List mã lỗi Toyota được cập nhật năm 2012
tinhnguyen3688
Khách
File: PDF
Pass: tinhnguyen
C0200 TOYOTA Right Front Wheel Speed Sensor Signal Malfunction
C0205 TOYOTA Left Front Wheel Speed Sensor Signal Malfunction
C0210 TOYOTA Right Rear Wheel Speed Sensor Signal Malfunction
C0215 TOYOTA Left Rear Wheel Speed Sensor Signal Malfunction
C0226 TOYOTA SFR Solenoid Circuit
C0236 TOYOTA SFL Solenoid Circuit
C0246 TOYOTA SRR Solenoid Circuit
C0256 TOYOTA SRL Solenoid Circuit
C0273 TOYOTA Open or Short Circuit in ABS Motor Relay Circuit
C0274 TOYOTA Short to B+ in ABS Motor Relay Circuit
C0278 TOYOTA Open or Short Circuit in ABS Solenoid Relay Circuit
C0279 TOYOTA Short to B+ in ABS Solenoid Relay Circuit
C1235 TOYOTA Foreign Object is Attached on Tip of Front Speed Sensor RH
C1236 TOYOTA Foreign Object is Attached on Tip of Front Speed Sensor LH
C1238 TOYOTA Foreign Object is Attached on Tip of Rear Speed Sensor RH
C1239 TOYOTA Foreign Object is Attached on Tip of Rear Speed Sensor LH
C1241 TOYOTA Low Battery Positive Voltage
P1340 TOYOTA Igniter Circuit Fault Bank No. 8
P1349 TOYOTA Variable Valve Timing System Malfunction Bank 1
P1400 TOYOTA Sub-Throttle Position Sensor Circuit Fault
P1401 TOYOTA Sub-Throttle Position Sensor Range/Performance Problem
P1410 1997 TOYOTA AVALON EGR Valve Position Sensor Circuit Malfunction
P1410 1998 TOYOTA AVALON EGR Valve Position Sensor Circuit Malfunction
P1410 TOYOTA EGR Valve Position Sensor Circuit Malfunction
P1500 TOYOTA Starter Signal Circuit Fault
P1510 TOYOTA Air Volume Too Low With Supercharger On
P1520 TOYOTA Stop Light Switch Signal Malfunction
P1600 TOYOTA ECM Battery Back-up Circuit Fault
P1605 TOYOTA Knock Control CPU Fault
P1630 TOYOTA Communication Error Between From ECM To VSC
P1631 TOYOTA Communication Error Between From ECM To VSC
P1633 TOYOTA ECM Malfunction ETCS Circuit
P1700 TOYOTA Vehicle Speed Sensor Circuit Fault
P1705 TOYOTA Direct Clutch Speed Sensor Circuit Fault
Tất cả 7 trang
