Fuel system
quang duy nang
Bình luận: 2Lượt xem: 1,134
quang duy nang
GENERAL
SPECIFICATIONS
Fuel tank
Capacity
Fuel filter
Type
Fuel pump
Type
Driven by
Throttle body
Throttle position sensor (TPS)
Type
Resistance
Output voltage at curb idle
Idle speed control (ISC) servo motor
Type
Resistance
Idle position switch
Type
Motor position sensor (MPS)
Type
Resistance
Input sensor
Air flow sensor (AFS)
Type
Intake air temperature sensor
Type
Resistance
Coolant temperature sensor
Type
Resistance
Oxygen sensor
Type
Vehicle speed sensor
Type
45 lit. (11.9 U.S. gal., 9.9 lmp.gal.)
High pressure type
Electrical, in-tank type
Electric motor
Variable resistor type
3.5-6.5 KD
0.48-0.52 V
Electric motor
5-35 fl at 20°C (68°F)
Contact type within ISC servo
Approx. 4-6 Kn
Karman vortex type
Thermistor type
2.33-2.97 Kn at 20°C (68°F)
Thermistor type
2.5 Kfi at 20°C (68°F)
0.3 Kfi at 80°C (176°F)
Zirconia sensor
Reed switch type
3 1 - 2
GENERAL
No. 1 cylinder TDC sensor
Type
Crankshaft angle sensor
Type
Output actuator
Injector
Type
Number
Coil resistance
Purge control solenoid valve
Type
EGR control solenoid valve [California Only]
Type
Fuel pressure regulator
Regulated pressure
Photo diode sensor
Photo diode sensor
Electromagnetic type
4
13-16 R at 20°C (68°F)
ON/OFF type
Duty cycle type solenoid valve
330 kPa (3.35 kg/cm2, 48 psi)
SEALANT
Water temperature sensor ass’y LOCTITE 962T or equivalent
3 1 - 3
SERVICE STANDARD
Basic ignition timing
Curb idle speed
Throttle-position sensor (TPS) adjustment voltage
BTDC 5° ± 2° at curb idle
700 ± 100 rpm
0.48-0.52V at curb idle
TIGHTENING TORQUE Nm Kg.cm lb.ft
Delivery pipe installation screw
Water temperature gauge unit
Oxygen sensor
Throttle position sensor (TPS) installation screw
Fuel pressure regulator lock nut
High pressure hose and fuel main pipe eye bolt
High pressure hose and fuel filter
Fuel pump assembly to fuel tank
High pressure hose at fuel tank
Throttle body to surge tank
Fuel tank drain plug
Fuel filter mounting bolt
Accelerator arm bracket bolts
1 0 - 1 3 100-130 7.2-9.4
2 0 - 3 9 200-400 1 5 - 2 9
1 0 - 1 2 100-120 7.2-8.7
3 8 - 4 9 400-500 2 9 - 3 6
1.5-2.5 1 5 - 2 5 1 . 1 - 2
7 - 1 1 7 0 - 1 1 0 5 - 8
2 9 - 3 9 300-400 2 2 - 2 9
2 5 - 3 4 250-350 1 8 - 2 5
2 - 3 2 0 - 3 0 1.5-2.2
1 5 - 2 5 150-250 1 1 - 1 8
9 - 1 4 9 0 - 1 4 0 6.5-10
8 - 1 2 8 0 - 1 2 0 5.8-8.7
3 1 - 4
GENERAL
SPECIAL TOOLS
3 1 - 5
TROUBLESHOOTING
When checking and correcting engine troubles, it is important
to start with an inspection of the basic systems. If one of the
following conditions exists, (A) engine start failure, (B) unstable
idling or (C) poor acceleration, begin ‘by checking the following
basic systems.
1. Power supply
1) Battery
2) Fusible link
3) Fuse
2. Body ground
3. Fuel supply
1) Fuel line
2) Fuel filter
3) Fuel pump
4. Ignition system
1) Spark plugs
2) High-tension cables
3) Distributor
4) Ignition coil
5. Emission control system
1) PCV system
2) EGR system
3) Vacuum leak
6. Others
1) Ignition timing
2) Idle speed
Troubles with the MPI system are often caused by poor
contact of the harness connectors. It is important to check
all harness connectors and verify that they are securely
connected.
3 1 - 6
GENERAL
MPI TROUBLESHOOTING PROCEDURES
PROBLEM
Engine will not start
o Battery
1. Connection
2. Specific gravity, charging system
3. Drive belt
4. Voltage
o Fusible link
o Ignition switch
o Starter relay
o Starter
o Wiring
Trouble codes
o Using voltmeter
[Refer to page 31-32]
o Using MUT
[Refer to page 31-35]
Oil filler cap
o Oil dipstic
o Vacuum hose connections
o PCV hose
o EGR system
o High tension cables
o Distributor
o Ignition coil, power transistor
o Spark plug
3 1 - 7
GENERAL
o Ignition timing-adjust
[Refer to page 27-5]
3 1 - 8
o Fuel line (leakage, deformation)
o Fuse
o Fuel pump [Refer to page 31-24]
o Fuel filter
o Fuel pressure regulator
o Wiring connections
o Power to ECU
1. Fusible links
2. Fuses
3. MPI control relay
o Engine coolant temperature
sensor
o Intake air temperature sensor
o Injection signal circuit
1. Injector wiring
2. ECU
o TPS
o AFS
GENERAL
PROBLEM
Rough idle or engine stalls
T r o u b l e C o d e s
[Refer to page 31--32]
o Using voltmeter
o Using MUT [Refer to page 31-35]
o Oil filler cap
o Oil dipstic
o PCV hose
o EGR system
o Fuses
o Fuel filter
Element-Clean or replace
Idle speed-Adjust
[Refer to page 31-20]
Ignition timing-Adjust
3 1 - 9
GENERAL
o Fuel pump [Refer to page 20-24]
o Fuel filter
o F u e l r e g u l a t o r
Injection condition
o Power to ECU
1. Fusible links
2. Fuses
sensor
1. Injector wiring
2. ECU
3 1 - 1 0
GENERAL
PROBLEM
Engine hesitates or accelerates poorly
o Clutch-slip
o Brake-drag
o Oil filler cap
o Oil dipstic
o Hose connections
o PCV hose
o EGR system
Trouble codes
o Using voltmeter
o Using MUT
o Distributor
o Ignition coil, ignition
o Fuel pump
o Fuel filter
3 1 - 1 1
3 1 - 1 2
GENERAL
Fuel Tank And Fuel Line
Symptom Probable cause
Engine malfunctions
due to insufficient fuel
supply
Bent or kinked fuel pipe or hose
Clogged fuel pipe or hose
Clogged fuel filter of in-tank fuel filter
Water in fuel filter
Dirty or rusted fuel tank interior
Malfunctioning fuel pump (Clogged filter
in the pump)
Evaporative emission
control system malfunctions
(when fuel filler
cap is removed, pressure
is released)
Incorrect routing of a vapor line
Disconnected vapor line
Folded, bent, cracked or clogged vapor line
Faulty fuel tank cap
Malfunctioning overfill limiter (Two-way
valve)
Remedy
Repair or replace
Clean or replace
Replace
Replace the fuel filter or clean the
fuel tank and fuel lines
Clean or replace
Replace
Correct
Correct
Replace
Replace
3 1 - 1 3
MPI SYSTEM
MPI SYSTEM
GENERAL INFORMATION
The basic function of the MPI (Multi-Point Injection) system is
to control the air-fuel ratio, based on data from various sensors.
The MPI system is composed of three basic systems: Fuel, Intake
and Electronic Control.
Fuel System
Fuel is supplied under constant pressure to the injectors by an
electric fuel pump in the fuel tank. The pressure is controlled
by the pressure regulator. Based on ECU signals, the injectors
inject fuel jnto the intake manifold in the correct firing order.
Intake System
The flow rate of the intake air is measured by the AFS (Air Flow
Sensor) in the air cleaner. The amount of intake air during idling,
warm-up and deceleration is controlled by the ISC (Idle Speed
Control) servo through the ECU.
Electronic Control System
The electronic control system is composed of sensors, which
monitor engine conditions, and the Electronic Control Unit (ECU),
which calculates the injection timing and air/fuel ratio according
to the signals from the sensors.
The sensors convert such conditions as the amount of intake air,
amount of oxygen in the exhaust gas, coolant temperature,
intake air temperature, engine speed, and vehicle speed into
electrical signals, which are sent to the ECU.
Analyzing these signals, the ECU determines the amount of fuel
to inject and drives the injectors. The fuel injection is sequential
injection type, in which four injectors are sequentially driven.
During idling, the ISC Servo is driven according to engine load
to assure stable idling.
3 1 - 1 4
MPI SYSTEM
LOCATION OF COMPONENTS
A. Air conditioner relay
B. Air flow sensor
C. ISC servo (Motor position sensor)
D. Throttle position sensor
E. Coolant temperature sensor
F. Power transistor
G. Crankshaft angle sensor
H. injector
I. Oxygen sensor
J. Inhibitor switch
K. MPI control relay
L. Diagnosis terminal
M. Vehicle speed sensor
N. Electronic control unit
O. EGR temperature sensor (California vehicles only)
P. Power steering oil pressure switch
Q. Purge control solenoid valve
R. EGR control solenoid valve
3 1 - 1 5
MPI SYSTEM
3 1 - 1 6
MPI SYSTEM
MPI SYSTEM
3 1 - 1 8
MPI SYSTEM
SERVICE ADJUSTMENT PROCEDURES
Idle Speed Check Procedure
CAUTION
The improper setting (throttle valve opening) will increase
exhaust gas temperature at deceleration, reducing catalyst life
greatly and deteriorating exhaust gas cleaning performance.
It also has effect on fuel consumption and engine braking.
Checking conditions:
o Engine coolant temperature is 80 to 95°C (176 to 205°F).
o Lights, electric cooling fan and all accessories are off.
o Transaxle is in neutral [“P” or “N” range for A/T vehicles].
o Steering wheel is a straight ahead position (Vehicles with
power steering).
1.
2.
3.
4.
5.
6.
Install the tachometer and the timing light, or connect the
multi-use tester to the diagnostic connector in the fuse box.
Run the engine at curb idle speed.
Check the basic ignition timing and adjust if necessary.
Refer to Group 27.
Run the engine for more than 5 seconds at an engine speed
of 2,000 to 3,000 rpm.
Run the engine at idle for 2 minutes.
Read the idling rpm. If the multi-use tester is used, press
code No.22 and read the idling rpm. If it is not within the
specified valve, check the idle speed control system.
Curb idle rpm . . . . . . . . . . . . . . . . . . . . . . . . . . . 700 ± 100 rpm
Idle Speed Control (ISC) And Throttle Position
Sensor (TPS) Adjustment
Adjustment conditions:
power steering).
1. Loosen the accelerator cable.
2. Connect the multi-use tester to the diagnostic connector in
the fuse box.
3. If the multi-use tester is not used, install a tachometer and
a voltmeter.
3 1 - 2 0
MPI SYSTEM
4. Turn the ignition switch to ON (do not start the engine) and
leave it in that position for 15 seconds or longer; then check
to be sure that the idle speed control servo is fully retracted
to the curb idle position.
NOTE
When the ignition switch is turned to ON, the ISC plunger
extends to the fast idle position opening; then, after 15
seconds, it retracts to the fully close (curb idle) position.
Motor position sensor : 0.9V
5. Turn the ignition switch OFF.
6. Disconnect the ISC motor connector and secure the ISC
motor at the fully retracted position.
7. In order to prevent the throttle valve from sticking, open it
two or three times; then release it to let it click shut, and
sufficiently loosen the fixed SAS.
8. Start the engine and let it run at idle speed.
9. Check that the engine rpms are within the standard value.
If the multi-use tester is used, press code No. 22 and read
engine rpms.
10. If the engine speed is not as specified, adjust the ISC
adjusting screw to obtain the standard rpm.
NOTE
1. The engine speed on a new vehicle driven less than
500 Km (300 miles) may be 20 to 100 rpm lower than
specification, but no adjustment is necessary.
2. If the engine stalls or the engine speed is low after the
vehicle has been driven a distance of 500 km (300
miles) or more, a deposit on the throttle valve area is
suspected. Clean the throttle valve area. [Refer to page
3 1 - 2 3 ]
11. Tighten the fixed SAS until the engine speed starts to
increase. Then, loosen it until the engine speed ceases to
drop (touch point) and then loosen a half turn from the touch
point.
12. Stop the engine.
3 1 - 2 1
MPI SYSTEM
13. Turn the ignition switch to ON (do not start engine) and
check that the TPS output voltage is as specified.
If the multi-use tester is used, press code No. 14 and read
the voltage.
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.48-0.52V
14. Connect a digital-type voltmeter between terminal 24 and
terminal 19 of the ECU, if the multi-use tester is not used.
NOTE
1. Do not disconnect the ECU connector from the ECU.
2. Use an accurate digital voltmeter.
15. If it is out of specification, loosen TPS mounting screws and
adjust by turning the TPS.
NOTE
Turning the TPS clockwise increases the output voltage.
CAUTION
Tighten the screws securely after adjustment.
16. Turn the ignition switch to the OFF position.
17. Adjust the accelerator cable play.
Standard value
A/T-4 . . . . . . . . . . . . . . . . . . . . . . . 3-5 mm (0.12-0.2 in.)
Except above.. . . . . . . . . . . . . . . 1-2 mm (0.04-0.08 in.)
18. Connect the ISC motor connector.
19. Disconnect the voltmeter, and connect the TPS connector.
20. Start the engine and check to be sure-that the idle speed
is correct.
21. Turn the ignition switch to OFF and disconnect the battery
terminal for 15 seconds and then re-connect. (This erases
the data stored in memory during the ISC adjustment).
3 1 - 2 2
MPI SYSTEM
Throttle Body (Throttle Valve Area) Cleaning
NOTE
Disconnect the air intake hose from the throttle body, and
check the throttle valve surface for carbon deposits, rotating
the valve. Apply the spray cleaning solvent on the valve to
remove carbon deposits.
1. Run the engine until warm.
2. Remove the air intake hose from the throttle body.
3. Spray cleaning solvent into the valve through the throttle
body intake port and leave it for about 5 minutes.
4. Start the engine, race it several times and let it idle for about
1 minute.
NOTE
If the idle speed becomes unstable (or if the engine stalls),
slightly open the throttle valve to keep the engine running.
5. Repeat steps 3 and 4.
6. Attach the air intake hose.
7. Disconnect the battery terminals and reconnect them more
than 10 seconds.
8. Adjust the idle speed control and throttle position sensor.
Fuel Filter Replacement
1. Reduce the internal pressure of the fuel pipes and hoses by
completing the following operations.
o Disconnect the fuel pump harness connector at the rear
of the fuel tank.
o Start the engine and after it stalls, turn the ignition
switch to OFF.
o Disconnect the battery negative (-) terminal.
o Connect the fuel pump harness connector.
2. Remove the eye bolts while holding the fuel filter nuts
securely.
CAUTION
Cover with a shop towel to avoid gasoline from splashing.
3. Remove the fuel filter mounting bolts, then remove the fuel
filter from the fuel filter clamp.
4. After replacing the fuel filter, check for fuel leaks.
MPI SYSTEM
Overfill Limiter (Two-way Valve) Replacement
1. Disconnect the vapor hoses and the overfill limiter.
Fuel Sender Replacement
1. Remove the fuel filler cap to lower the fuel tank’s internal
pressure.
2. Disconnect the harness connector from the fuel sender.
3. Remove the fuel sender unit installation screws, then
remove the fuel sender assembly from the fuel tank.
Fuel Pump Operation Check
1. Turn the ignition switch to OFF.
2. Apply battery voltage to the fuel pump drive connector to
check that the pump operates.
NOTE
The fuel pump is in-tank type and its operating sound is
hard to hear without removing the fuel filler cap.
3. Pinch the fuel hose to check that fuel pressure is felt.
3 1 - 2 4
MPI SYSTEM
Fuel Pressure Test
1.
2.
3.
4.
5.
6.
the following procedures.
1) Disconnect the fuel pump harness connector at the rear
of the fuel tank.
2) Start the engine and after it stalls, turn the ignition
switch to OFF.
3) Disconnect the battery negative (-) terminal.
4) Connect the fuel pump harness connector.
Remove the upper, eye bolt while holding the fuel filter nut
securely.
CAUTION
Cover the hose connection with a shop towel to prevent
splashing of fuel caused by residual pressure in the fuel
line.
Using the fuel pressure gauge adapter (09353-24000),
install the fuel-pressure gauge to the fuel filter. Tighten the
bolt to the specified torque.
Tightening torque
Fuel pressure gauge to fuel filter . . . . . . . . . . . . . . . . . . . . .
25-34 Nm (250-350 kg.cm, 18-25 lb.ft)
Connect the battery’s negative (-) terminal.
Apply battery voltage to the terminal for the pump drive and
activate the fuel pump; then, with fuel pressure applied,
check that there is no fuel leakage from the pressure gauge
or connection part.
Disconnect the vacuum hose from the pressure regulator,
and plug the hose end. Measure the fuel pressure at idle.
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
320-340 kPa (3.26-3.47 kg/cm2, 46-49 psi)
3 1 - 2 5
MPI SYSTEM
7. Measure the fuel pressure when the vacuum hose is
connected to the pressure regulator.
Approx. 270 kPa (2.75 kg/cm2, 39 psi)
8. If the results of the measurements made in steps (6) and
(7) are not within the standard value, use the table below
to determine the probable cause, and make the necessary
repairs.
Condition
Fuel pressure too low
Fuel pressure too high
There is no difference in
vacuum hose is connected
and when it is not.
Probable cause
a. Clogged fuel filter.
b. Fuel leakage to the return side, caused by
poor seating of the valve within the
fuel-pressure regulator
c. Low discharge pressure of the fuel pump
a. Sticking valve within the fuel-pressure
regulator
b. Clogged or bent fuel return hose or pipe.
a. Clogging, or damaged vacuum hose or the
nipple
b. Sticking or poor seating of the valve in the
fuel-pressure regulator.
