Giúp em xử lý lỗi khi cài đặt Mastercam
Bình luận: 2Lượt xem: 16,063
maivanson_haui
Em cài MasterCamX4 đẫ crackkk thành công thì bị lỗi như hình sau. Ai giúp em xử lý với. Hic
Thank for all !!!
truongn
Khách
Dowload Crack Mastercam X4
Lam theo :
1) Install Mastercam X4, select Sim Type > NetHASP
2) Run "mastercam_x4_nethasp_crk.exe",extract to browse to C:<mastercam X4 or progdir\mastercam.exe> click Start > OK
3) If you have got Mastercam X3 installed as Sim Type > HASP you need to delete old dump from Windows Registry!
Delete Registry Entry
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\NEWHASP\Services\Emulator\HASP\Dump\584B4AE9]
4) Run "mastercam-dealer-unlim.reg"
5) you need to install it."USB-Emul Win32 Setup" or "USB-Emul Win64 Setup" next
6 ICON SHORTCUT MASTERCAM, RIGHT MOUSE PROPETIES-FIND TARGET TO Nhaspx select Sim :Nethasp and mode :Local
click: READ-OK-EXIT
7 MUST RESTART COMPUTER if still not Activa
8.Run nethasp_crack in forder mastercam in c:
9.copy mcamx4_fix extrac past vao c:mastercam
8. MASTERCAM WILL BE ACTIVE
That's all.. Enjoy :)
__________________________________________________________________
1) Open folder "USB-Emul_Win32" and run "install.bat"
2) Wait until system will find and install new devices
You need a local Administrator rights to install this emulator for Win64!
1) Start -> Control Panel -> Add Hardware (Yes, I have already connected the hardware) -> Add a new hardware device -> Install the hardware that I manually select from a list -> Show all Devices -> Have disk -> Browse -> (browse to folder "USB-Emul_Win64")
Confirm to install not certificated drivers if Windows ask for..
2) If setup is succesfull you have to see new system device
Device Manager -> System devices -> Virtual Usb Bus Enumerator
3) Reboot!!!
Các bác làm như sau nhé:
- Đầu tiên làm theo file hướng dẫn " .txt", sau đó copy file "mastercam.exe" vào trong thư mục cài đặt. (Nếu chạy thì nó sẽ báo lỗi "No sim found")
- Sau đó vào thư mục cài đặt chạy file "Nhasp.exe" và lựa chọn theo hình dưới đây -> sau đó chọn Ok để kết thúc.
Lưu ý: Trước đó phải vào regedit xóa ... và chạy lại file .reg trong thư mục Cr -> xem lại có nội dung như sau:
Như vậy là có thể chạy được MC X4 rồi đó!!
maivanson_haui
đâu cần như thế đâu anh. Em đã cài và dùng được MasterCamX4.
Ai có khó khăn gì về cài đặt MasterCamX4 thì chụp hình up lên em giúp co.
Goodluck to all !!!
