52.4 x 57.9 mm
Lubrication system. Wet.
Carburetor. MIKUNI BS26 x 1.
Ignition system. DC - CD-i. (Digital).
C direction, the stone. C LEDs Alliance retreat center dry centrifugal type automatic.
System restart. Mobile with electric start. And start the foot.
Fuel. Octane gasoline. Or gas Gasohol 91 or more.
Fuel capacity. 4.2 liters.
Oil capacity. 0.8 liters.
Transmission drive. Rockwell Automation unit for a belt, a V (V-Belt).
Rate of reduction gears. 2.540 to 0.838: 1.
Ratio. 2.625 / 3.750.
Air filter. Paper (wet).
Maxspeed aproximate - 120kph.
Colors - Pink & White, Blue & White, Yellow & Blue, Red & White, Green & Black.