9. Stop the engine and check for a change in the fuel pressure
gauge reading, which should hold for approximately 5 minutes.
If the gauge indication drops, observe the rate of drop.
Determine and remove the causes according to the following
table.
Remedy
a. Replace fuel filter
b. Replace fuel pressure regulator
c. Check the in-tank fuel hose for
leakage or replace the fuel pump
a. Replace fuel pressure regulator
b. Repair or replace hose or pipe.
a. Repair or replace the vacuum
hose or the nipple
Condition
Fuel pressure drops
slowly after engine is
stopped
Fuel pressure drops immediately
after engine is
stopped
Probable cause Remedy
a. Injector leakage a. Replace injector
a. The check valve within the fuel pump is a. Replace fuel pump
open
3 1 - 2 6
MPI SYSTEM
10. Reduce the fuel pressure in the fuel line.
11. Disconnect the high pressure hose and remove the fuel
pressure gauge from the delivery pipe.
CAUTION
line.
12. Install a new O-ring in the groove at the end of the
high-pressure hose.
13. Connect the high pressure fuel hose to the delivery pipe, and
tighten the screws to the specified torque.
14. Check for fuel leaks.
o Apply battery voltage to the fuel pump drive terminal to
operate the fuel pump.
o With pressure, check the fuel line for leaks.
EGR VALVE Control Vacuum Check
Checking Condition
Engine coolant temperature: 80-95°C (176-205°F)
1. Disconnect the vacuum hose from the throttle body EGR
vacuum fitting and connect a hand vacuum pump to the
fitting.
2. Start the engine and check to see that, after increasing the
engine speed, vacuum raises proportionately to engine
speed.
NOTE
If there is a problem with the change in vacuum, it is
possible that the throttle body port may be restricted and
require cleaning.
3 1 - 2 7
MPI SYSTEM
Purge Port Vacuum Check
Checking Condition
1. Disconnect the vacuum hose from the throttle body purge
hose fitting and connect a vacuum pump.
engine speed, vacuum remains fairly constant.
NOTE
If there is no vacuum created, it is possible that the
throttle body port may be restricted and require cleaning.
3 1 - 2 8
MPI SYSTEM
MPI SYSTEM INSPECTION
If the MPI system components (sensors, ECU, injector, etc.) fail,
interruption or failure to supply the proper amount of fuel for
engine operating conditions will result. Therefore, the following
situations will be encountered.
1. Engine is hard to start or does not start at all.
2. Unstable idle.
3. Poor driveability.
If any of the above conditions are noted, first check for any ECU
diagnostic codes and then perform basic engine checks (ignition
system malfunction, incorrect engine adjustment, etc.), and then
inspect the MPI system components with the multi-use tester
(MUT) service data test.
NOTE
1) Before removing or installing any part, read the diagnosis
code, then disconnect the battery negative (-) terminal.
2) Before disconnecting the cable from battery terminal, turn
the ignition switch to OFF. Removal or replacement of
battery cable during engine operation or while the ignition
switch is ON could cause damage to the ECU.
3) The harness between the ECU and the oxygen sensor is
shielded to prevent the influence of ignition noises and
radio interference. When the wire is faulty, the harness
must be replaced.
Malfunction Indicator Light
Among the self-diagnostic items, a malfunction indicator light
comes on to notify the driver of emission control items that are
malfunctioning.
However, when a signal returns to normal and the ECU senses
that it has returned to normal, the malfunction indicator light
goes out.
Immediately after the ignition switch is turned on, the
malfunction indicator light is lit for 2.5 seconds to indicated that
it is operating normally.
The MIL will come ON only while the engine is running and a
problem is detected.
Items Indicated By The MIL (Malfunction Indicator Light)
o Computer
o Oxygen sensor
o Air-flow sensor
o Throttle position sensor
3 1 - 2 9
MPI SYSTEM
o Motor position sensor
o Engine coolant temperature sensor
o Crank angle sensor
o No.1 cylinder top dead center sensor
o Barometric pressure sensor
o Injector
o Fuel pump
o EGR temperature sensor (California Vehicles Only)
SELF-DIAGNOSIS
The electronic control unit monitors the input/output signals at
all times.
When the ECU detects a problem for a specified time, the
electronic control unit memorizes the trouble code, and outputs
a signal to the self-diagnositc output terminal.
There are 14 diagnosis codes, including the normal code, that
can be read out with a voltmeter or the multi-use tester.
The diagnosis codes are memorized even if the ignition key is
turned off. The trouble codes will, however, be erased when the
battery terminal or the electronic control unit harness is
disconnected.
NOTE
If a sensor connector is disconnected with the ignition switch
turned on, a diagnosis code will be memorized. To erase any
diagnostic codes, disconnect the battery negative terminal (-)
for 15 seconds or more, and the ECU memory will be erased.
The 13 diagnostic codes are listed below, and if more than one
code is detected, they will be indicated sequentially from the
smallest to the largest code number.
Trouble code Diagnosis item Trouble code Diagnosis item
11 Oxygen sensor
12 Air-flow sensor
13 Intake air temperature sensor
14 Throttle position sensor
15 Motor position sensor
21 Engine coolant temperature sensor
22 Crank angle sensor
23
24
25
41
42
43
Vehicle-speed reed switch
Injector
Fuel pump
Vehicles Only)
3 1 - 3 0
CHECKING PROCEDURE (SELF-DIAGNOSIS)
CAUTION
1) If the battery voltage is low, no trouble codes will be
stored. Be sure to check the battery voltage before starting
the test.
2) Diagnostic codes will be erased if the battery or the ECU
harness is disconnected. Do not disconnect the battery
before the diagnostic codes are read.
3) After checks and repairs are completed, disconnect the (-)
ground cable for 15 seconds or more to make sure that
the codes are erased.
Inspection Procedure (Using Mlulti-Use Tester)
1.
2.
3.
4.
5.
6.
Connect the harness connector of the multi-use tester to the
Connect the power-source terminal of the multi-use tester
to the cigarette lighter socket.
Turn the ignition switch ON.
Use the multi-use tester to check the self-diagnostic codes.
After completion of the repair, turn the ignition switch OFF;
then disconnect the battery negative terminal for 15 seconds.
Then, check that no malfunction codes are displayed with the
multi-use tester.
7. Disconnect the multi-use tester.
NOTE
If a test is to be made during cranking, the power to the
cigarette lighter will be interrupted. Therefore, use the
separate battery harness for the multi-use tester.
3 1 - 3 1
MPI SYSTEM
Inspection Procedure (Using Voltmeter)
1. Connect the voltmeter to the self diagnosis connector.
2. Turn on the ignition switch, and indication of electronic
control unit memory contents will immediately start. If the
system is in normal operating condition, the pointer of
voltmeter indicates a normal pattern. If any abnormality is
in the memory, the pointer of voltmeter will deflect,
indicating an abnormal item as described in “Diagnosis
chart”.
After recording the abnormal item, check and repair each
part according to the check items in “Diagnosis Chart”
3. When the defective parts have been repaired, disconnect the
negative terminal of the battery cable for 15 seconds or
more, reconnect it to make sure that the abnormal code has
been erased.
Diagnosis Chart
output
Diagnosis
Trouble code
preference Check item (Remedy)
order item Output signal pattern No. Memory
1 Electronic - - (Replace electronic control unit)
control
unit
2 Oxygen 11 Retained o Harness and connector
sensor o Fuel pressure
o injectors
(Replace if defective)
o Intake air leaks
o Oxygen sensor
3 Air flow 12 Retained o Harness and connector
sensor (If harness and connector
are normal, replace air flow
sensor assembly)
3 1 - 3 2
MPI SYSTEM
output Diagnosis Trouble code
order item Output signal pattern NO. Memory
4 Air tem- 13 Retained o Harness and connector
perature o Air temperature sensor
sensor
5 Throttle 14 Retained o Harness and connector
position o Throttle position sensor
sensor o Idle position switch
6 Motor 15 Retained o Harness and connector
position o Motor position sensor
sensor
7 Engine 21 Retained o Harness and connector
coolant o Engine coolant temperature
temperature
sensor
sensor
8 Crank angle 22 Retained o Harness and connector
are normal, replace the
distributor assembly.)
9 No.1 cylin- 23 Retained o Harness and connector
der top (If harness and connector
dead center are normal, replace the
sensor distributor assembly.)
10 Vehiclespeed
sensor
(reed
switch)
24 Retained o Harness and connector
o Vehicle-speed sensor
(reed switch)
3 1 - 3 3
MPI SYSTEM
preference item Check item (Remedy)
order Output signal pattern No. Memory
11 Barometric 25 Retained o Harness and connector
pressure (If harness and connector
sensor are normal, replace the
barometric pressure sensor
assembly.)
12 Injector 41 Retained o Harness and connector
o Injector coil resistance
13 Fuel pump 42 Retained o Harness and connector
o Control relay
14 EGR* 43 Retained o Harness and connector
o EGR valve
o EGR control solenoid valve
o EGR valve control vacuum
15 Normal - - -
state
NOTE
1. Replace the ECU only when all other possible causes for a malfunction have been explored.
2. The diagnostic item marked * is applicable to the California vehicles only.
3 1 - 3 4
MPI SYSTEM
CHECKING (USING THE MULTI-USE TESTER)
1. Turn the ignition switch OFF.
2. Connect the harness connector of the multi-use tester to the
3. Connect the power-source terminal of the multi-use tester
4. Turn the ignition switch ON.
5. Use the multi-use- tester to make the system and sensor
checks.
NOTE
If the malfunction indicator light (engine-check light)
illuminates while the checks are being made, check the
self-diagnostic output.
6. After the repair, check again to be sure the problem has been
corrected.
7. Turn the ignition switch OFF.
8. Disconnect the multi-use tester.
9. Disconnect the battery negative terminal for 15 seconds or
longer. This erases the self-diagnostic code.
10. Restart the engine. Check (by a driving test and other means)
that the problem has been corrected.
NOTE
cigarette lighter will be interrupted, therefore, use the
Cranking Cheek (should be performed when the engine fails to start, or before starting the engine)
Item No.: Multi-use tester code number
Check points Check conditions
Battery voltage
o Service data
o Item No.16
o Ignition switch: ON
Test
specification
Probable cause of malfunction
11-13 v o Low battery voltage
o Power not supplied to the electronic
control unit
1) Check the power-supply circuit.
2) Check the ignition switch.
3) Check the control relay.
o Malfunction of the electronic control
unit ground circuit
3 1 - 3 5
MPI SYSTEM
Test
specification
Malfunction code
read out
o Self diagnostic
Fuel pump
o Actuator test
o Item No.7
o After holding for 15 seconds or Normal o Check in accordance with the diaglonger
with the ignition switch at nostic code.
“ON”, move the ignition switch to (Note that the diagnostic code will be
“LOCK” and disconnect the ISC erased if there is disconnection or
servo connector. damage to the electronic control unit
o Crank for four seconds or longer. back-up power-supply circuit.)
o Ignition switch: “ON” o If various diagnostic codes are output,
(Check for damage or disconnec- the most frequent cause is damage or
tion of the injector or crank angle disconnection of the power-supply or
sensor circuit.) ground circuit.
Try under both Pinch off The pulsations o Voltage is not supplied to the fuel
conditions: the return of the fuel flow pump.
o Engine cranking hose. can be felt. 1) Check the ignition switch (IG and
o Forced fuel pump ST)
activation
Listen closely The pump
to the fuel drive sound
2) Check the control relay.
tank. can be heard.
3) Check the related circuits.
o Malfunction of the fuel pump.
Crank angle sensor o Engine cranking Cranking Engine speed o If the tachometer reading is 0, there
o Service data o Tachometer con- speed (rpm) (rpm) is no interruption of the ignition coil
o Item No.22 nected (check, by
Approx. 200 Approx. 200
primary current.
using the tacho- 1) Check the power transistor and
meter for inter- the control circuit.
ruptions of the 2) Check the ignition coil and the coil
ignition coil power supply circuit.
primary current.) o If the multi-use tester’s indicated rpm
is abnormal
1) Malfunction of the crank angle
sensor circuit.
2) Malfunction of the crank angle
sensor.
3) Malfunction of the timing belt.
3 1 - 3 6
MPI SYSTEM
Check points
Injectors
o Service data
o Item No.41
Check conditions
o Engine cranking Listen for
operation
Engine
coolant
temperature
[°C (°F)]
0 (32)
20 (68)
80 (176)
Test
specification
Injectors o Injector malfunction.
should be o Improper contact of the connector and
heard control relay contacts.
Injector o Malfunction of the engine coolant
activation temperature sensor.
time o Malfunction of the ignition
(msec.) switch-ST.
Approx. 17
Approx. 35
Approx. 8.5
3 1 - 3 7
MPI SYSTEM
Sensor Check
Test
specification
Self-diagnostic
output
o Engine: idling
(2 minutes or more after engine
start)
diagnostic code.
be erased if there is disconnection
or damage of the engine control
unit back-up power-supply circuit.)
o If numerous diagnostic codes are
output, the most frequent cause is
damage or disconnection of the
power-supply or ground circuit.
Oxygen sensor
o Service data
o Item No.11
o Engine warm
(Make the
mixture lean by
engine speed
reduction, and
rich by racing.)
Engine Voltage (mV) o If the oxygen sensor output voltage
condition is high during sudden deceleration
When sudden 200 or lower
1) Check for injector leakage.
deceleration
2) Check the oxygen sensor signal
from 4,000
circuit.
rpm
is low during high engine speed
When engine 600-1,000 1) Check the oxygen sensor and
is suddenly signal circuit.
rewed
o Engine warm Engine speed Voltage (mV) o If the oxygen sensor signal is
(Using the oxygen (rpm) normal, the electronic control unit
sensor signal,
check the air/fuel
700 (idle) 400 or lower
is regulating the air/fuel mixture
ratio normally.
mixture ratio, and 2,000 o If the oxygen sensor output voltage
also check the is low at all times, check for intake
condition of the (changes) air restriction.
electronic control o If the oxygen sensor output voltage
unit.) is high at all times, check for
600-1,000 leakage of the injector.
Air-flow sensor o Engine warm Engine Frequency (Hz) o If the air-flow sensor output sudo
Service data condition denly changes greatly, improper
o Item No.1 2 700 rpm 3 0 - 5 0
contact of the air-flow sensor or
(Idle)
connector is probable.
o If the output frequency of the
2,000 rpm 6 3 - 8 3 air-flow sensor is unusually high or
Revving Increases
low, check the air cleaner element.
caused by
racing
air-flow sensor is high, an increase
of engine resistance or leakage of
compression pressure is probable.
3 1 - 3 8
MPI SYSTEM
Test
specification
Intake-air temper- o Ignition switch: Air temperature Temperature o Malfunction of the intake-air temature
sensor ON, or engine °C (°F) °C (°F) perature or related circuit
o Service data running
o Item No.13
-20 (-4) -20 (-4)
0 (32) 0 (32)
20 (68) 20 (68)
40 (104) 40 (104)
80 (176) 80 (176)
o Ignition switch: Warm by using Increases
ON a hair dryer or
other method.
Throttle-position
sensor
o Service data
o Item No.14
o Hold for 15 Throttle valve Voltage (mV) o Throttle position sensor misadjusted
seconds or
longer with the
Idle position 480-520
o Throttle position sensor or related
circuit malfunction
ignition switch Opens slowly. Becomes
at “ON”. higher in
proportion to
valve opening
Motor position
sensor
o Service data
o Item No.1 5
Fully open 4,500-5,500
o Engine: Idle Engine Voltage (mV) o If the voltage is low, check whether
after warm-up condition or not there is air intake.
(The idle position
switch
Idle (700 rpm) 500-1,300
o If the voltage is high, the probable
cause is:
must be ON.) 1) Deposits adhered to the throttle
valve
2) Increased engine resistance
o If the voltage or idling speed is
abnormal even though each part of
the engine is normal, the probable
cause is:
1) Improper adjustment of the idle
speed control and/or the throttle
position sensor
2) Malfunction of the motor position
sensor or the related circuit.
3 1 - 3 9
MPI SYSTEM
Check points
Motor position
sensor
o Sensor data
o Item No.15
Check conditions
Test
specification
The compressor Air conditioner 800-1,800 o If the engine speed does not
clutch must be switch ON increase when the air conditioner
activated when (800 rpm) switch is switched from OFF to ON,
the air condi- check the DC motor drive circuit
tioner switch is o Check the air conditioner system
switched ON.)
Air conditioner 900-1,900 o Check the inhibitor switch and the
switch: ON signal circuit
Shift lever: “D”
range (700
rpm)
Crank signal
o Service data
o Item No.18
Engine coolant
temperature
sensor
o Service data
o Item No.21
Crank angle
sensor
o Service data
o Item No.22
o Ignition switch: OFF o Ignition switch-ST signal circuit
ON check
o Ignition switch check
o Ignition switch: Engine coolant Temperature o Engine coolant temperature sensor
ON, or engine temperature °C (°F) or related circuit malfunction
running °C (°F)
-20 (-4) -20 (-4)
0 (32) 0 (32)
20 (68) 20 (68)
40 (104) 40 (104)
80 (176) 80 (176)
o Engine: idle Engine coolant Idle rpm o If the idle speed suddenly increases,
(Check with the temperature a malfunction of the crank angle
ignition switch °C (°F) sensor or improper contact of the
ON.)
-20 (-4) 1,500-1,700
0 (32) 1,350-1,550
20 (68) 1,150-1,350
40 (104) 950-1,150
80 (176) 650-850
3 1 - 4 0
MPI SYSTEM
Test
specification
Barometric pres- o Ignition switch: Altitude m (ft.) Pressure o Barometric pressure sensor or
sure sensor ON mm Hg related circuit malfunction.
o Service data
0 (0) 760
(If the barometric pressure sensor
o Item No.25 pressure is low at high speed,
600 (1,968) 710 clogging of the air cleaner element
1,200 (3,937) 660
is probable.)
