Handbook of Shaft Alignment
khoadongluc
Bình luận: 0Lượt xem: 1,631
khoadongluc
Nothing Is Impossible
1/ Introduction to Shaft Alignment
2/ Detecting Misalignment on Rotating Machinery
3/ Foundations, Baseplates, Installation and Piping Strain
4/ Flexible and Rigid Couplings
5/ Preliminary Alignment Checks
6/ Shaft Alignment Measuring Tools
7/ Correcting Misalignment
8/ Alignment Modeling Basics
9/ Defining Misalignment: Alignment and Coupling Tolerances
10/ Reverse Indicator Method
11/ Face and Rim Methods
12/ Double Radial Method
13/ Shaft to Coupling Spool Method
14/ Face-Face Method
15/ Electronic and Electro-Optical Shaft Alignment Systems
16/ Measuring and Compensating for Off-Line to Running Machinery Movement
17/ Aligning Multiple-Element Drive Systems
18/ Aligning V-Belt Drives
19/ Bore Alignment
20/ Parallel Alignment
21/ Alignment Considerations for Specifics Types of Machinery
22/ The History of Machinery Alignment
http://www.mediafire.com/?dmzz2eyoiwt
