Honda Accord 1985 - 2005 Wiring Diagram
J
Bình luận: 0Lượt xem: 3,494
javaro_2405
1985-2005 Honda Accord wiring diagram document that will guide you to understand the wiring, wiring color and wire location. Divided into 20 tables for each years 1985-2005. Here’s the sample of wiring information: Ignition -> wire color Black/yellow -> wire location ignition harness. you can find the wiring of these following parts easily: Starter, ignition, accessory, power lock door, power door unlock, door trigger, brake wire, horn trigger, left front window up/down and many more.