1,800 (5,905) 610
o Engine: Gradually close Decreases.
2,000 rpm the air-intake
duct by hand.
Idle switch
o Service data
o Item No.26
Power-steering
switch
o Service data
o Item No.27
o Ignition switch: Throttle valve ON o Idle position switch or related circuit
ON idling position malfunction
(Checking by
Open the throt- OFF
o Improper adjustment of the acceldepressing
the erator cable or the cruise control
accelerator pedal
tle valve slightly.
cable.
several times) o Misadjusted fixed SAS.
o Engine: Idle Steering OFF o Power steering oil-pressure
wheel neutral switch or signal circuit malfunction
position
(wheels
straight-ahead
direction)
Steering
wheel half
turn
ON
Air-conditioner
switch
o Service data
o Item No.28
o Engine: idle Air-conditioner
(The air condi- switch “OFF”
tioner compressor
will be
activated when
Air-conditioner
the air-condiswitch
“ON”
tioner switch is
ON.)
OFF
ON
o Check the air conditioner system.
Inhibitor switch
o Service data
o Item No.29
o Ignition switch: Shift lever: “P”, “N” o Malfunction of the inhibitor
ON “P” or “N” switch or the signal circuit.
(A/T models
only)
Shift lever: “D”, “2”, “L”, o Improper adjustment of the control
“D”, “2”, “L” “R”
cable between the shift lever and
or “R”
the inhibitor switch.
3 1 - 4 1
MPI SYSTEM
Test
specification
EGR temperature o Engine: warm Engine Temperature o Check the EGR temperature
sensor condition °C (°F) sensor.
[California vehicle o Check the EGR control system.
only)
700 rpm 70 (158)
(Idle) or less
o Check the EGR valve.
o Service data o Check the EGR control solenoid
o Item No.43 3,500 rpm 70 (158) valve.
o Disconnect or more o Check the EGR control vacuum.
the vacuum
hose (yellow)
stripe from the
A port nipple
of the throttle
body, and
pinch the hose
end with your
fingers.
Injectors
o Actuator test
o Item No.1-4
Injector
o Service data
o Item No.41
o Engine: idle Injector No. Engine o If the idling condition doesn’t
after warm-up
1
(Cut off the
Unstable idle
change, check the cylinder.
1) Check the injector operation
injectors in 2 sound.
sequence dur- 2) Check the spark plug and
ing idle after
3
high-tension cable.
engine warm- 4 3) Check the power transistor unit
up; check the and control circuit.
idle condition.) 4) Check injecting condition
o Engine: warmed Engine Activation o If the injector activation time is
up condition time (msec.) unusually long or short, there is a
700 rpm 2.2-2.9
malfunction of the air-flow sensor,
(Idle)
engine coolant temperature sensor,
intake-air temperature sensor, or
2,000 rpm 1.8-2.6 barometric pressure sensor.
Rapid racing Increases
long, increased engine resistance or
leakage of compression pressure is
probable.
Ignition advance o Engine: warmed Engine speed
(power transistor) up (rpm)
o Service data o Timing light: set
o Item No.44
700 (Idle)
2,000
Ignition
advance
(°BTDC)
8 - 1 2
2 6 - 3 4
o If the ignition advance and actual
ignition timing are different, adjust
the ignition timing.
[The ignition timing may fluctuate
during idling, but this is not a
problem. The advance is greater
(approx. 5°) at high altitude.]
3 1 - 4 2
MPI SYSTEM
Check points
Air conditioner
relay
o Service data
o Item No.49
Check conditions
Test
specification
o Engine: idle Air conditioner Air conditioner o If the air conditioner relay output is
after warm-up switch relay abnormal, check the air conditioner
OFF OFF
signal input circuit and the air
(compressor
conditioner system.
clutch nono
If the activation of the air condiactivation)
tioner compressor clutch is not
normal, check the compressor
ON ON (compres- clutch and the relay circuit.
sor clutch
activation)
Purge control o Ignition switch: Actuator forced Operation o Check the purge control solenoid
solenoid valve ON actuation sound is valve.
o Actuator test (Engine stop) audible o Check the purge control solenoid
o Item No.8 valve drive circuit.
EGR control o Ignition switch: Actuator forced Operation o Check the EGR control solenoid
[California vehicle (Engine stop) audible o Check the EGR control solenoid
only) valve drive circuit.
o Actuator test
o Item No.10
3 1 - 4 3
MPI SYSTEM
MPI SYSTEM COMPONENTS INSPECTION
Air Flow Sensor (AFS)
1. Connect a voltmeter between 6 and 3 of AFS connector.
Terminal 6 : Sensor ground
Terminal 3 : AFS output
2. Warm the engine and bring it to a normal idle.
3. Measure the voltage between terminals.
Engine speed (rpm) Output voltage (V)
Idling
3,000
2.7-3.2
NOTE
If the air flow sensor fails, the intake air volume cannot
be measured and as a result, normal fuel injection control
is no longer available. The vehicle can be run, however,
by a preset map value.
Barometric Pressure Sensor
1. Connect a voltmeter between terminals 5 and 6 of the
barometric pressure sensor connector.
Terminal 5 : Barometric sensor output
3. Slowly cover about half of the air cleaner air intake, checking
for a change in voltage.
Pressure
Fall
Voltage
Drop
3 1 - 4 4
MPI SYSTEM
Reference
Pressure mmHg (kPa, psi) (20, 2.9) (49, 6.9) (103, 15)
150 350 760
Central voltage (V) 0.79 1.84 4.00
4. Replace the air flow sensor if necessary.
intake Air Temperature Sensor
1. Disconnect the air flow sensor connectors.
2. Measure the resistance between the terminals 4 and 6.
Terminal 4 : intake air temperature output
3.
4.
Temperature ºC (ºF) Resistance (KD)
0 (32) 5.4-6.6
20 (68) 2.33-2.97
80 (176) 0.31-0.43
Measure the resistance while heating the sensor using a
hair drier.
Higher Smaller
If the value deviates from the standard value or the
resistance remains unchanged, replace the air flow sensor
assembly.
Engine Coolant Temperature Sensor
1. Remove the engine coolant temperature sensor from the
intake manifold.
2. With the sensing portion of the engine coolant temperature
sensor immersed in hot water, check resistance. The sensor
should be held with its housing 3 mm (0.12 in.) away from
the surface of the hot water.
3 1 - 4 5
MPI SYSTEM
3.
0 (32) 5.9
20 (68) 2.5
40 (104) 1.1
80 (176) 0.3
If the resistance deviates from the standard value greatly,
replace the sensor.
Throttle Position Sensor (TPS)
1. Disconnect the throttle position sensor connector.
2. Measure the resistance between terminals 1 and 4 of the
Terminal 1 : Sensor ground
Terminal 4 : Sensor power
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.5-6.5 Kfi
3 1 - 4 6
MPI SYSTEM
3. Connect an analog type ohmmeter between terminals 1 and
3.
Terminal 3 : Sensor output
4. Slowly open the throttle valve from the idle position to the
fully open position and check that the resistance values
change smoothly with the opening of the throttle valve.
Standard value . . . . . . . . . . . . . . . Approx 0.5 - (3.5-6.5) kfl
5. If the resistance is out of specification, or if the change is
not smooth, replace the throttle position sensor.
Tightening torque
Throttle position sensor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1.5-2.5 Nm (15-25 kg.cm, 1.1-1.8 lb.ft)
Idle Switch
1. Disconnect the ISC motor connector.
2. Check for continuity between the terminal 3 and the body
ground.
Terminal 3 : Idle Switch
Accelerator pedal Continuity
Depressed Non-conductive (MI)
Released Conductive (On)
Motor Position Sensor (MPS)
1. Connect an ohmmeter between terminals 4 and 1 of the
motor position sensor connector.
Terminal 1 : Sensor power
Terminal 4 : Sensor ground
2. Measure the resistance of the terminals.
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-6 kfi
3. Attach an ohmmeter between terminals 2 and 4 of the motor
Terminal 2 : MPS output
4. Connect a 6V battery between terminals 2 and 1 of the ISC
motor connector and check to see that resistance changes
smoothly when the ISC motor is activated.
Standard value . . . . . . . . . . . . . . . . . . Approx 0.5 - (4-6) k0
3 1 - 4 8
MPI SYSTEM
5. If the standard value is not achieved, or if the change is not
smooth, replace the ISC servo assembly.
No.1 Cylinder TDC Sensor And Crankshaft
Angle Sensor
1. Connect a voltmeter between terminals 1 and 2, and 1 and
3.
Terminal 2 : Crank angle signal
Terminal 3 : No.1 TDC signal
2. Measure the output voltage of the terminals while cranking
the engine.
Sensor
No.1 cylinder
TDC sensor
Terminal
Ground
Voltage
0.2-1.2V
(The needle fluctuates)
Crankshaft
angle sensor
Ground 1.8-2.5V
3. When the voltage is abnormal, check the sensor power and
ground circuit, and if nothing unusual is found, disassemble
the distributor and check it.
Oxygen Sensor
NOTE
1) Before checking, warm up the engine until engine coolant
temperature reaches 80 to 95ºC (176 to 203ºF)
2) Use an accurate digital voltmeter.
1. Disconnect the oxygen sensor connector and connect a
voltmeter to the oxygen sensor connector.
2. While increasing engine RPM, measure the oxygen sensor
output voltage.
3 1 - 4 9
MPI SYSTEM
Engine
Oxygen sensor
output voltage
Remarks
Increase RPM Min. 0.6V Richens air/fuel mixture
Tightening torque
Oxygen sensor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
39-49 Nm (400-500 kg.cm, 29-36 lb.ft)
Vehicle Speed Sensor
The vehicle speed sensor uses a reed type switch. The speed
sensor built in the speedometer converts the speedometer gear
revolution (vehicle speed) into pulse signals, which are sent to
the ECU.
Inhibitor Switch (For A/T)
Refer to Group 45.
Injectors
Operation Check
Using a multi-use tester, check as described below.
o Cut off the fuel injection of the injectors in sequence.
o Check the operation time of the injectors.
Operation Sound Check
using a stethoscope, check the operation sound (tick, tick) during
idle or cranking. Check that the sound is produced at shorter
intervals as the engine speed increases.
NOTE
1) Other injectors may produce sound as they operate even
if the injector being checked does not operate.
2) Ensure that the sound from an adjacent injector is not
being transmitted along the delivery pipe to an inoperative
injector.
3 1 - 5 0
MPI SYSTEM
Resistance Measurement Between Terminals
1. Disconnect the connector for the injector.
2. Measure the resistance between the terminals.
Standard value . . . . . . . . . . . . . . . . 13-16 Cl [at 20°C (68ºF)]
3. Connect the connector for the injector.
Idle Speed control (ISC) Servo
1. Measure resistance between terminal 1 and 2 using an
ohmmeter.
Standard value : 5-35 Sz [at 20°C (68ºF)]
2. Connect 6V DC to terminals 1 and 2 and check that the idle
speed control servo extends and retracts by itself.
If the idle speed control servo does not move, replace the
idle speed control servo assembly.
CAUTION
Apply only a 6V DC or lower voltage. Application of higher
voltage could cause locking of the servo gears.
4. If the servo does not operate, replace it as an assembly.
3 1 - 5 1
MPI SYSTEM
Control Relay
CAUTION
When applying battery voltage directly, make sure that it is
applied to the correct terminal. Otherwise, the relay could be
damaged.
NOTE
Failure of the control relay interrupts power supply to the fuel
pump, injectors and ECU, resulting in start failure.
1. Check continuity between the terminals when the relay coil
is energized and when it is not.
NOTE
In the following tables, the arrows indicate the direction
of the current flow.
Confirm circuit tester polarity before checking continuity.
o Coils L1 and L2
Condition Measuring
terminals Continuity
Not
energized
1 - 4
3 - 8
2 - 8
Non-conductive (MI)
Conductive (approx. 950)
Energized
6 - 7 Conductive (approx. 35R)
1 - 4 Conductive (On)
NOTE
“Energized” means voltage applied across terminals 6 and
7.
o Coil L3
NOTE
“Energized” means voltage applied across terminals 5 and
7.
2. If the result is not satisfactory, replace the control relay.
3 1 - 5 2
MPI SYSTEM
Power Transistor
The power transistor is installed on the intake manifold; it
functions to control the ignition timing by controlling the ignition
coil primary current by signals from the ECU.
1. Disconnect the power transistor connector.
2. Connect a power supply of 1.5V (one dry cell) between the
power transistor and then check for continuity between
terminals 3 and 2 under power-ON and power-OFF
conditions.
NOTE
1) When checking for continuity, connect the ohmmeter
to terminal 2 on the positive side and terminal 1 on
the negative side.
2) Check with an analog-type circuit tester.
3 1 - 5 3
INJECTOR AND THROTTLE BODY (MPI)
COMPONENTS
TORQUE : Nm (kg.cm, lb.ft)
REMOVAL
1. Release residual pressure from the fuel line to prevent fuel
from spilling.
CAUTION
fuel from leaking out due to residual pressure in the fuel
line.
3 1 - 5 4
2. Remove the delivery pipe with the fuel injector and pressure
regulator.
CAUTION
1. Be careful not to drop any injectors when removing the
delivery pipe.
2. Be aware that fuel may flow out when removing the
injector.
INSPECTION
1. Measure the resistance of the injectors between the
terminals using an ohmmeter.
Resistance . . . . . . . . . . . . . . . . . . . . .13-16n [at 20°C (68ºF)]
2. If the resistance is not within specifications, replace the
injector.
INSTALLATION
1. Install a new grommet and O-ring to the injector.
2. Apply a coating of solvent, spindle oil or gasoline to the
O-ring of the injector.
3. While turning the injector to the left and right, install it on
to the delivery pipe.
4. Be sure the injector turns smoothly.
NOTE
If it does not turn smoothly, the O-ring may be jammed;
remove the injector and re-insert it into the delivery pipe
and re-check.
3 1 - 5 5
5. When installing the delivery pipe, check to be sure that the
insulator is correctly inserted into the delivery pipe’s
installation hole.
6. When connecting the fuel pressure regulator to the delivery
pipe, apply light oil or fuel to the O-ring, and then insert,
being careful not to damage the O-ring.
7. When connecting the high pressure fuel hose to the delivery
pipe, apply fuel to the hose union, and then insert, being
3 1 - 5 6
THROTTLE BODY (MPI)
THROTTLE BODY
COMPONENTS
REMOVAL
CAUTION
The throttle valve must not be removed.
3 1 - 5 7
THROTTLE BODY (MPI)
1. Remove the throttle position sensor by unscrewing the
Phillips-head screws.
NOTE
Except when necessary for replacement, the throttle
position sensor must not be removed.
2. Remove the ISC servo assembly.
NOTE
1) Except when necessary for replacement, the ISC servo
assembly should not be removed.
2) The ISC servo assembly should not be disassembled.
3. Use an open-end wrench or box wrench to remove the
adjustment screw.
INSPECTION
Cleaning Throttle Body components
1. Clean all components. The following components must not
be cleaned by immersion in cleaning solvents.
o ISC servo assembly
The insulation of these components will be damaged if they
are immersed in a cleaning solvent. They should be cleaned
by using only a piece of cloth.
2. Check for restriction of the vacuum port or passage. Clean
the vacuum passage by using compressed air.
3 1 - 5 8
FUEL TANK
COMPONENTS
REMOVAL
1. To reduce the internal pressure of the fuel lines and hoses,
first start the engine and then disconnect the electrical fuel
pump connector.
NOTE
Be sure to reduce the fuel pressure before disconnecting
the fuel line and hose otherwise fuel will spill out.
3 1 - 5 9
FUEL TANK (MPI)
2. Disconnect the battery cable from the negative terminal of
the battery.
3. Remove the fuel tank cap.
4. Remove the drain plug and drain the fuel.
5. Disconnect the return hose and vapor hose.
6. Disconnect the fuel gauge unit connector.
3 1 - 6 0
FUEL TANK (MPI)
7. Disconnect the high pressure hose from the fuel tank.
8. Detach the fuel filler hose and leveling hose.
9. Loosen the two self-locking nuts, that hold the tank in
position and remove the two tank bands.
10. Remove the fuel vapor hose and the fuel tank.
INSPECTION
1. Check the hoses and the pipes for cracks or damage.
2. Check the fuel tank cap for proper operation.
3. Check the fuel tank for deformation, corrosion or cracking.
4. Check the inside fuel tank for dirt or foreign material.
5. Check the in-tank fuel filter for damage or restriction.
3 1 - 6 1
FUEL TANK (MPI)
6. Test the two-way valve for proper operation.
7. To check the two-way valve, lightly breathe into the inlet and
outlet. If air passes through after slight resistance, then the
valve is good.
INSTALLATION
1. Confirm that the pad is fully bonded to the fuel tank, and
install the fuel tank by tightening the self-locking nuts to the
tank bands until the rear end of the tank band contacts the
body.
2. Connect the leveling hose to the tank and approximately 40
mm (1.6 in.) at the filler neck.
3. When connecting the filler hose, the end with the shorter
straight pipe should be connected to the tank side.
4. Connect the vapor hose and return hose.
When attaching the fuel hose to the line, be sure that the
hose is attached as shown in the illustration.
3 1 - 6 2
FUEL TANK (MPI)
5. To connect the high pressure hose to the fuel pump,
temporarily tighten the flare nut by hand; then tighten it to
the specified torque. Be careful that the fuel hose does not
twist.
Tightening torque
High pressure hose flare nut . . . . . . . . . . . . . . . . . . . . . . . . .
31-41 Nm (320420 kg.mm, 23-30 lb.ft)
CAUTION
When tightening the flare nut, be careful not to bend or
twist the line to prevent damage to the fuel pump
connection.
