Service/overhaul manual of Mitsubishi 4M40 engine. This diesel engine is propelling Pajero, Delica, Challenger, Mitsubishi L200, and available in Turbo and Non Turbo engine options.
Download Here: Cuốn 1
[HIDE]http://www.mediafire.com/?vnxkuk9nae4dix2
[/HIDE]
Overhaul manual of Mitsubishi Engine 4M41, a standard engine of some variants of Mitsubishi cars, e.g. Mitsubishi Triton, Mitsubishi Delica, Mitsubishi Shogun.
Contents:
* Specification
* Special Tools
* Generator Assy
* Glow Plug
* Cooling Fan, V-Belt and Water Pump
* Thermostat
* Water Hoses and Pipes
* Coolant Temperature Sensor
* EGR Valve Assy
* Intake Manifold
* Turbocharger Assembly
* Exhaust Manifold
* Injection Pump Assy
* Injection Pump Gear
* Rocker Cover, Camshaft Holder Assembly and camshaft
* Injection Nozzle
* Cyl Head and Valve Mechanism
* Vacuum Pump
* Timing Gear Case
* Timing Gear and Balance Shaft
* Oil Pump
* Oil Cooler and Oil Filter
* Oil Pan, Oil Strainer and Oil Jet
* Piston and Connecting Rod Assy
* Piston and Piston Pin
* Flywheel
* Drive Plate
* Crankshaft and Crankcase
* Balance Shaft Bush
Link Download cuốn 2
[HIDE]http://www.mediafire.com/?7f3cpcddxodjov4[/HIDE]
[/HIDE]
Contents:
* Specification
* Special Tools
* Generator Assy
* Glow Plug
* Thermostat
* EGR Valve Assy
* Intake Manifold
* Exhaust Manifold
* Injection Nozzle
* Vacuum Pump
* Timing Gear Case
* Oil Pump
* Flywheel
* Drive Plate
