MasterCam X6 Bản Chính Thức (32Bit/64Bit)
Bình luận: 2Lượt xem: 4,627
bmt-hui
Những điểm mới trong được bổ sung trong bản X6 :
Tăng cường thêm khả năng về Design :
- Stock Model
- 64-bit Support
- New tool database/manager
- Solid trim to surface
- Solid edges intersection and trimming
- Trim/Divide support for splines
- All and Only Mask arc sweep
- Quick Mask group option
- xform rotate min angle
- Active report updates
Mill 2D :
- Stock Model
- 2D HST by Depth and Pocket
- Bull nose support
- New chaining
- 2D HST Blend Mill compensation
- Zigzag for Dynamic milling toolpaths
- 2D Contour Smoothing
- 2D HST Peel Mill adjust start/end
- 2D HST Dynamic milling variable radius
- 2D HST Dynamic milling approach from outside control (lead in/out control)
- 2D HST Dynamic milling open toolpath
Mill 3D :
- Stock Model
- OptiRest toolpaths
- Hybrid Finish filler passes
- OptiRough now two toolpaths, OptiCore and OptiArea
- Mill toolpath drop-down menu reorganization
Lathe :
- Face optional finish feed/speed
- Face corner break
- Canned groove optional Finish feed/speed
- Variable depth roughing
- Finish down-cutting strategy
- Groove rough optional retract feed on first plunge
- Groove finish option to remove undercuts
- Finish tool inspection
- Rough remaining stock, including pinch turn
- MT Misc Ops
Wire :
- Power Library Manager for Tech Libraries
- New autosync
Multiaxis :
- 5-axis Stock Model toolpath trimming
- Support for tapered tools
- Blade Expert
- Port Expert Enhancements
Giao diện của MasterCam X6 :
Update (28/11/2011)
Hiện tại trên trang chủ đã mở Server và cho Download Source cài đặt MasterCam X6 bình thường Bạn nào muốn khám phá sức mạnh hoặc những tính năng mới trong MasterCam X6 thì có thể download ở đây :
Source 32Bit : http://updates.mastercam.com/X6/release/mastercamx6-x86-web.exe
Cr@ck 32Bit : http://www.mediafire.com/?giy89uf1oo0fxw6 (Update)
Source 64Bit : http://updates.mastercam.com/X6/release/mastercamx6-x64-web.exe
Cr@ck 64Bit : http://www.mediafire.com/?g71f901u600fizb (Update)
Hoặc có thể download link mediafire ở đây :
Source 32Bit : http://www.mediafire.com/?3r9y5w6bdvpz3
Source 64Bit : http://www.mediafire.com/?4m7q7tjt7ttn7
Pass mediafire : nguyenthanh2309
Và tải thêm các Add-on cũng như What’s New của MasterCam X6 ở đây :
http://www.mastercam.com/Support/Downloads/MastercamX6/Default.aspx