6. Connect the electrical fuel pump and fuel gauge unit
connector.
7. Tighten the drain plug to the specified torque.
Tightening torque
Drain plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15-25 Nm (150-250 kg.cm, 11-18 lb.ft)
3 1 - 6 3
FUEL LINE AND VAPOR LINE (MPI)
REMOVAL
1. Remove the upper eye bolt while holding the fuel filter nut
securely and remove the high pressure fuel hose.
CAUTION
1) Be sure to reduce the fuel pressure before disconnecting
the fuel line and hose, otherwise fuel will spill
out.
2) Cover the hose connection with a shop towel to
prevent splashing of fuel that could be caused by
residual pressure in the fuel line.
2. Remove the lower eye bolt while holding the fuel filter nut
assembly.
filter from the bracket.
4. Remove the fuel return hose and line.
5. Remove the fuel vapor hose and line.
3 1 - 6 4
INSPECTION
1. Check the hoses and pipes for cracking bending, deformation
or restrictions.
2. Check the canister for restrictions.
3. Check the fuel filter for restrictions and damage.
If a problem is found, repair or replace parts as necessary.
INSTALLATION
1. Install the fuel vapor hose and return hoses.
o If the fuel line has a stepped section, connect the fuel
hose to the line securely, as shown in the illustration.
o If the fuel line does not have a stepped section, connect
the fuel hose to the line securely.
2. Install the fuel filter, and tighten the fuel filter bracket.
3. Insert the main line on the filter and tighten the eye bolts
while holding the fuel filter nuts.
4. Install the clips and make sure that they do not interfere with
other components.
5. When installing the check valve, install it so that the valve
is facing in the direction as shown in the illustration.
ENGINE CONTROL (MPI)
ENGINE CONTROL
TORQUE : Nm (kg.cm, Ib.ft)
REMOVAL
1. Remove the bushing and inner cable of the accelerator arm
side.
2. After disconnecting the accelerator switch connector, loosen
the bolts of the accelerator arm bracket and remove.
3 1 - 6 6
INSPECTION
1. Check the inner and outer cable for damage.
2. Check the cable for smooth movement.
3. Check the accelerator arm for deformation.
4. Check the return spring for deterioration.
5. Check the connection of the bushing to end metal fitting.
6. Check the accelerator switch for proper operation.
INSTALLATION
1. When installing the return spring and accelerator arm, apply
multi-purpose grease around each moving point of the
accelerator arm.
2. Apply the sealant to the bolt mounting hole, and tighten the
accelerator arm bracket.
Tightening torque
Accelerator arm bracket bolts . . . . . . . . . . . . . . . . . . . . . . . . .
8-12 Nm (80-120 kg.cm, 5.8-7.2 lb.ft)
3. Securely install the resin bushing of the accelerator cable
on the end of the accelerator arm.
4. Apply multipurpose grease around the cable end.
3 1 - 6 7
GENERAL (FBC)
GENERAL INFORMATION (FBC SYSTEM)
The Feedback Carburetor (FBC) system provides a positive
air-fuel ratio control for maximum reduction of emissions. The
Electric Control Unit (ECU) receives signals from various sensors
and then modulates two solenoid valves (FBSV, SCSV) installed
on the carburetor to control the air-fuel ratio.
The ECU also controls the ignition timing, electric choke, throttle
opener by switching on-off the solenoid valves.
FBSV : Feedback Solenoid Valve
SCSV : Slowcut Solenoid Valve
ECU : Electric Control Unit
3 1 - 6 9
GENERAL
SPECIFICATIONS
Fuel tank
Capacity
Fuel filter
Type [In-line filter]
Type [In-tank filter]
Fuel pump
Type
Driven by
Feed pressure
Carburetor
Type
Identification mark
M/T
A/T
Throttle bore
Primary
Secondary
Feedback solenoid valve (FBSV)
Type
Coil resistance
Slow cut solenoid valve (SCSV)
Type
Coil resistance
Type
Regulating voltage (When throttle
valve fully closed)
Coil resistance
Bow vent valve (BVV)
Type
Vacuum orifice
Mixture control valve (MCV)
Type
Dash pot
Type
Operating rpm (When SAS 2 touches
free lever)
Outer venturi dia.
Primary
Secondary
Inner venturi dia.
Primary
Secondary
45 lit. (11.9 U.S.gal., 9.9 Imp.gal.)
Cartridge type
Open type
Mechanical diaphragm type
Camshaft
19-25 kPa (2.76-3.63 psi) at 2,500 rpm
Down-draft, 2-barrel, feed back type
472 (For Canada), 474 (For Federal)
475 (For Federal)
30 mm (1.181 in.)
32 mm (1.260 in.)
Duty cycle solenoid
54-66 fl [At 20°C (68ºF)l
Duty cycle solenoid
48-60 fl [At 20°C (68ºF)]
Variable resistor type (Rotary type)
0.25V
3.5-6.5 KD
Vacuum type
0.3 mm (0.012 in.)
Vacuum type
Conventional type
Approx. 1,800 rpm
20 mm (0.787 in.)
25 mm (0.984 in.)
9-14 mm (0.354-0.551 in.)
9-12 mm (0.354-0.472 in.)
3 1 - 7 0
GENERAL (FBC)
Main jet
Primary
Secondary
Main air jet
Primary - First
Second
Secondary
Pilot jet
Primary
Secondary
Pilot air jet
Primary - First
Second
Secondary
Main nozzle
Primary
Secondary
Throttle valve plate
Thickness
Primary
Secondary
Fuel closing angle
Primary
Secondary
Full opening angle
Enrichment jet
Slow air jet
Accelerating pump
Diaphragm dia.
Pump jet dia.
Choke
Type
Choke valve operating angle
Bimetal
Temperature constant
Spring constant
Choke breaker opening
First stage
Second stage
Input sensor
Type
Resistance
#83.8
#145
#80
#60
#70
#46.3
#70
#120
#200
#100
2.6 mm (0.102 in.)
2.8 mm (0.110 in.)
1.0 mm (0.040 in.)
1.5 mm (0.060 in.)
15º
90º
#50
#110
24 mm (0.945 in.)
0.35 mm (0.014 in.)
Automatic (Electric type)
25º (When fully closed)
90° (When fully opened)
1.0 deg/ºC
60 gr.mm/deg.
1.4-1.6 mm (0.056,0.064 in.)
2.9-3.1 mm (0.116-0.124 in.)
Thermistor type
2.5 KR [at 20°C (68ºF)]
0.3 Ka [at 80°C (176ºF)l
3 1 - 7 1
GENERAL (FBC)
Oxygen sensor
Type
Vacuum switch
Type
Operating condition - ON
OFF
Top gear sensing switch
Output actuator
Cold mixture heater
Type
Secondary air control solenoid valve
Type
Resistance
Advance control solenoid valve
Type
Resistance
Cold advance control solenoid valve
Type
Resistance
Throttle opener control solenoid valve
Type
Resistance
Zirconia sensor
Contact type switch
More than 40 kPa (5.8 psi)
Less than 26 kPa (3.9 psi)
Reed switch type
Contact type switch
Positive Temperature Coefficient (PTC) heater
ON-OFF solenoid valve
38-44fi [at 20°C (68ºF)]
38-440 [at 20°C (68ºF)]
38--44fi [at 20°C (68ºF)]
3 1 - 7 2
GENERAL (FBC)
SERVICE STANDARD
Basic ignition timing BTDC 5º ± 1º
Curb idle speed 700 ± 50 rpm
Throttle opener adjusting rpm for electrical load 800 ± 50 rpm
Throttle opener adjusting rpm for air conditioner load 900 ± 25 rpm
TIGHTENING TORQUE
Nm kg.cm lb.ft
Accelerator arm bracket to body 8 - 1 2 8 0 - 1 2 0 5.8-8.7
Accelerator cable guide to body 3 - 5 3 0 - 5 0 2.2-3.6
Carburetor attaching bolt 1 5 - 2 0 150-200 1 1 - 1 4
Engine coolant temperature sensor 2 0 - 4 0 200-400 1 4 - 2 9
Oxygen sensor 3 9 - 4 9 400-500 2 9 - 3 6
Fuel tank drain plug 7 8 - 9 8 800-1,000 5 8 - 7 2
LUBRICANT
Grease for accelerator arm pin and return spring Multipurpose grease SAE J310a, NLGI grade #3
or equivalent
3 1 - 7 3
GENERAL (FBC)
SPECIAL TOOLS
3 1 - 7 4
GENERAL (FBC)
TROUBLESHOOTING
to start with inspection of the basic systems. If you experience
one of the followings, (A) engine start failure, (B) unstable idling
or (C) poor acceleration, you should first check the following
basic systems.
1. Power supply
1) Battery
2) Fusible link
3) Fuse
2. Body ground
3. Fuel supply
1) Fuel line
2) Fuel filter
3) Fuel pump
4. Ignition system
1) Spark plug
3) Distributor
4) Ignition coil
1) PCV system
2) EGR system
3) Vacuum leak
6. Others
1) Ignition timing
2) Idle speed
Troubles with the FBC system are often caused by poor
contact of harness connector. It is, therefore, important to
check harness connector contact.
3 1 - 7 5
GENERAL (FBC)
Fuel Tank and Fuel Line
Symptom
Engine malfunctions due to
insufficient fuel supply
Evaporative emission control
malfunctions (Pressure released
when fuel tank cap is removed)
Probable cause
Clogged fuel filter or in-tank fuel filter
in the pump)
Misrouted vapor lines
Disconnected vapor line piping joint
Folded, belt, cracked or clogged vapor line
(two-way valve)
Remedy
Repair or replace
Clean or replace
Replace
the fuel tank and fuel line
Clean or replace
Replace
Correct
Correct
Replace
Replace
Replace
3 1 - 7 6
GENERAL (FBC)
Carburetor and FBC System
Symptom
or start to hard
stalls
Carburetor
FBC system
Carburetor
FBC system
Probable cause
Choke valve remains open-cold engine
Improper choke breaker operation
Electric choke malfunction
Needle valve sticking or clogged
malfunction
Vacuum hose disconnected or damaged
Slow-cut solenoid valve malfunction
Feedback solenoid valve malfunction
Vacuum switch malfunction-cold engine
Faulty ECU
Harness broken/short-circuited or
loose connection
Choke valve malfunction
Improper fast idle-cold engine
Improper idle adjustment
Primary pilot jet clogged
Dash pot malfunction
malfunction
Throttle position sensor malfunction
Engine speed sensor malfunction
Timing control system malfunction
Throttle opener control system
malfunction
connector not connected securely
Remedy
Clean choke bore and linkage
Check and adjust choke breaker
Check electric choke body and
choke valve operation
Repair or replace
Check by using checker (Check
component and replace if faulty)
Repair or replace
Check component
Check component
Check component
Replace
Repair or replace
Adjust fast idle speed
Adjust idle speed
Check choke body and choke
valve operation
Clean up or replace
Adjust
Check drive signal by using
checker
Check component
Repair or replace
Check component and adjust
Check harness for continuity
Check system. If faulty, check
components
components
Repair or replace
3 1 - 7 7
GENERAL (FBC)
Symptom
Engine hesitates or
poor acceleration
Engine dieseling
(runs after ignition
switch is turned off)
Carburetor
FBC system
Carburetor
FBC system
Poor fuel mileage Carburetor
Probable cause
Acceleration pump malfunction
Choke valve remains closed-hot engine
Main jet clogged
Enrichment jet clogged
Secondary valve operation abnormal
malfunction
Cold mixture heater relay control system
connector not connected properly
Air conditioner power relay control
system malfunction
Engine idle speed too high
Choke valve operation abnormal
Enrichment valve kept open
Remedy
Clean pump discharge. rate
Check choke valve operation
Clean up
Clean up
Check valve operation
checker
Check component
Check with checker (Replace
if faulty)
components
components and replace if faulty)
Check harnesses for continuity
components
Repair or replace
Check system
Adjust idle speed
Check component
Adjust idle speed
Check choke body and valve
operation
Repair or replace
3 1 - 7 8
GENERAL (FBC)
Symptom
Poor fuel mileage FBC system
Probable cause
malfunction
Oxygen sensor malfunction
Remedy
(Check component and replace
if faulty)
if faulty)
components
checker
Check component
checker
Check components
Repair or replace
3 1 - 7 9
GENERAL (FBC)
FBC System Component
1. Electric Control Unit (ECU)
Based on the information- from various sensors, the ECU
determines (computes) ideal setting for varying operating
conditions and drives the output actuators to control the
air-fuel ratio.
The ECU consists of an 8-bit microprocessor, random access
memory (RAM), read only memory (ROM) and input/output
(l/O) interface.
3 1 - 8 0
GENERAL (FBC)
2. Engine Coolant Temperature Sensor
The engine coolant temperature sensor is installed in the
engine coolant passage of the intake manifold. This coolant
sensor is a thermistor. The ECU determines engine
temperature by the sensor output voltage and utilize it to
provide optimum fuel enrichment when the engine is cold.
3. Throttle Position Sensor (TPS)
The TPS is a rotary type variable resistor that rotates together
with the carburetor throttle shaft to sense the throttle valve
angle. As the throttle shaft rotates, the TPS output voltage
changes and the ECU detects the throttle valve opening
based on the change of the voltage.
Using the TPS output signal, engine speed signal and other
signals, the ECU maintains the optimum air-fuel ratio.
4. Engine Speed Sensor
The ignition coil negative terminal voltage makes sudden
increase twice per crankshaft revolution synchronously with
ignition timing.
By sensing this ignition coil negative terminal voltage change
and measuring the time between peak voltages, the ECU
computes the engine speed, judges the engine operating
mode and controls the air-fuel ratio and ignition timing.
GENERAL (FBC)
5. Oxygen Sensor
1) The oxygen sensor installed on the exhaust manifold
makes use of the principles of solid electrolyte oxygen
concentration cell. The‘ oxygen concentration cell is
characterized by sharp change of the output voltage in
the vicinity of the stoichiometric air-fuel ratio.
2) Using such characteristics, the oxygen sensor senses the
oxygen concentration in the exhaust gas and feeds it to
the ECU. The ECU then judges if the air-fuel ratio is
richer or leaner as compared to the stoichiometric ratio
and provides feedback control to adjust the air-fuel ratio
to the stoichiometric ratio where the emission purification
rate of the three way catalytic converter is the
optimum.
6. Vacuum Switch
The vacuum switch is a contact type switch that is operated
by intake manifold vacuum. When the throttle valve closes,
the intake manifold vacuum acts on the vacuum switch to
close its contact.
By this action, the voltage on the ECU side is grounded and
the ECU senses that the throttle valve opening is near idle.
3 1 - 8 2
GENERAL (FBC)
7. Feedback Solenoid Valve (FBSV)
The FBSV is installed in the carburetor float chamber cover.
The ECU controls the air-fuel ratio by controlling the duty
cycle of the FBSV.
The higher is the duty ratio, the leaner becomes the air-fuel
ratio.
NOTE
The duty cycle control means control of the solenoid valve
energization rate by changing the ON time ratio T2/T1
(called duty ratio) of 10 Hz pulse.
8. Slow Cut Solenoid Valve (SCSV)
The SCSV is located in the carburetor float chamber cover.
The ECU controls the carburetor slow system fuel flow by
controlling the duty cycle of the SCSV.
3 1 - 8 3
GENERAL (FBC)
FBC System Operation
1. The air-fuel ratio control is maintained by the ECU in one
of two operating modes.
1) Closed loop control (Feedback control)
After engine warm-up, the air-fuel ratio control is made
by the feedback control based on the oxygen sensor
signal.
The oxygen sensor output voltage changes sharply at the
stoichiometric ratio. The control unit senses this oxygen
sensor signal and provides feedback control to the FBSV
maintaining the stoichiometric ratio that will give the
best purification rate of the 3-catalyst converter may be
accurately kept. In this state, the SCSV is kept wide open
(100% duty).
2) Open loop control (No feedback control)
During engine start, warm-up operation, high load
operation and deceleration, the air-fuel ratio is in
open-loop. The ECU controlled based on map values*
established previously for engine speed, throttle valve
opening angle and engine coolant temperature, to
improve startability and driveability.
During deceleration, the SCSV limits fuel flow for better
fuel economy and for prevention of overheating of the
catalysts.
* Map value is a value previously established and
stored in ROM in ECU.
2. When the FBSV is energized, the main fuel jet is closed to
leaving the primary main jet passage as the only fuel
passage.
This reduces the amount of fuel, resulting in leaner air-fuel
mixture.
3. When the FBSV is de-energized, the main fuel jet is opened
to provide two fuel passages including the primary main jet
passage. Since this will increase the amount of fuel, richer
air-fuel mixture is obtained.
With the ON-OFF operation of SCSV, the slow fuel passage
is opened and closed.
The air-fuel ratio at deceleration is controlled in this manner.
3 1 - 8 4
GENERAL (FBC)
Distributor Advance Control System
(Ignition Timing Control System)
The distributor vacuum advance is a dual diaphragm type having
main vacuum chamber and sub-vacuum chamber. To control the
ignition timing, the ECU energizes the solenoid valves in the
respective vacuum circuits of main vacuum chamber and
subvacuum chamber.
1. Main Vacuum Timing Control
1) When the engine speed is near the idle speed (1,200 rpm
or less), the ECU energizes the distributor advance
control solenoid valve. By this action the carburetor D
port vacuum is introduced to the main vacuum chamber
which resets the ignition timing.
NOTE
The D port vacuum is zero when the throttle valve is
at idle position, and increases with the valve opening
angle.
3 1 - 8 5
GENERAL (FBC)
2. Sub-vacuum Timing Control
2) When the engine speed increases to 1,200 rpm the ECU
turns off the distributor advance control solenoid valve.
Intake manifold vacuum is routed to the main vacuum
chamber increasing ignition advance.
