Year: 2012
Language: Multilingual
CD1: For Bus
CD 2: Truck
No need to install Keygen January or February 2012
Do not forget to give thanks, greetings to all
INSTALLATION Iveco
Caution must be installed IE
1. Assemble Iveco (Power2012.iso). We take this hand.
2. Cdi.exe Run -> Yes -> Forward -> wait ->
installation directory such as C: \. Auto \ Iveco -> Forward -> I agree -> I agree -> I agree - wait> long
Forward -> I Agree -> I agree -> I agree -> Long wait -> Ok -.> Bye
3. Run the installation Iveco. In the window - in the upper right corner to change port 9090 -.> Ok
Contacted 2 times Allow firewall access.
4. Install SQLyog
Set - Select language -> OK -> Next ->
put points on the accept ... -> Next -> Next -> Install -> Next -> Finish
5. When executed - Select language -> OK -> Continue ... -> New ... - Ok> -> Connection -> Yes
6. Select File - New Connection - Connect
Then in the right column wherein said insertion query is:
IVECO USE;
UPDATE `SET` = '2033 dati_cd_pubblicati DT_PUBBLICAZ-06-05 00:00:00 'WHERE 1;
Utenti UPDATE `SET` `` = '2033 DT_TERMINE_ABIL-06-05 00:00:00 ',' LANGUAGE_CODE `= '3 'WHERE 1,
Press [Ctrl] [F9]. Close SQLyog -> No -> Continue ...
Basically SQLyog Community Edition can now be removed.
7. Then click the icon cdi (which seems a step in the number 9)
Left-Ed DVD TRUCK 2012/1.
8.Reboot
I hope they work
Do not forget ... THANKS costs nothing
CD1: For Bus
CD 2: Truck
INSTALLATION Iveco
4. Install SQLyog
IVECO USE;
8.Reboot
I hope they work
