lỗi khi cài đặt solidwork
C
Bình luận: 3Lượt xem: 6,458
Ctrl+C
Giúp em với sau khi em cài SW xong khi chạy trương trình thì nó báo "SldWork has encountered a problem and needs to close.We are sorry for the inconvenience." và "If you were in the middle of something,the infommation you were working on might be lost." Ấn vào close thì nó out ra ngoài là sao vậy
C
congnghiep4
Khách
loi cài solidworks 2009
khi mình download bản cài solid2009 nhưng khi cài với máy ở nhà nó lại báo lỗi như sau:
I already have all installation; don't download any. Click Browse to chose a location.
xin chỉ giúp
otohui
bạn tham khảo cái này
cài thêm dot net frame 3.0, 3.5
Hey... I had the same problem until I read this on a tech support website:http://www.javelin-tech.com/main/sup...s_2009_faq.htm
‘SolidWorks Explorer has encountered an error’ is displayed while trying to start SolidWorks Explorer 2009.
This is a typical symptom of not having the .NET FrameWork 3.0 application installed on the PC running SolidWorks Explorer 2009. This is required for SolidWorks Explorer and SolidWorks 2009 to run. The .NET redistributable packages are included with the DVD or download. Browse the source of the installation (DVD, download folder, or Administrative Image). Go to the <source location>\<swwi>\data\DotNetFX and double click on dotnetfx3.exe for WinXP x32 and dotnetfx3_64.exe for WinXP x64. Once this is installed, run a repair of the SolidWorks Explorer Installation.
First, I had to download the .NET Uninstaller here:
http://www.microsoft.com/downloads/d...displaylang=en
Then I went to get the latest Windows .NET framework at windows website:
http://www.microsoft.com/downloads/d...9-81da479ab0d7
PROBLEMS SOLVED. I was happy and hope you can be too. Good luck!