When the engine starts to warm up [engine coolant
temperatures: below 80°C (176°F), the solenoids are
energized, allowing D port vacuum to reach main
vacuum chamber.
o Control at low altitude [approx. 1,200 m (3,900 ft.) or
lower]
1) When the engine coolant temperature is low [50°C
(122°F) or lower], the ECU energizes the distributor cold
advance control solenoid valve. By this action, the intake
manifold vacuum no longer leaks to atmosphere and
instead is introduced to the sub-vacuum chamber. As a
result, the timing advanced by the main vacuum advance
is additionally advanced by a fixed angle (5°C in crank
angle).
2) During warm-up operation or when the engine coolant
temperature is- high [over 50°C (122°F)], the ECU
de-energizes the distributor cold advance control
solenoid valve circuit. As a result, the intake manifold
vacuum leaks to atmosphere, which prevents timing
advance.
o Control at high altitude [approx, 1,200 m (3,900 ft.) or over)
At high altitude, the HAC is closed and hence the intake
manifold vacuum does not leak to atmosphere from the HAC.
Independently of the distributor cold advance control solenoid
valve, the intake manifold vacuum acts on the sub-vacuum
chamber, causing the timing to advance by a fixed angle (5°
in crank angle). [For Federal]
3 1 - 8 6
GENERAL (FBC)
Throttle Opener System (For power steering,
electrical load)
If the power steering oil pressure switch is turned on by high
pump pressure the throttle opener control solenoid valve is
energized to introduce intake manifold vacuum to the throttle
opener. The throttle valve opens slightly, preventing engine
speed drop caused by power steering load.
When the engine speed drops below the set speed (1,200 rpm),
the ECU keeps the power transistor on. When the electrical load
switch is turned on for lighting etc., the throttle opener control
solenoid valve is energized, allowing intake manifold vacuum to
the throttle opener to open the throttle valve slightly, preventing
engine speed drop caused by electrical load.
3 1 - 8 7
GENERAL (FBC)
Throttle Opener Switch (For A/C)
When the engine speed is below the set speed (1,200 rpm), the
ECU keeps the power transistor on. When the air conditioner
relay is turned on the throttle opener control solenoid valve is
opener. The throttle valve opens slightly preventing engine
speed drop caused by air conditioner load.
Air Conditioner Power Relay Control System (For A/T)
When the throttle valve opening increases (over 74°) during
acceleration etc., the ECU turns off the air conditioning power
relay for about 5 seconds. As a result, even if the air conditioner
switch it is, the air compressor is not driven and hence the
engine load is reduced, improving acceleration performance.
3 1 - 8 8
GENERAL (FBC)
Cold Mixture Heater (CMH) Relay Control
System
The cold mixture heater is a Positive Temperature Coefficient
(PTC) heater installed between the carburetor and intake
manifold.
When the engine coolant temperature is below 60°C (140°F), the
ECU energizes the cold mixture heater relay. The closed relay
supplies voltage to the cold mixture heater. The cool air-fuel
mixture is heated and atomized by the heater before it reaches
the combustion chamber for improved combustion.
3 1 - 8 9
GENERAL (FBC)
Electric Auto Choke System
In the carburetor electric choke system, a bimetal choke spring
is heated by an electric heater (PTC heater*).
As the bimetal spring is heated by the heater after start-up, the
bimetal opens the choke valve gradually by thermal expansion
and pushes down the stopper lever.
The lower the temperature when the engine is started, the
tighter the bimetal closes the choke valve, thus improving at cold
weather starting.
*PTC heater : Positive Temperature Coefficient heater
3 1 - 9 0
GENERAL (FBC)
1. Choke Valve and Fast Idle Cam Operation
1) Before starting the engine, the throttle valve is in normal
idle opening state.
2) Before starting the engine, depress the accelerator pedal
to the floor, and the fast idle cam will turn clockwise.
Release the accelerator pedal, and the lever will ride on
the fast idle cam and the throttle valve will open.
3) When the engine starts, the intake manifold vacuum is
applied to the choke breaker to slightly open the choke
valve, preventing a rich air-fuel mixture.
4) Shortly after starting of engine, the bimetal is heated by
the heater and expands to open the choke valve gradually
and push down the stopper lever.
At this time, the engine speed increases gradually.
5) Depress the accelerator pedal, and the fast idle cam will
turn counterclockwise. Release the accelerator pedal and
the lever will ride on the lower step of fast idle cam and
the throttle valve will close slightly, decreasing the
engine speed. After warming up the engine for a while,
depress the accelerator pedal and the throttle valve will
be further closed.
By repeating this procedure, the fast idle cam is released
and the throttle valve comes to have a normal idle
opening.
3 1 - 9 1
GENERAL (FBC)
2. Operation of Choke Opener
If the engine has been started with the throttle valve lever
on the highest fast idle cam step then the engine speed will
increase with the engine coolant temperature. This results
in the engine overrun. In order to prevent such overrun, the
choke opener is provided.
1) When the thermo valve closes as the engine coolant
temperature rises [65°C (149°F)], the intake manifold
vacuum acts on the fast idle breaker.
2) The fast idle breaker forces the fast idle cam to
counterclockwise so that the lever will rest on the lowest
detent of cam, closing the throttle valve to decrease the
engine speed.
3. Electric Auto Choke Relay
The electric choke relay is normally closed (ON) and it opens
when its coil is energized.
During engine cranking or for approx. 80 seconds at an
engine coolant temperature of -10 to 18°C (-14 to 64°F),
the ECU energizes the electric choke relay coil. This prevents
heating of the electric choke heater, until the engine has
started.
3 1 - 9 2
SERVICE ADJUSTMENT PROCEDURES (FBC)
FBC SYSTEM
Inspection
If FBC system components (sensors, carburetor control unit--
computer, solenoid, etc.) fail, one of the following situations may
be encountered.
2. Unstable idle.
If any of above conditions is noted, first perform basic engine
checks (ignition system malfunctions, incorrect engine
adjustment, etc.). The FBC system can be checked by use of
FBC checker and FBC harness connector. Inspection
procedure is as follows.
CAUTION
1) Before battery terminals are disconnected, make sure
that ignition switch is OFF. If battery terminals are
disconnected while engine is running or when ignition
switch is in ON position, malfunction of computer
could result.
2) Disconnect battery cables before charging battery.
3) When battery is connected, be sure not to reverse
polarity.
4) Make sure that harness connectors are securely
connected. Take care not to allow entry of water or
oil into connectors.
1.
2.
3.
4.
5.
6.
Turn ignition switch to OFF.
Remove the harness connector “A” (13 poles) and connector
“B” (7 poles) from carburetor control unit (computer).
Set check switch of FBC checker to OFF.
Set select switch of checker to A.
Connect the FBC harness connector to the connectors of FBC
checker, and then connect FBC harness connector to
carburetor control unit and harness connectors. Place FBC
checker on front passenger’s seat.
Perform checks according to the “FBC System Check
Procedure Chart”.
7.
8.
9.
If check shows any departure from specifications, check
corresponding sensor and related electrical wiring, repair or
replace.
After repair or replacement, recheck with FBC checker to
confirm that repaired or replaced parts is performing well.
3 1 - 9 3
10. Turn the ignition switch to OFF.
11. Disconnect connectors of FBC checker and FBC harness
connector from carburetor control unit and body side harness
connectors.
12. Connect body side harness connector to carburetor control
unit.
Check Procedure Chart
3 1 - 9 4
3 1 - 9 5
IDLE SPEED CHECK AND ADJUSTMENT
Checking Conditions:
o Engine coolant temperature is 80 to 95°C (176 to 205°F).
o Engine lubricant temperature is over 80°C (176°F).
o Lights, electric cooling fan and all accessories are off.
o Transaxle is in neutral.
1. Set timing light and tachometer.
2. Start the engine and let it idle.
3. Check the basic ignition timing and adjust if necessary.
Ignition timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . BTDC 5° ± 1°
NOTE
When the basic ignition timing is to be adjusted at a high
altitude, disconnect the vacuum hose (yellow stripe hose)
from the distributor sub-vacuum chamber and temporarily
close the disconnected hose end with an appropriate plug.
4. Run the engine for more than 5 seconds at an engine speed
of 2,000 to 3,000 rpm.
5. Run the engine at idle for 2 minutes.
6. Set the engine speed to the specified valve body adjusting
the idle speed adjusting screw No. 1 (SAS-1).
Curb idle rpm . . . . . . . . . . . . . . . . 700 ± 50 rpm
CAUTION
Do not touch SAS-2. The idle speed adjusting screw
(SAS-2) is the preset screw that determines the relationship
between the throttle valve and free lever, and has
been accurately set at the factory. If this setting is
disturbed, throttle opener adjustment and dash pot
adjustment cannot be done accurately.
3 1 - 9 6
THROTTLE OPENER ADJUSTMENT
For Operation Under Electrical Load
The procedure that follows is to check and adjust the idle speed
control operation of the throttle opener when electric load is
applied.
1.
2.
3.
4.
5.
6.
Make sure curb idle speed is within the specified speed. If
outside the specified limits, readjust the speed to the
nominal specification.
By using the auxiliary lead wire, activate the idle-up control
solenoid valve, apply the intake manifold vacuum to the
idle-up actuator and activate the idle-up actuator.
Open the throttle slightly (to an engine speed of about 2,000
rpm), and then slowly close it.
Adjust the engine speed to the specified speed with the
idle-up adjusting screw.
Throttle opener adjusting rpm (For electrical load)
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 800 ± 50 rpm
After repeating step 3, check the engine speed.
Remove the auxiliary lead wire used in step 2, and reconnect
the idle-up solenoid valve wiring.
For Operation Under Air Conditioner Load
control operation of the throttle opener when air conditioning
load is applied.
1.
2.
3.
4.
5.
Start the engine.
Set the tachometer
Turn on the air conditioner switch.
NOTE
The solenoid valve with open and the intake manifold
vacuum will act on the throttle opener to fully actuate it.
Check the engine speed during this operation.
Throttle opener adjusting rpm (For A/CON). . . . . . . . . . . . . .
900 ± 25 rpm
If the engine speed is out of specification, adjust using the
throttle (for air conditioner) adjusting screw.
3 1 - 9 7
THROTTLE POSITION SENSOR (TPS)
ADJUSTMENT
1. Loosen the accelerator cable enough.
2. Loosen the speed adjusting screw No. 1 (SAS 1) and No. 2
(SAS 2) sufficiently to close the throttle valve completely.
Record the number of turns loosened.
NOTE
Turning the screw counterclockwise closes the valve.
At this time, the fast idle control should have been
released (the lever not resting on the fast idle cam).
3. Connect voltmeter (digital type) between 2 and 3 of TPS
connector pins.
NOTE
Do not disconnect the TPS connector from the chassis
harness.
4. Turn the ignition switch to ON. (Engine will not start.)
5. Measure the TPS output voltage.
Standard value : 250 mV
6. If the output voltage is not correct turn the TPS body to
adjust to specification.
NOTE
Turning the TPS body clockwise increases the output
voltage.
7. Turn the ignition switch to OFF.
8. Tighten SAS 1 and SAS 2 by the same number of turns as
loosened in step (2) to return them to initial state.
9. Adjust free play of the accelerator cable.
10. Start the engine and check that the idle speed as specified.
3 1 - 9 8
DASH POT CHECK AND ADJUSTMENT
o Engine coolant temperature : 80 to 95°C (176 to 205°F).
o Lights, electric cooling fan and accessories : Set to OFF
o Transaxle : Neutral.
1. Start the engine and run at idle.
2. Open the throttle valve for full stroke of the rod until the
free lever contacts SASS.
3. Close the throttle valve until SAS2 contacts the free lever
and check the engine speed at that moment.
4. If engine is not as specified, adjust dash pot setting by
turning SAS3.
5. Release the free lever and verify that the engine returns to
idle speed slowly.
3 1 - 9 9
ELECTRIC CHOKE SYSTEM CHECK AND INSPECTION
CAUTION
All carburetors have a tamper-proof choke. The choke-related
parts are factory adjusted. The choke adjustment is not
required during service, except when major carburetor
overhaul or choke calibration related parts adjustments are
needed by state or local inspections.
1. Check that the alignment marks on the electric choke and
bimetal assembly are lined up.
If not, align the marks.
Misalignment Symptom
Clockwise deviation Better startability but plugs more
likely to be sooty
Counterclockwise Poorer startability and more likely
deviation to stall
2. Check that the engine coolant temperature is below 10°C
(50°F).
3. Start the engine and check operation of the choke valve and
fast idle cam, with hand on the electric choke body.
Electric choke body Gets gradually hotter after engine start
Choke valve Opens as bimetal temperature rises
Fast idle cam Fast idle control is released as engine
coolant temperature rises and fast idle
breaker operates
4. If the electric choke body remains cool even after the engine
is started, check the electric choke.
3 1 - 1 0 0
INSPECTION OF CHOKE BREAKER SYSTEM
o Check conditions of the choke valve according to procedures given in the table below.
Engine coolant
temperature
Lower than
10°C (50°F)
Lower than
10°C (50°F)
Checking condition Normal choke valve operation Probable cause of trouble
Before engine start Closes fully
Start engine and run idle
(fully depress accelerator
pedal and then start)
Opens slowly and slightly
(immediately after starting)
[gap approx. 1.5 mm (0.059
in.)]
Faulty bimetal assembly
of linkage operation
o Clogged delay valve
o Broken diaphragm
(chamber A)
Disconnect vacuum hose
(yellow stripe) from choke
breaker during idling
Stationary o Faulty thermo valve
Step
1
2
3 Lower than
10°C (50°F)
4 Higher than
25°C (77°F)
Connect vacuum hose
(yellow stripe) and run
engine idle
When closed lightly with
finger, stops at larger opening
than step 2 [gap approx. 3 mm
(0.118 in.)]
o Broken diaphragm
(chamber B)
3 1 - 1 0 1
1. After inspection of the choke breaker system, disconnect the
vacuum hose from the choke breaker and make the following
check.
2. With the engine idling, close the choke valve lightly with a
finger until the choke valve stops. Then, measure the choke
valve to choke bore clearance.
Standard value : 1.4-1.6 mm (0.055-0.063 in.)
3. If the clearance is not as specified, stop the engine, remove
the bimetal assembly and adjust the rod end opening for
standard clearance.
NOTE
When removing the bimetal assembly, put a mark on the
Information
4. Reconnect the removed yellow stripe vacuum hose and
measure the choke valve to choke bore clearance as in step
(2).
Standard value : 2.0-3.1 mm (0.114-0.122 in.)
5. If the clearance is out of specification, adjust by the adjusting
screw.
Information
Adjusting screw
turning direction
Clockwise
Counterclockwise
3 1 - 1 0 2
Valve
clearance
Small
Large
Expected result
plug more likely to get
sooty
Poor startability and stall
more likely
Fast Idle And Adjustment
Inspection Conditions
o Lights, electric cooling fan and accessories : Set to OFF.
o Air cleaner : Removed
o Tachometer installed
1. Disconnect the vacuum hose (white stripe) from the choke
opener.
2. Set the lever on the second highest step of fast idle cam.
3. Start the engine and check the fast idle speed.
Standard value:
Vehicles with a manual transaxle 2,800 rpm
Vehicles with an automatic transaxle 2,700 rpm
4. If the fast idle speed is out of specification, adjust with the
fast idle adjusting screw.
Information
Adjusting direction Valve Fast idle speed
Clockwise Large Increases
Counterclockwise Small Decreases
5. Connect the vacuum hose removed in step 1 to the choke
opener and check that the choke opener cancels fast idle.
Choke Heater Inspection
1.
2.
Disconnect the electric choke heater connector and check
continuity of the heater.
Normal state:
Should be conductive [approx. 60 resistance at 20°C
(68°F)]
If the heater is not conductive, replace the electric choke
body (Bimetal assembly).
3 1 - 1 0 4
INSPECTION AND ADJUSTMENT OF
ACCELERATOR CABLE FREE PLAY
1. Run the engine until it reaches the specified idle speed.
2. Confirm that the accelerator inner cable has no slack.
3. If it shows slack, adjust it as follows:
1) Loosen the adjusting nut so that the throttle lever is free.
2) Turn the accelerator adjusting nut to the point where the
throttle lever just starts moving, then back off one turn
and secure the lock nut.
FUEL GAUGE UNIT REPLACEMENT
1. Remove the plug located on the trunk floor.
2. Disconnect the fuel gauge unit connectors.
3. Remove the fuel gauge unit.
4. After installing the fuel gauge unit, confirm that the unit is
grounded.
5. When installing the plug on trunk floor, apply a specified
sealant around the plug mounting surface.
3 1 - 1 0 5
FUEL TANK (FBC)
FUEL TANK
COMPONENTS
REMOVAL
CAUTION
When removing parts such as a fuel tank, rear suspension,
etc., use a garage jack at the front of vehicle (Refer to
GENERAL GROUP), to prevent the vehicle from tilting.
When working on fuel tank, be sure the ignition is switched
off. Avoid any source of heat or sparks, such as lights,
smoking, etc.
Prior to working on the fuel tank or lines, remove the fuel filler
cap to release any pressure in the tank.
3 1 - 1 0 6
FUEL TANK (FBC)
1. Remove the drain plug to drain the fuel tank.
NOTE
Do not disconnect the in-tank filter except when the filter
is replaced.
2. Loosen the fuel hose (main and return) clamps and
disconnect the fuel hoses.
3. Disconnect the filler hose and breather hose from the filler
neck.
4. After removing the protector (if so equipped) and fuel tank
mounting band, drop the fuel tank slightly and disconnect the
fuel gauge unit harness.
5. Remove the fuel tank.
6. Remove the fuel gauge unit as necessary.
INSPECTION
Check the following and replace defective parts as necessary.
1.
2.
3.
4.
Leaky fuel tank
If leaks are evident, clean the fuel tank interior and exterior
and check for rust formation, corrosion, damage and cracks.
A badly corroded or damaged fuel tank should be replaced.
Clogged, cracked, damaged or rusty fuel pipe.
