Mạch điện xe nâng điện thấp
Bình luận: 2Lượt xem: 2,983
tranvanthua
SƠ ĐỒ MẠCH ĐIỆN XE NÂNG 1230 - 2402 Curtis Motor Controler
1/ Các dòng xe sử dụng:
- Xe nâng Eoslift
- Xe nâng Noveltek
- Xe nâng Toyota
- Xe nâng Nichiyu
- Xe nâng Maditek
- Xe nâng Niuli
Còn nhiều loại xe khác
Sơ đồ mạch điện
http://www.xenang.biz/2015/11/so-do-mach-dien-xe-nang-eoslift-ac-1230-2402-curtis.html
Hình ảnh board
pecifications:
Operating voltage range: 16 to 32 V
Nominal input voltage: 24 V
PWM operating frequency: 16 kHz
Electrical isolation to heatsink: 500 V ac (minimum)
KSI input current (no contactors engaged): 90 mA without programmer or speed encoder; 170 mA with programmer and SKF speed encoder
Logic input voltage: >7.5 V High; <1 V Low
Logic input current: 10 mA (nominal)
Nominal output line-to-line voltage (rms): 15 V
Max. output frequency: >200 Hz
Operating ambient temp. range: -40°C to 50°C (-40°F to 122°F)
Storage ambient temperature range: -40°C to 85°C (-40°F to 185°F)
MOSFET overtemperature cutback: linear cutback starts at 100°C (212°F); complete cutoff at 110°C (230°F)
MOSFET undertemperature cutback: approx. 50% motor current at -25°C (-13°F); complete cutoff at -40°C (-40°F)
Package environmental rating: IP53
Weight: 1.1 kg
Dimensions : 164 × 146 × 56 mm
Facebook: xe nâng hàng , xe nâng điện hàng đầu Việt Nam
