Cái này áp dụng giải mã chìa khóa cho xe Toyota Yaris bằng phương pháp thủ công nhé.
I. REMOTE ALARM/CENTRAL LOKING:
System operation
• If vehicle unlocked and doors or boot/tailgate not opened within 30 seconds,locks/alarm are reactivated.
Programming
When
• Key added or replaced.
• System malfunction.
How
• Driver’s door open and key removed from ignition switch.
• Insert key into ignition switch,then remove it.
• Within 40 seconds:close and open driver’s door twice.
• Close driver’s door.
• Switch ignition ON and OFF once to program an new key code whilst retaining the original codes or tice to program a new key code whilst erasing the original codes.
• Remove key.
• System should now lock and unlock vehicle,once or twicw depending which mode has been selected.
• Carry out the following button procedure within 20 seconds.
• Yaris built in Japan and Yaris Verso:Simultaneously press and hold key lock and unlock button for 1-1.5 seconds.
• Within 3 seconds:
• Press key lock button for a minimum of 1 second and release.
• System should now lock and unlock vehicle.
NOTE:If system locks and unlocks vehicle twice,programming procedure has not been completed.Repeat button procedure.
• If required repeat button procedure to program remaining keys.
NOTE:To exit programming mode:Open driver’s door.
II. BATTERY REPLACEMENT:
III.IMMOBILIZER:
System operation
• Arms after switching ignition OFF.
Programming
When
How – black key
• Obtain 1 programmed black key.
• Insert programmed black key into ignition switch.
• Within 15 seconds: Press and release accelerator pedal 5 times.
• Within 20 seconds:
• Press an release brake pedal 6 times.
• Remove black key.
• Within 10 seconds:Insert black key to be programmed into ignition switch.
• Within 10 seconds
ress and release accelerator pedal once.
• Immobilizer warning lamp will flash.
• After 1 minute immobilizer warning lamp will extinguish
NOTE:A maximum of 7 black keys can be programmed.NOTE:To exit programming mode:Remove inginition key and press brake pedal at least once within 10 seconds,or wait 10 seconds.
How-grey key
NOTE:Grey key will not operate boot/tailgate lock.
• Within 15 seconds
ress and release accelerator pedal 4 times.
• Press and release brake pedal 5 times.
• Remove black key.
• Within 10 seconds:Insert greykey to be programmed into ignition switch.
• Within 10 seconds
• Immobilizer warning lamp will flash for 1 minute and then extinguish.
NOTE:A maximum of 3 grey keys can be programmed.NOTE:To exit programming mode:Remove ignition key and press brake pedal at least once within 10 seconds,or wait 10 secondes.
Mình đang translate có gì sẽ post sau,thank phát nếu thấy hay nhé
System operation
Programming
When
How
• Remove key.
• Within 3 seconds:
III.IMMOBILIZER:
System operation
Programming
When
How – black key
• Remove black key.
• Within 10 seconds
How-grey key
• Within 15 seconds
• Remove black key.
• Within 10 seconds