NOTE
When cleaning the fuel tank, avoid using cleaners which
may affect the terne-coated inside surface of the tank.
Use trichloroethylene, neutral emulsion type cleaner, etc.
Peeled or damaged pad on top of tank
If the pad is to be rebonded, clean the top surface of the tank,
apply adhesive to the entire pad bonding area, and bond the
pad securely.
Test two-way valve for proper operation.
outlet. If the air passes through after slight resistance, then
the valve is good.
INSTALLATION
1. Confirm that the pad is fully bonded to the fuel tank, then
install the fuel tank by tightening the tank band until its end
touches the floor.
2. Connect all hoses and tubes correctly.
CAUTION
When installing the hoses. Be sure not to mix up the
hoses.
Improper installation can cause fuel leakage.
3. Slowly slide the in-tank filter over the in-tank outlet pipe and
tighten the drain plug to the specified torque.
3 1 - 1 0 7
FUEL LINE (FBC)
FUEL LINE
COMPONENTS
3 1 - 1 0 8
FUEL LINE (FBC)
REMOVAL AND INSTALLATION
1. Pipes should be secured firmly with clips and clamps to
prevent looseness.
2. With the hoses and pipes are installed, make sure that they
are not distorted or loose.
3. Route the hoses and tubes correctly and fit their ends
securely.
4. Install clips and clamps in correct direction to make sure that
they do not interfere with neighboring objects.
INSPECTION
1. Check the hoses and pipes for cracks, bend, deformation,
deterioration or clogging.
2. Check the fuel filter for clogging or damage.
3. Check the canister for clogging.
4. Check the overfill limiter (two-way valve) and the fuel check
valve for malfunction.
Overfill Limiter Simple Test
A simple way of inspecting the overfill limiter is to remove, and
then air is lightly blown into either the inlet or outlet by mouth.
If the air passes after a slight resistance, overfill limiter is in good
condition.
5. Check purge control valve as follows:
1) Make sure that the engine coolant is between 80 and
95°C (176 and 205°F).
2) Disconnect the purge control hose from the carburetor
and blow into the purge hose. The valve should not allow
airflow. Then start the engine and increase the engine
speed to 1,500 to 2,000 rpm and blow into the purge
hose. If the valve is not open, check for clogged or broken
vacuum hose, or malfunctioning thermo valve.
FUEL FILTER REPLACEMENT
1. Remove the fuel tank cap to release the fuel tank pressure.
2. Disconnect the fuel hoses from the fuel filter, and then
remove the fuel filter.
CAUTION
1) Whenever the fuel filter is replaced, always inspect the
flex hoses for deterioration and cracking, and replace
as necessary.
2) Ensure the installation is secure and the fuel line
routing is in the original configuration.
3 1 - 1 0 9
FUEL PUMP (FBC)
FUEL PUMP
REMOVAL
1. Disconnect the battery ground cable.
2. Disconnect the fuel inlet, outlet and return hoses at fuel
pump.
3. Remove the two fuel pump mounting bolts, and remove the
fuel pump and push rod.
4. Remove the fuel pump gaskets and insulator.
INSPECTION
Checking Leakage
If there is oil or fuel leaks from breather hole, oil seal or
diaphragm in fuel pump is defective. Replace fuel pump
assembly.
3 1 - 1 1 0
FUEL PUMP (FBC)
Inlet Valve Test
To test the inlet valve, connect a vacuum gauge on the inlet
fitting while the line is disconnected.
1. Start engine or turn over with starting motor.
2. There should be a noticeable vacuum present.
3. If blow-back is present, inlet valve is not seating properly and
a new pump should be installed.
4. If fuel pump does not perform to above test requirements,
a new fuel pump should be installed.
Pressure Test
1. Disconnect the hose at the carburetor and connect a fuel
pressure gauge.
2. Disconnect the fuel return hose from the pump and plug the
fuel pump return pipe as shown in illustration.
3. Check pressure while the engine is idling. Replace the pump,
if required.
Standard pressure (at camshaft rpm 2,500). . . . . . . . . . . . . .
19-25 kPa (0.19-0.26 kg/cm2, 2.76-3.63 psi)
Fuel Flow Rate Test (Volume)
1. Disconnect the carburetor fuel hose and insert the end into
a beaker.
2. Disconnect the fuel return hose from the fuel pump and plug
the fuel pump return pipe.
3. Start the engine and measure the amount of fuel pumped
within one minute.
Volume (at camshaft rpm 2,500). . . . . . . . . . . . . . . . . . . . . . . .
0.6 lit/min. (0.85 U.S.qt, 0.72 Imp.qt.)
INSTALLATION
1. Turn crankshaft to place piston in No. 1 cylinder at top dead
center on compression stroke.
NOTE
This is to minimize cam lift for ease of installation.
2. Insert the push rod into the cylinder head.
3. Install the new gasket and insulator, and then install the fuel
pump. Tighten the bolts firmly.
4. Reconnect the fuel hoses to the fuel pump nipples and install
the hose clamps.
5. Start and run the engine. Check for fuel or oil leak.
3 1 - 1 1 1
FUEL PUMP (FBC)
FUEL PUMP TROUBLESHOOTING
3 1 - 1 1 2
CARBURETOR
CARBURETOR
CONSTRUCTION
3 1 - 1 1 3
CARBURETOR
COMPONENTS
1. Throttle return spring
2. Damper spring
3. Throttle return spring bracket
4. Throttle opener/dash pot
5. Hose
6. Vacuum delay valve
7. Hose
8. Screw
9. Pin
10. Float
11. Needle valve
12. Needle valve seat
13. O-ring
14. Packing
15. Retainer
16. Feedback solenoid valve (FBSV)
17. O-ring
18. O-ring
19. Retainer
20. Slow cut solenoid valve (SCSV)
21. O-ring
22. O-ring
23. Plate
24. Bimetal assembly
25. Packing
26. Connector
27. Cover
28. Diaphragm
29. Spring seat
30. Spring
31. Housing
32. Spring
33. Diaphragm
34. Valve
35. Mixture control valve (MCV) assembly
36. Gasket
37. Cover
38. Spring
39. Diaphragm
40. Body
41. Spring
42. Diaphragm
43. Bracket
44. Cover
45. Spring
46. Diaphragm
47. Body
48. Main air jet (primary)
49. Pilot jet (primary)
50. Pilot jet (secondary)
51. Float chamber cover
3 1 - 1 1 4
CARBURETOR
COMPONENTS
52. Bracket
53. Float chamber cover gasket
54. Steel ball
55. Weight
56. Ball
57. Plug
58. O-ring
59. Ball
60. Screw
61. Gasket
62. Main jet (primary)
63. Main jet (secondary)
64. Cover
65. Spring
66. Diaphragm
67. Enrichment jet valve 82. Throttle lever
68. Enrichment jet 83. Cam follower
69. Spring 84. Fast idle adjusting screw
70. Ball 85. Free lever
71. Pump cover assembly 86. Abutment plate
72. Diaphragm 87. idle speed adjusting screw (SAS-2)
73. Spring 88. Spring
74. Pump body 89. Secondary lever
75. Gasket 90. Idle speed adjusting screw (SAS-1)
76. Mixing body 91. Plug
77. Vacuum hose 92. Mixture adjusting screw (MAS)
78. Depression chamber 93. Throttle body
79. Throttle position sensor (TPS)
80. Lever
94. Idle speed adjusting screw (SAS-3)
81. Adjusting screw
3 1 - 1 1 5
CARBURETOR
REMOVAL
1. Disconnect battery ground cable.
2. Remove air cleaner.
3. Disconnect the throttle cable from carburetor.
4. Disconnect the vacuum hoses from carburetor.
5. Disconnect connectors for solenoid valves and TPS.
6. Place a container under fuel fittings of carburetor to catch
any fuel that may be trapped in fuel line and disconnect the
fuel hoses from the carburetor inlet nipples.
7. Remove carburetor mounting bolts and carefully remove the
carburetor from engine. Hold carburetor level to avoid spilling
fuel from fuel bowl.
DISASSEMBLY
1. Remove the throttle return spring from the throttle lever and
throttle return spring bracket unscrewing two screws.
2. Remove the dash pot rod from the free lever.
3. Unscrewing two screws, remove the bracket with two
connectors and off the connectors.
3 1 - 1 1 6
CARBURETOR
4. Pull the hose with delay valve off the nipple of choke breaker.
5. Remove the float chamber cover screws “B” to remove the
throttle body.
6. Remove the screws “A” to remove the float chamber cover
from main body.
7. To remove the float chamber cover assembly, insert a screw
driver blade between the enrichment cover and the float
chamber cover as illustrated and lightly pry and lift up slowly.
CAUTION
Do not apply excessive force.
8. Remove the pin and then remove the float and needle valve.
CAUTION
1) Do not let the float drop or supply collapsing load.
2) Use care not to damage the end of the needle valve.
CARBURETOR
9. Using flat blade screwdrivers, pry up the needle valve seat
at both edges to remove.
CAUTION
Use care not to damage the float chamber cover when
pushing up the needle valve seat.
10. Remove the retainer of the feedback solenoid valve (FBSV).
11. Using a screwdriver or other tool with a thin flat end, push
the stopper portion and remove the two terminals from
behind the connector.
NOTE
Unless the terminals are removed from the connector, the
feedback solenoid valve cannot be removed from the float
chamber cover.
12. Pull out the FBSV from the float chamber cover.
3 1 - 1 1 8
CARBURETOR
13. Remove the retainer and pull out the slow cut solenoid
valve.
14.
15.
16.
the stopper section and remove the two terminals from
To remove the bimetal assembly, grind away the head of the
two rivets of the bimetal assembly using a hand grinder or
other tool and remove the screw.
Remove the plate and the bimetal assembly.
17. Using a screwdriver or other tool with a thin flat end, push
the stopper section and remove the terminal from behind the
connector.
CARBURETOR
18. Remove the three screws attaching the Bowl Vent Valve
(BVV) cover to the float chamber.
19. Remove the plastic vent hosing, housing cover and the two
springs.
20. Remove the bowl vent valve diaphragm shaft.
CAUTION
Carefully pull the diaphragm out of the float chamber
cover so that rubber vent seal slides off the diaphragm
shaft.
NOTE
Be careful not to misplace the two small springs
positioned on either side of the plastic vent housing.
21. Unscrewing the three screws attaching the Mixture Control
Valve (MCV) assembly, remove the MCV assembly.
3 1 - 1 2 0
22. Remove the three screws attaching the choke vacuum
breaker cover, then remove the choke break cover, springs,
diaphragm and linkage assembly.
CARBURETOR
NOTE
Of the two diaphragm springs, the outer one is longer.
23. Remove the choke bracket.
24. Unscrewing the four screws, remove the choke opener.
3 1 - 1 2 1
CARBURETOR
25. Remove the pilot jets and main air jet.
NOTE
When removing the jets, use a screwdriver that is an exact
fit for their slot and work carefully to prevent damage.
26. Carefully lift and swing up the roll-over device weight from
the bottom of the float chamber, then use a magnet to
remove the roll-over steel ball.
NOTE
Remove the float chamber gasket and pour the remaining
fuel contained in the float chamber into a container.
27. Remove the accelerator pump outlet check ball and weight.
NOTE
Invert the chamber to remove the accelerator pump outlet
check ball and weight located at the gasket surface.
28. Separate the float chamber from the throttle body.
3 1 - 1 2 2
CARBURETOR
29. Remove the main jets.
NOTE
When removing the main jets, use a screwdriver that is
an exact fit and work carefully to prevent damage.
30.
31.
32.
Remove the three screws attaching the enrichment valve
cover to the enrichment housing on the float chamber.
Remove the cover, spring and diaphragm.
Unscrew the enrichment valve from the housing.
33. Using a screwdriver, loosen the enrichment jet and take out
the spring and ball from the enrichment jet valve.
CAUTION
The valve has many small parts. Do not lose them.
34. Remove the four screws (thread sealant supplied) attaching
the accelerator pump cover to the float chamber.
35. Remove the accelerator pump cover, diaphragm, spring,
pump body and gaskets.
3 1 - 1 2 3
CARBURETOR
NOTE
When reinstalling, apply thread sealant to the screws and
be sure the pump body, gasket and cover are properly
positioned.
36. Remove the E-clip and outside washer on the secondary
throttle shaft and slide the diaphragm spring link off the
throttle shaft.
37. Remove the two screws attaching the diaphragm bracket to
throttle body and remove the secondary throttle diaphragm.
38.
39.
40.
41.
Using a 10 mm wrench, remove the nut attaching the
accelerator pump lever to the throttle shaft.
With the impact driver, remove two screws attaching the
throttle position sensor to the throttle body.
Remove the E-clip holding the throttle position sensor onto
the throttle shaft.
For removal of plug, clamp carburetor in a vice and drill a
2mm (5/64 in.) pilot hole in the casting surrounding the idle
mixture adjusting screw (MAS) then redrill the hole to 3mm
(1/8 in.)
Insert a blunt punch into the hole and drive out plug.
3 1 - 1 2 4
REASSEMBLY
Perform reassembly in reverse of disassembly procedure, paying
special attention to the following items:
1. Clean all parts before assembly.
2. Check to be sure that no clogging is in the air passages and
fuel passages.
3. Check for smooth operation of throttle and choke linkage. If
the operation is not smooth, clean them up. Then may be
replaced at this time to ensure proper carburetor performance.
4. When replacing a main or a pilot jet, the old jet and the new
jet must be of the same size, because the jet is selected after
exact flow measurement by factory.
5. Do not reuse the O-rings and gasket. Replace them with new
ones at every reassembly.
Service Point of Reassembly
1. Make sure that correct jets are installed at correct positions.
Note the size symbol stamped on each jet for identification.
Identification mark
Main jet
Primary . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . # 83.8
Secondary . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . # 145
Pilot jet
Primary . . . . . . . . . . . . . . . . . . . . . . .. . . . . ... # 46.3
Secondary. . . . . . . .. . . . . . . . . . . . . . . . . . . . . . . # 70
2. Bimetal assembly
1) Fit the bimetal end over the choke valve lever.
CARBURETOR
2) Install the plate and temporarily tighten the screw.
3) Align the mating marks.
4) Set the rivet as illustrated.
7) Install terminal to the connector at correct position.
5) While keeping the mating marks aligned, install the
bimetal assembly with a hand riveter or similar tool.
6) Tighten the screw.
3 1 - 1 2 6
CARBURETOR
INSPECTION
General Description
Check the following and repair or replace parts if necessary.
1.
2.
3.
4.
5.
6.
7.
Check the fuel paths (jets) and air paths (jets or orifices) for
clogging. If clogged, wash thoroughly with cleaning solvent
or detergent and blow by compressed air. Do not use metal
wire or other metal pieces.
Check the diaphragms for damage and cracks.
Check that the needle valve operates lightly. If the valve is
hard to slide or is binding, repair or replace. If there is
overflow, poor valve to seat contact is suspected. Check
thoroughly.
Check the fuel inlet filter (located above the needle valve)
for clogging and damage.
Check the float operation. Check the float and lever for
deformation and damage and replace if necessary.
Check operation of the throttle valve, chock valve and link.
If they do not operate lightly, wash well and apply engine
oil sparingly to their shaft.
Check the float chamber cover and main body for damage
and cracks.
1. Apply battery voltage directly to the slow cut solenoid valve
terminals.
2. Check that the valve operates with a click.
3. Using a circuit tester, check that there is no continuity
between the solenoid valve body and terminals.
CARBURETOR
4. Measure resistance between the terminals.
SCSV coil resistance . . . . . . . . . . 48-60 fl [at 20°C (68°F)]
1. Apply battery voltage directly to the feedback solenoid valve
terminals.
2. Check that the valve. operates with a click.
3. Check that the jet is free from clogging.
4. Using a circuit tester, check that there is not continuity
3 1 - 1 2 8
CARBURETOR
5. Measure resistance between the terminals.
FBSV coil resistance . . . . . . . . . . . 54-66 0 [at 20°C (68°F)]
Bimetal Assembly
Using a circuit tester, measure resistance between the terminal
and body.
Bimetal resistance . . . . . . . . . . . . . Approx. 6 0 [at 20°C (68°F)l
Dash Pot
Check that the dash pot operates normally. Resistance must be
felt when the dash pot is pulled. When the rod is released it
must return quickly to the original position. If no resistance is
felt when it is pulled, the diaphragm or the check valve is broken.
If the rod returns slowly, the check valve is binding. In either
case, replace the dash pot.
Secondary Throttle Chamber (Depression Chamber)
Check the secondary throttle chamber diaphragm for damage.
First, push up fully and closing tightly the nipple with a finger,
release the rod. The diaphragm is intact if the rod does not return
to the initial position while the nipple is held closed with a finger.
If the rod returns, the diaphragm is broken. Replace the
secondary throttle chamber.
CARBURETOR
1. Measure resistance between terminals 1 and 2 of the
throttle position sensor.
TPS resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.5-6.5 Kn
2. Check the body for crack and damage.
Fast Idle Opening
1. Set the lever on the mark (scribed line) of fast idle cam.
2. Measure the primary valve to throttle bore clearance.
Fast opening (drill diameter)
M/T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.93 mm (0.037 in.)
A/T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.02 mm (0.040 in.)
3. If the clearance is out of specification, adjust using the fast
idle adjusting screw for the standard value.
Adjusting screw Valve opening
Clockwise Larger
Counterclockwise Smaller
Fast idle rpm
Increases
Decreases
3 1 - 1 3 0
CARBURETOR
Unloader Opening
1. Lightly press the choke valve with a finger to fully close it.
2. In this state, fully open the throttle valve and measure the
choke valve to choke bore clearance.
Standard value. . . . . . . . . 1.9-2.1 mm (0.075-0.083 in.)
3. If the clearance is out of specification, bend the throttle lever
at illustrated portion to adjust the clearance to the standard
value.
Choke Breaker
CAUTION
Check and adjust with the bimetal assembly removed.
