Manual for Nissan Rogue
S
Bình luận: 0Lượt xem: 1,175
Sklad1000
Hello!
Repair and maintenance Nissan Rogue
The "L” terminal circuit controls the charge warning lamp. The charge warning lamp illuminates when the ignition switch is set to ON or START. When the alternator is providing sufficient voltage with the engine running, the charge warning lamp will go off. If the charge warning lamp illuminates with the engine running, a malfunction is indicated.
Diagnosis Procedure
1.CHECK "L” TERMINAL CIRCUIT (SHORT)
INFOID.0000000004233785
1. Turn ignition switch OFF.
2. Disconnect alternator connector.
3. Turn ignition switch ON.
