ĐỘNG CƠ
CỤM ĐẦU XI LANH................................................................1
TRỤC KHUỶU........................................................................2
XU PÁP...................................................................................3
TRỤC CAM, XÍCH CAM.........................................................4
BƠM DẦU...............................................................................5
BẦU LỌC GIÓ........................................................................6
CHẾ HOÀ KHÍ........................................................................7
ỐNG XẢ..................................................................................9
VỎ HỘP SỐ............................................................................11
VỎ MÁY..................................................................................12
CẦN KHỞI ĐỘNG..................................................................14
LI HỢP KHỞI ĐỘNG..............................................................15
LI HỢP CÔN TẢI....................................................................16
HỘP SỐ..................................................................................18
BỘ CHUYẾN SỐ....................................................................19
CẦN SỐ..................................................................................20
THÂN XE
KHUNG XE.............................................................................21
CHẮN BÙN.............................................................................22
ỐP CẠNH...............................................................................24
CÀNG SAU.............................................................................27
CỤM CÀNG TRƯỚC..............................................................28
CỤM GIẢM XÓC TRƯỚC CHO XE PHANH CƠ...................32
CỤM GIẢM XÓC TRƯỚC CHO XE PHANH ĐĨA...................34
BÌNH XĂNG............................................................................36
YÊN XE...................................................................................37
BÁNH TRƯỚC PHANH CƠ...................................................38
BÁNH TRƯỚC PHANH ĐĨA...................................................40
BÁNH TRƯỚC VÀNH ĐÚC....................................................41
PHANH DẦU...........................................................................42
BÁNH SAU NAN HOA............................................................43
BÁNH SAU VÀNH ĐÚC..........................................................45
CỤM ỐP ĐẦU.........................................................................47
XI LANH PHANH ĐĨA TRƯỚC...............................................49
ĐỂ CHÂN................................................................................50
CỤM ỐP SƯỜN.....................................................................55
MÁY PHÁT ĐIỆN....................................................................61
ĐỒNG HỒ CÔNG TƠ MÉT....................................................63
ĐÈN PHA................................................................................65
ĐÈN HẬU................................................................................66
CÔNG TẮC TAY PHANH.......................................................67
HỆ THỐNG ĐIỆN 1................................................................68
HỆ THỐNG ĐIỆN 2................................................................69
CHỈ DẪN
CHỈ DẪN.................................................................................70
ENGINE
CYLINDER HEAD...................................................................1
CRANKSHAFT & PISTON......................................................2
VALVE....................................................................................3
CAMSHAFT & CHAIN............................................................4
OIL PUMP...............................................................................5
INTAKE...................................................................................6
CARBURETOR.......................................................................7
EXHAUST...............................................................................9
CRANKCASE.........................................................................11
CRANKCASE COVER 1.........................................................12
STARTER...............................................................................14
STARTER CLUTCH...............................................................15
CLUTCH.................................................................................16
TRANSMISSION....................................................................18
SHIFT CAM & FORK..............................................................19
SHIFT SHAFT.........................................................................20
CHASSIS
FRAME...................................................................................21
FENDER.................................................................................22
SIDE COVER..........................................................................24
REAR ARM & SUSPENSION.................................................27
STEERING.............................................................................28
FRONT FORK FOR DRUM BRAKE.......................................32
FRONT FORK FOR DISK BRAKE.........................................34
FUEL TANK............................................................................36
SEAT......................................................................................37
FRONT WHEEL FOR DRUM BRAKE....................................38
FRONT WHEEL FOR DISK BRAKE......................................40
FRONT WHEEL FOR CAST WHEEL.....................................41
FRONT BRAKE CALIPER......................................................42
REAR WHEEL FOR SPOKE WHEEL....................................43
REAR WHEEL FOR CAST WHEEL.......................................45
STEERING HANDLE & CABLE..............................................47
FRONT MASTER CYLINDER................................................49
STAND & FOOTREST............................................................50
LEG SHIELD...........................................................................55
GENERATOR.........................................................................61
METER...................................................................................63
HEADLIGHT...........................................................................65
TAILLIGHT..............................................................................66
HANDLE SWITCH & LEVER..................................................67
ELECTRICAL 1.......................................................................68
ELECTRICAL 2.......................................................................69
INDEX
NUMERICAL INDEX...............................................................70
Link download tài liệu:
[HIDE]http://www.mediafire.com/?mmikmtqnz5dziom[/HIDE]
THÂN XE
CHỈ DẪN
ENGINE
CHASSIS
INDEX