2. Push the choke breaker rod toward the diaphragm and
measure the choke valve to choke bore clearance.
Standard value
1st stage . . . . . . 1.4-1.6 mm (0.055-0.063 in.)
2nd stage . . . . . . . 2.9-3.1 mm (0.114-0.122 in.)
3. If the clearance is out of specification, adjust by bending the
throttle lever at illustrated portion.
3 1 - 1 3 1
CARBURETOR
INSTALLATION
1.
2.
3.
4.
5.
6.
7.
8.
9.
Inspect the mating surfaces of carburetor and intake
manifold. Be sure both surfaces are clean and free of nicks,
burrs or other damage.
Place a new carburetor gasket on intake manifold surface.
Carefully place the carburetor on intake manifold.
Install carburetor mounting bolts and tighten alternately, a
little at time, to compress carburetor gasket evenly. The bolts
must be drawn down tightly to prevent vacuum leakage
between the carburetor and intake manifold.
Connect the throttle cable, vacuum hoses and fuel hoses.
Check carefully for worn of loose vacuum hose connections.
Check to be sure the choke valve opens and closes fully
when operated.
Check to see that full throttle travel is obtained.
Install air cleaner. The air cleaner should be cleaned or
10. Connect battery cable.
CAUTION
The practice of priming an engine by pouring gasoline into
the carburetor air horn for starting after servicing the fuel
system should be strictly avoided. Cranking the engine and
priming by depressing the accelerator pedal several times
should be adequate.
11. Set carburetor idle speed and mixture adjustment.
3 1 - 1 3 2
ENGINE CONTROL (FBC)
ENGINE CONTROL
REMOVAL
Accelerator Cable
1. Loosen the accelerator cable adjusting nut.
2. Disconnect the accelerator cable from either the throttle
lever.
3. Disconnect the accelerator cable from the accelerator arm.
4. Disconnect the accelerator cable guide from the fire wall,
and then remove the accelerator cable.
Accelerator Pedal
1. Loosen the accelerator cable adjusting nut, and disconnect
the accelerator cable from the accelerator arm and remove
the accelerator pedal.
2. Remove the return spring from the accelerator arm.
3. Remove the cotter pin from the accelerator arm shaft, and
then remove the accelerator arm from the accelerator arm
bracket.
INSPECTION
1. Check the inner and outer cables for damage.
3. Check the accelerator arm for bending.
5. Check for connection of accelerator cable to end fitting.
INSTALLATION
1. Apply the specified multipurpose grease around the each
moving point of the pedal.
Recommended multipurpose grease . . . . . . . . . . . . . . . . . . . . .
grade #2 or equivalent
3 1 - 1 3 4
2.
3.
4.
5.
To prevent entry of exhaust fumes, apply semi-drying type
sealant to the bolt mounting hole, and then tighten the
Make sure that the accelerator cable is laid without sharp
bends.
Inspect the play of accelerator cable.
Install parts and torque to specification.
3 1 - 1 3 5
giacvecad
GENERAL
SPECIFICATIONS
Fuel tank
Capacity
Fuel filter
Type
Fuel pump
Type
Driven by
Throttle body
Type
Resistance
Output voltage at curb idle
Idle speed control (ISC) servo motor
Type
Resistance
Idle position switch
Type
Motor position sensor (MPS)
Type
Resistance
Input sensor
Air flow sensor (AFS)
Type
Intake air temperature sensor
Type
Resistance
Coolant temperature sensor
Type
Resistance
Oxygen sensor
Type
Vehicle speed sensor
Type
45 lit. (11.9 U.S. gal., 9.9 lmp.gal.)
High pressure type
Electrical, in-tank type
Electric motor
3.5-6.5 KD
0.48-0.52 V
Electric motor
5-35 fl at 20°C (68°F)
Contact type within ISC servo
Approx. 4-6 Kn
Karman vortex type
Thermistor type
2.33-2.97 Kn at 20°C (68°F)
Thermistor type
2.5 Kfi at 20°C (68°F)
0.3 Kfi at 80°C (176°F)
Zirconia sensor
Reed switch type
3 1 - 2
GENERAL
No. 1 cylinder TDC sensor
Type
Crankshaft angle sensor
Type
Output actuator
Injector
Type
Number
Coil resistance
Purge control solenoid valve
Type
EGR control solenoid valve [California Only]
Type
Fuel pressure regulator
Regulated pressure
Photo diode sensor
Photo diode sensor
Electromagnetic type
4
13-16 R at 20°C (68°F)
ON/OFF type
Duty cycle type solenoid valve
330 kPa (3.35 kg/cm2, 48 psi)
SEALANT
Water temperature sensor ass’y LOCTITE 962T or equivalent
3 1 - 3
SERVICE STANDARD
Curb idle speed
Throttle-position sensor (TPS) adjustment voltage
BTDC 5° ± 2° at curb idle
700 ± 100 rpm
0.48-0.52V at curb idle
TIGHTENING TORQUE Nm Kg.cm lb.ft
Delivery pipe installation screw
Water temperature gauge unit
Oxygen sensor
Throttle position sensor (TPS) installation screw
Fuel pressure regulator lock nut
High pressure hose and fuel main pipe eye bolt
High pressure hose and fuel filter
Fuel pump assembly to fuel tank
High pressure hose at fuel tank
Throttle body to surge tank
Fuel filter mounting bolt
1 0 - 1 3 100-130 7.2-9.4
2 0 - 3 9 200-400 1 5 - 2 9
1 0 - 1 2 100-120 7.2-8.7
3 8 - 4 9 400-500 2 9 - 3 6
1.5-2.5 1 5 - 2 5 1 . 1 - 2
7 - 1 1 7 0 - 1 1 0 5 - 8
2 9 - 3 9 300-400 2 2 - 2 9
2 5 - 3 4 250-350 1 8 - 2 5
2 - 3 2 0 - 3 0 1.5-2.2
1 5 - 2 5 150-250 1 1 - 1 8
9 - 1 4 9 0 - 1 4 0 6.5-10
3 1 - 4
GENERAL
SPECIAL TOOLS
3 1 - 5
TROUBLESHOOTING
When checking and correcting engine troubles, it is important
to start with an inspection of the basic systems. If one of the
following conditions exists, (A) engine start failure, (B) unstable
idling or (C) poor acceleration, begin ‘by checking the following
basic systems.
1. Power supply
1) Battery
2) Fusible link
3) Fuse
2. Body ground
3. Fuel supply
1) Fuel line
2) Fuel filter
3) Fuel pump
4. Ignition system
1) Spark plugs
2) High-tension cables
3) Distributor
4) Ignition coil
5. Emission control system
1) PCV system
2) EGR system
3) Vacuum leak
6. Others
1) Ignition timing
2) Idle speed
Troubles with the MPI system are often caused by poor
contact of the harness connectors. It is important to check
all harness connectors and verify that they are securely
connected.
3 1 - 6
GENERAL
MPI TROUBLESHOOTING PROCEDURES
PROBLEM
o Battery
1. Connection
2. Specific gravity, charging system
3. Drive belt
4. Voltage
o Fusible link
o Ignition switch
o Starter relay
o Starter
o Wiring
Trouble codes
o Using voltmeter
[Refer to page 31-32]
o Using MUT
[Refer to page 31-35]
Oil filler cap
o Oil dipstic
o Vacuum hose connections
o PCV hose
o EGR system
o High tension cables
o Distributor
o Ignition coil, power transistor
o Spark plug
3 1 - 7
GENERAL
o Ignition timing-adjust
[Refer to page 27-5]
3 1 - 8
o Fuel line (leakage, deformation)
o Fuse
o Fuel pump [Refer to page 31-24]
o Fuel filter
o Fuel pressure regulator
o Wiring connections
o Power to ECU
1. Fusible links
2. Fuses
3. MPI control relay
sensor
o Intake air temperature sensor
o Injection signal circuit
1. Injector wiring
2. ECU
o TPS
o AFS
GENERAL
PROBLEM
Rough idle or engine stalls
T r o u b l e C o d e s
[Refer to page 31--32]
o Using voltmeter
o Using MUT [Refer to page 31-35]
o Oil filler cap
o Oil dipstic
o PCV hose
o EGR system
o Fuses
o Fuel filter
Element-Clean or replace
Idle speed-Adjust
[Refer to page 31-20]
Ignition timing-Adjust
3 1 - 9
GENERAL
o Fuel pump [Refer to page 20-24]
o Fuel filter
o F u e l r e g u l a t o r
Injection condition
o Power to ECU
1. Fusible links
2. Fuses
sensor
1. Injector wiring
2. ECU
3 1 - 1 0
GENERAL
PROBLEM
Engine hesitates or accelerates poorly
o Clutch-slip
o Brake-drag
o Oil filler cap
o Oil dipstic
o Hose connections
o PCV hose
o EGR system
Trouble codes
o Using voltmeter
o Using MUT
o Distributor
o Ignition coil, ignition
o Fuel pump
o Fuel filter
3 1 - 1 1
3 1 - 1 2
GENERAL
Fuel Tank And Fuel Line
Symptom Probable cause
Engine malfunctions
due to insufficient fuel
supply
Bent or kinked fuel pipe or hose
Clogged fuel pipe or hose
Clogged fuel filter of in-tank fuel filter
Water in fuel filter
Dirty or rusted fuel tank interior
Malfunctioning fuel pump (Clogged filter
in the pump)
control system malfunctions
(when fuel filler
cap is removed, pressure
is released)
Incorrect routing of a vapor line
Folded, bent, cracked or clogged vapor line
Faulty fuel tank cap
Malfunctioning overfill limiter (Two-way
valve)
Remedy
Repair or replace
Clean or replace
Replace
Replace the fuel filter or clean the
fuel tank and fuel lines
Clean or replace
Replace
Correct
Correct
Replace
Replace
3 1 - 1 3
MPI SYSTEM
MPI SYSTEM
GENERAL INFORMATION
The basic function of the MPI (Multi-Point Injection) system is
to control the air-fuel ratio, based on data from various sensors.
The MPI system is composed of three basic systems: Fuel, Intake
and Electronic Control.
Fuel System
Fuel is supplied under constant pressure to the injectors by an
electric fuel pump in the fuel tank. The pressure is controlled
by the pressure regulator. Based on ECU signals, the injectors
inject fuel jnto the intake manifold in the correct firing order.
Intake System
The flow rate of the intake air is measured by the AFS (Air Flow
Sensor) in the air cleaner. The amount of intake air during idling,
warm-up and deceleration is controlled by the ISC (Idle Speed
Control) servo through the ECU.
Electronic Control System
The electronic control system is composed of sensors, which
monitor engine conditions, and the Electronic Control Unit (ECU),
which calculates the injection timing and air/fuel ratio according
to the signals from the sensors.
The sensors convert such conditions as the amount of intake air,
amount of oxygen in the exhaust gas, coolant temperature,
intake air temperature, engine speed, and vehicle speed into
electrical signals, which are sent to the ECU.
Analyzing these signals, the ECU determines the amount of fuel
to inject and drives the injectors. The fuel injection is sequential
injection type, in which four injectors are sequentially driven.
During idling, the ISC Servo is driven according to engine load
to assure stable idling.
3 1 - 1 4
MPI SYSTEM
LOCATION OF COMPONENTS
A. Air conditioner relay
B. Air flow sensor
C. ISC servo (Motor position sensor)
D. Throttle position sensor
E. Coolant temperature sensor
F. Power transistor
G. Crankshaft angle sensor
H. injector
I. Oxygen sensor
J. Inhibitor switch
K. MPI control relay
L. Diagnosis terminal
M. Vehicle speed sensor
N. Electronic control unit
O. EGR temperature sensor (California vehicles only)
P. Power steering oil pressure switch
Q. Purge control solenoid valve
R. EGR control solenoid valve
3 1 - 1 5
MPI SYSTEM
3 1 - 1 6
MPI SYSTEM
MPI SYSTEM
3 1 - 1 8
MPI SYSTEM
Idle Speed Check Procedure
CAUTION
The improper setting (throttle valve opening) will increase
exhaust gas temperature at deceleration, reducing catalyst life
greatly and deteriorating exhaust gas cleaning performance.
It also has effect on fuel consumption and engine braking.
Checking conditions:
o Transaxle is in neutral [“P” or “N” range for A/T vehicles].
o Steering wheel is a straight ahead position (Vehicles with
power steering).
1.
2.
3.
4.
5.
6.
Install the tachometer and the timing light, or connect the
multi-use tester to the diagnostic connector in the fuse box.
Run the engine at curb idle speed.
Refer to Group 27.
Read the idling rpm. If the multi-use tester is used, press
code No.22 and read the idling rpm. If it is not within the
specified valve, check the idle speed control system.
Curb idle rpm . . . . . . . . . . . . . . . . . . . . . . . . . . . 700 ± 100 rpm
Idle Speed Control (ISC) And Throttle Position
Sensor (TPS) Adjustment
Adjustment conditions:
power steering).
1. Loosen the accelerator cable.
2. Connect the multi-use tester to the diagnostic connector in
the fuse box.
3. If the multi-use tester is not used, install a tachometer and
a voltmeter.
3 1 - 2 0
MPI SYSTEM
4. Turn the ignition switch to ON (do not start the engine) and
leave it in that position for 15 seconds or longer; then check
to be sure that the idle speed control servo is fully retracted
to the curb idle position.
NOTE
When the ignition switch is turned to ON, the ISC plunger
extends to the fast idle position opening; then, after 15
seconds, it retracts to the fully close (curb idle) position.
Motor position sensor : 0.9V
5. Turn the ignition switch OFF.
6. Disconnect the ISC motor connector and secure the ISC
motor at the fully retracted position.
7. In order to prevent the throttle valve from sticking, open it
two or three times; then release it to let it click shut, and
sufficiently loosen the fixed SAS.
8. Start the engine and let it run at idle speed.
9. Check that the engine rpms are within the standard value.
If the multi-use tester is used, press code No. 22 and read
engine rpms.
10. If the engine speed is not as specified, adjust the ISC
adjusting screw to obtain the standard rpm.
NOTE
1. The engine speed on a new vehicle driven less than
500 Km (300 miles) may be 20 to 100 rpm lower than
specification, but no adjustment is necessary.
2. If the engine stalls or the engine speed is low after the
vehicle has been driven a distance of 500 km (300
miles) or more, a deposit on the throttle valve area is
suspected. Clean the throttle valve area. [Refer to page
3 1 - 2 3 ]
11. Tighten the fixed SAS until the engine speed starts to
increase. Then, loosen it until the engine speed ceases to
drop (touch point) and then loosen a half turn from the touch
point.
12. Stop the engine.
3 1 - 2 1
MPI SYSTEM
13. Turn the ignition switch to ON (do not start engine) and
check that the TPS output voltage is as specified.
If the multi-use tester is used, press code No. 14 and read
the voltage.
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.48-0.52V
14. Connect a digital-type voltmeter between terminal 24 and
terminal 19 of the ECU, if the multi-use tester is not used.
NOTE
1. Do not disconnect the ECU connector from the ECU.
2. Use an accurate digital voltmeter.
15. If it is out of specification, loosen TPS mounting screws and
adjust by turning the TPS.
NOTE
Turning the TPS clockwise increases the output voltage.
CAUTION
Tighten the screws securely after adjustment.
16. Turn the ignition switch to the OFF position.
17. Adjust the accelerator cable play.
Standard value
A/T-4 . . . . . . . . . . . . . . . . . . . . . . . 3-5 mm (0.12-0.2 in.)
Except above.. . . . . . . . . . . . . . . 1-2 mm (0.04-0.08 in.)
18. Connect the ISC motor connector.
19. Disconnect the voltmeter, and connect the TPS connector.
20. Start the engine and check to be sure-that the idle speed
is correct.
21. Turn the ignition switch to OFF and disconnect the battery
terminal for 15 seconds and then re-connect. (This erases
the data stored in memory during the ISC adjustment).
3 1 - 2 2
MPI SYSTEM
Throttle Body (Throttle Valve Area) Cleaning
NOTE
Disconnect the air intake hose from the throttle body, and
check the throttle valve surface for carbon deposits, rotating
the valve. Apply the spray cleaning solvent on the valve to
remove carbon deposits.
1. Run the engine until warm.
2. Remove the air intake hose from the throttle body.
3. Spray cleaning solvent into the valve through the throttle
body intake port and leave it for about 5 minutes.
4. Start the engine, race it several times and let it idle for about
1 minute.
NOTE
If the idle speed becomes unstable (or if the engine stalls),
slightly open the throttle valve to keep the engine running.
5. Repeat steps 3 and 4.
6. Attach the air intake hose.
7. Disconnect the battery terminals and reconnect them more
than 10 seconds.
8. Adjust the idle speed control and throttle position sensor.
Fuel Filter Replacement
1. Reduce the internal pressure of the fuel pipes and hoses by
completing the following operations.
o Disconnect the fuel pump harness connector at the rear
of the fuel tank.
o Start the engine and after it stalls, turn the ignition
switch to OFF.
o Disconnect the battery negative (-) terminal.
o Connect the fuel pump harness connector.
2. Remove the eye bolts while holding the fuel filter nuts
securely.
CAUTION
Cover with a shop towel to avoid gasoline from splashing.
3. Remove the fuel filter mounting bolts, then remove the fuel
filter from the fuel filter clamp.
4. After replacing the fuel filter, check for fuel leaks.
MPI SYSTEM
Overfill Limiter (Two-way Valve) Replacement
1. Disconnect the vapor hoses and the overfill limiter.
Fuel Sender Replacement
1. Remove the fuel filler cap to lower the fuel tank’s internal
pressure.
2. Disconnect the harness connector from the fuel sender.
3. Remove the fuel sender unit installation screws, then
remove the fuel sender assembly from the fuel tank.
Fuel Pump Operation Check
1. Turn the ignition switch to OFF.
2. Apply battery voltage to the fuel pump drive connector to
check that the pump operates.
NOTE
The fuel pump is in-tank type and its operating sound is
hard to hear without removing the fuel filler cap.
3. Pinch the fuel hose to check that fuel pressure is felt.
3 1 - 2 4
MPI SYSTEM
Fuel Pressure Test
1.
2.
3.
4.
5.
6.
the following procedures.
1) Disconnect the fuel pump harness connector at the rear
of the fuel tank.
2) Start the engine and after it stalls, turn the ignition
switch to OFF.
3) Disconnect the battery negative (-) terminal.
4) Connect the fuel pump harness connector.
Remove the upper, eye bolt while holding the fuel filter nut
securely.
CAUTION
Cover the hose connection with a shop towel to prevent
splashing of fuel caused by residual pressure in the fuel
line.
Using the fuel pressure gauge adapter (09353-24000),
install the fuel-pressure gauge to the fuel filter. Tighten the
bolt to the specified torque.
Tightening torque
Fuel pressure gauge to fuel filter . . . . . . . . . . . . . . . . . . . . .
25-34 Nm (250-350 kg.cm, 18-25 lb.ft)
Connect the battery’s negative (-) terminal.
Apply battery voltage to the terminal for the pump drive and
activate the fuel pump; then, with fuel pressure applied,
check that there is no fuel leakage from the pressure gauge
or connection part.
Disconnect the vacuum hose from the pressure regulator,
and plug the hose end. Measure the fuel pressure at idle.
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
320-340 kPa (3.26-3.47 kg/cm2, 46-49 psi)
3 1 - 2 5
MPI SYSTEM
7. Measure the fuel pressure when the vacuum hose is
connected to the pressure regulator.
Approx. 270 kPa (2.75 kg/cm2, 39 psi)
8. If the results of the measurements made in steps (6) and
(7) are not within the standard value, use the table below
to determine the probable cause, and make the necessary
repairs.
Condition
Fuel pressure too low
Fuel pressure too high
There is no difference in
vacuum hose is connected
and when it is not.
Probable cause
a. Clogged fuel filter.
b. Fuel leakage to the return side, caused by
poor seating of the valve within the
fuel-pressure regulator
c. Low discharge pressure of the fuel pump
a. Sticking valve within the fuel-pressure
regulator
b. Clogged or bent fuel return hose or pipe.
a. Clogging, or damaged vacuum hose or the
nipple
b. Sticking or poor seating of the valve in the
fuel-pressure regulator.
9. Stop the engine and check for a change in the fuel pressure
gauge reading, which should hold for approximately 5 minutes.
If the gauge indication drops, observe the rate of drop.
Determine and remove the causes according to the following
table.
Remedy
a. Replace fuel filter
b. Replace fuel pressure regulator
c. Check the in-tank fuel hose for
leakage or replace the fuel pump
a. Replace fuel pressure regulator
b. Repair or replace hose or pipe.
a. Repair or replace the vacuum
hose or the nipple
Condition
Fuel pressure drops
slowly after engine is
stopped
Fuel pressure drops immediately
after engine is
stopped
Probable cause Remedy
a. Injector leakage a. Replace injector
a. The check valve within the fuel pump is a. Replace fuel pump
open
3 1 - 2 6
MPI SYSTEM
10. Reduce the fuel pressure in the fuel line.
11. Disconnect the high pressure hose and remove the fuel
pressure gauge from the delivery pipe.
CAUTION
line.
12. Install a new O-ring in the groove at the end of the
high-pressure hose.
13. Connect the high pressure fuel hose to the delivery pipe, and
tighten the screws to the specified torque.
14. Check for fuel leaks.
o Apply battery voltage to the fuel pump drive terminal to
operate the fuel pump.
o With pressure, check the fuel line for leaks.
EGR VALVE Control Vacuum Check
Checking Condition
Engine coolant temperature: 80-95°C (176-205°F)
1. Disconnect the vacuum hose from the throttle body EGR
vacuum fitting and connect a hand vacuum pump to the
fitting.
2. Start the engine and check to see that, after increasing the
engine speed, vacuum raises proportionately to engine
speed.
NOTE
If there is a problem with the change in vacuum, it is
possible that the throttle body port may be restricted and
require cleaning.
3 1 - 2 7
MPI SYSTEM
Purge Port Vacuum Check
Checking Condition
1. Disconnect the vacuum hose from the throttle body purge
hose fitting and connect a vacuum pump.
engine speed, vacuum remains fairly constant.
NOTE
If there is no vacuum created, it is possible that the
throttle body port may be restricted and require cleaning.
3 1 - 2 8
MPI SYSTEM
MPI SYSTEM INSPECTION
If the MPI system components (sensors, ECU, injector, etc.) fail,
interruption or failure to supply the proper amount of fuel for
engine operating conditions will result. Therefore, the following
situations will be encountered.
1. Engine is hard to start or does not start at all.
2. Unstable idle.
3. Poor driveability.
If any of the above conditions are noted, first check for any ECU
diagnostic codes and then perform basic engine checks (ignition
system malfunction, incorrect engine adjustment, etc.), and then
inspect the MPI system components with the multi-use tester
(MUT) service data test.
NOTE
1) Before removing or installing any part, read the diagnosis
code, then disconnect the battery negative (-) terminal.
2) Before disconnecting the cable from battery terminal, turn
the ignition switch to OFF. Removal or replacement of
battery cable during engine operation or while the ignition
switch is ON could cause damage to the ECU.
3) The harness between the ECU and the oxygen sensor is
shielded to prevent the influence of ignition noises and
radio interference. When the wire is faulty, the harness
must be replaced.
Malfunction Indicator Light
Among the self-diagnostic items, a malfunction indicator light
comes on to notify the driver of emission control items that are
malfunctioning.
However, when a signal returns to normal and the ECU senses
that it has returned to normal, the malfunction indicator light
goes out.
Immediately after the ignition switch is turned on, the
malfunction indicator light is lit for 2.5 seconds to indicated that
it is operating normally.
The MIL will come ON only while the engine is running and a
problem is detected.
Items Indicated By The MIL (Malfunction Indicator Light)
o Computer
o Oxygen sensor
o Air-flow sensor
o Throttle position sensor
3 1 - 2 9
MPI SYSTEM
o Motor position sensor
o Engine coolant temperature sensor
o Crank angle sensor
o No.1 cylinder top dead center sensor
o Barometric pressure sensor
o Injector
o Fuel pump
o EGR temperature sensor (California Vehicles Only)
SELF-DIAGNOSIS
The electronic control unit monitors the input/output signals at
all times.
When the ECU detects a problem for a specified time, the
electronic control unit memorizes the trouble code, and outputs
a signal to the self-diagnositc output terminal.
There are 14 diagnosis codes, including the normal code, that
can be read out with a voltmeter or the multi-use tester.
The diagnosis codes are memorized even if the ignition key is
turned off. The trouble codes will, however, be erased when the
battery terminal or the electronic control unit harness is
disconnected.
NOTE
If a sensor connector is disconnected with the ignition switch
turned on, a diagnosis code will be memorized. To erase any
diagnostic codes, disconnect the battery negative terminal (-)
for 15 seconds or more, and the ECU memory will be erased.
The 13 diagnostic codes are listed below, and if more than one
code is detected, they will be indicated sequentially from the
smallest to the largest code number.
Trouble code Diagnosis item Trouble code Diagnosis item
11 Oxygen sensor
12 Air-flow sensor
13 Intake air temperature sensor
14 Throttle position sensor
15 Motor position sensor
21 Engine coolant temperature sensor
22 Crank angle sensor
23
24
25
41
42
43
Vehicle-speed reed switch
Injector
Fuel pump
Vehicles Only)
3 1 - 3 0
CHECKING PROCEDURE (SELF-DIAGNOSIS)
CAUTION
1) If the battery voltage is low, no trouble codes will be
stored. Be sure to check the battery voltage before starting
the test.
2) Diagnostic codes will be erased if the battery or the ECU
harness is disconnected. Do not disconnect the battery
before the diagnostic codes are read.
3) After checks and repairs are completed, disconnect the (-)
ground cable for 15 seconds or more to make sure that
the codes are erased.
Inspection Procedure (Using Mlulti-Use Tester)
1.
2.
3.
4.
5.
6.
Connect the harness connector of the multi-use tester to the
Connect the power-source terminal of the multi-use tester
to the cigarette lighter socket.
Turn the ignition switch ON.
Use the multi-use tester to check the self-diagnostic codes.
After completion of the repair, turn the ignition switch OFF;
then disconnect the battery negative terminal for 15 seconds.
Then, check that no malfunction codes are displayed with the
multi-use tester.
7. Disconnect the multi-use tester.
NOTE
If a test is to be made during cranking, the power to the
cigarette lighter will be interrupted. Therefore, use the
separate battery harness for the multi-use tester.
3 1 - 3 1
MPI SYSTEM
Inspection Procedure (Using Voltmeter)
1. Connect the voltmeter to the self diagnosis connector.
2. Turn on the ignition switch, and indication of electronic
control unit memory contents will immediately start. If the
system is in normal operating condition, the pointer of
voltmeter indicates a normal pattern. If any abnormality is
in the memory, the pointer of voltmeter will deflect,
indicating an abnormal item as described in “Diagnosis
chart”.
After recording the abnormal item, check and repair each
part according to the check items in “Diagnosis Chart”
3. When the defective parts have been repaired, disconnect the
negative terminal of the battery cable for 15 seconds or
more, reconnect it to make sure that the abnormal code has
been erased.
Diagnosis Chart
output
Diagnosis
Trouble code
preference Check item (Remedy)
order item Output signal pattern No. Memory
1 Electronic - - (Replace electronic control unit)
control
unit
2 Oxygen 11 Retained o Harness and connector
sensor o Fuel pressure
o injectors
(Replace if defective)
o Intake air leaks
o Oxygen sensor
3 Air flow 12 Retained o Harness and connector
sensor (If harness and connector
are normal, replace air flow
sensor assembly)
3 1 - 3 2
MPI SYSTEM
output Diagnosis Trouble code
order item Output signal pattern NO. Memory
4 Air tem- 13 Retained o Harness and connector
perature o Air temperature sensor
sensor
5 Throttle 14 Retained o Harness and connector
position o Throttle position sensor
sensor o Idle position switch
6 Motor 15 Retained o Harness and connector
position o Motor position sensor
sensor
7 Engine 21 Retained o Harness and connector
coolant o Engine coolant temperature
temperature
sensor
sensor
8 Crank angle 22 Retained o Harness and connector
are normal, replace the
distributor assembly.)
9 No.1 cylin- 23 Retained o Harness and connector
der top (If harness and connector
dead center are normal, replace the
sensor distributor assembly.)
10 Vehiclespeed
sensor
(reed
switch)
24 Retained o Harness and connector
o Vehicle-speed sensor
(reed switch)
3 1 - 3 3
MPI SYSTEM
preference item Check item (Remedy)
order Output signal pattern No. Memory
11 Barometric 25 Retained o Harness and connector
pressure (If harness and connector
sensor are normal, replace the
barometric pressure sensor
assembly.)
12 Injector 41 Retained o Harness and connector
o Injector coil resistance
13 Fuel pump 42 Retained o Harness and connector
o Control relay
14 EGR* 43 Retained o Harness and connector
o EGR valve
o EGR control solenoid valve
o EGR valve control vacuum
15 Normal - - -
state
NOTE
1. Replace the ECU only when all other possible causes for a malfunction have been explored.
2. The diagnostic item marked * is applicable to the California vehicles only.
3 1 - 3 4
MPI SYSTEM
CHECKING (USING THE MULTI-USE TESTER)
1. Turn the ignition switch OFF.
2. Connect the harness connector of the multi-use tester to the
3. Connect the power-source terminal of the multi-use tester
4. Turn the ignition switch ON.
5. Use the multi-use- tester to make the system and sensor
checks.
NOTE
If the malfunction indicator light (engine-check light)
illuminates while the checks are being made, check the
self-diagnostic output.
6. After the repair, check again to be sure the problem has been
corrected.
7. Turn the ignition switch OFF.
8. Disconnect the multi-use tester.
9. Disconnect the battery negative terminal for 15 seconds or
longer. This erases the self-diagnostic code.
10. Restart the engine. Check (by a driving test and other means)
that the problem has been corrected.
NOTE
cigarette lighter will be interrupted, therefore, use the
Cranking Cheek (should be performed when the engine fails to start, or before starting the engine)
Item No.: Multi-use tester code number
Check points Check conditions
Battery voltage
o Service data
o Item No.16
o Ignition switch: ON
Test
specification
Probable cause of malfunction
11-13 v o Low battery voltage
o Power not supplied to the electronic
control unit
1) Check the power-supply circuit.
2) Check the ignition switch.
3) Check the control relay.
o Malfunction of the electronic control
unit ground circuit
3 1 - 3 5
MPI SYSTEM
Test
specification
Malfunction code
read out
o Self diagnostic
Fuel pump
o Actuator test
o Item No.7
o After holding for 15 seconds or Normal o Check in accordance with the diaglonger
with the ignition switch at nostic code.
“ON”, move the ignition switch to (Note that the diagnostic code will be
“LOCK” and disconnect the ISC erased if there is disconnection or
servo connector. damage to the electronic control unit
o Crank for four seconds or longer. back-up power-supply circuit.)
o Ignition switch: “ON” o If various diagnostic codes are output,
(Check for damage or disconnec- the most frequent cause is damage or
tion of the injector or crank angle disconnection of the power-supply or
sensor circuit.) ground circuit.
Try under both Pinch off The pulsations o Voltage is not supplied to the fuel
conditions: the return of the fuel flow pump.
o Engine cranking hose. can be felt. 1) Check the ignition switch (IG and
o Forced fuel pump ST)
activation
Listen closely The pump
to the fuel drive sound
2) Check the control relay.
tank. can be heard.
3) Check the related circuits.
o Malfunction of the fuel pump.
Crank angle sensor o Engine cranking Cranking Engine speed o If the tachometer reading is 0, there
o Service data o Tachometer con- speed (rpm) (rpm) is no interruption of the ignition coil
o Item No.22 nected (check, by
Approx. 200 Approx. 200
primary current.
using the tacho- 1) Check the power transistor and
meter for inter- the control circuit.
ruptions of the 2) Check the ignition coil and the coil
ignition coil power supply circuit.
primary current.) o If the multi-use tester’s indicated rpm
is abnormal
1) Malfunction of the crank angle
sensor circuit.
2) Malfunction of the crank angle
sensor.
3) Malfunction of the timing belt.
3 1 - 3 6
MPI SYSTEM
Check points
Injectors
o Service data
o Item No.41
Check conditions
o Engine cranking Listen for
operation
Engine
coolant
temperature
[°C (°F)]
0 (32)
20 (68)
80 (176)
Test
specification
Injectors o Injector malfunction.
should be o Improper contact of the connector and
heard control relay contacts.
Injector o Malfunction of the engine coolant
activation temperature sensor.
time o Malfunction of the ignition
(msec.) switch-ST.
Approx. 17
Approx. 35
Approx. 8.5
3 1 - 3 7
MPI SYSTEM
Sensor Check
Test
specification
Self-diagnostic
output
o Engine: idling
(2 minutes or more after engine
start)
diagnostic code.
be erased if there is disconnection
or damage of the engine control
unit back-up power-supply circuit.)
o If numerous diagnostic codes are
output, the most frequent cause is
damage or disconnection of the
power-supply or ground circuit.
Oxygen sensor
o Service data
o Item No.11
o Engine warm
(Make the
mixture lean by
engine speed
reduction, and
rich by racing.)
Engine Voltage (mV) o If the oxygen sensor output voltage
condition is high during sudden deceleration
When sudden 200 or lower
1) Check for injector leakage.
deceleration
2) Check the oxygen sensor signal
from 4,000
circuit.
rpm
is low during high engine speed
When engine 600-1,000 1) Check the oxygen sensor and
is suddenly signal circuit.
rewed
o Engine warm Engine speed Voltage (mV) o If the oxygen sensor signal is
(Using the oxygen (rpm) normal, the electronic control unit
sensor signal,
check the air/fuel
700 (idle) 400 or lower
is regulating the air/fuel mixture
ratio normally.
mixture ratio, and 2,000 o If the oxygen sensor output voltage
also check the is low at all times, check for intake
condition of the (changes) air restriction.
electronic control o If the oxygen sensor output voltage
unit.) is high at all times, check for
600-1,000 leakage of the injector.
Air-flow sensor o Engine warm Engine Frequency (Hz) o If the air-flow sensor output sudo
Service data condition denly changes greatly, improper
o Item No.1 2 700 rpm 3 0 - 5 0
contact of the air-flow sensor or
(Idle)
connector is probable.
o If the output frequency of the
2,000 rpm 6 3 - 8 3 air-flow sensor is unusually high or
Revving Increases
low, check the air cleaner element.
caused by
racing
air-flow sensor is high, an increase
of engine resistance or leakage of
compression pressure is probable.
3 1 - 3 8
MPI SYSTEM
Test
specification
Intake-air temper- o Ignition switch: Air temperature Temperature o Malfunction of the intake-air temature
sensor ON, or engine °C (°F) °C (°F) perature or related circuit
o Service data running
o Item No.13
-20 (-4) -20 (-4)
0 (32) 0 (32)
20 (68) 20 (68)
40 (104) 40 (104)
80 (176) 80 (176)
o Ignition switch: Warm by using Increases
ON a hair dryer or
other method.
Throttle-position
sensor
o Service data
o Item No.14
o Hold for 15 Throttle valve Voltage (mV) o Throttle position sensor misadjusted
seconds or
longer with the
Idle position 480-520
o Throttle position sensor or related
circuit malfunction
ignition switch Opens slowly. Becomes
at “ON”. higher in
proportion to
valve opening
Motor position
sensor
o Service data
o Item No.1 5
Fully open 4,500-5,500
o Engine: Idle Engine Voltage (mV) o If the voltage is low, check whether
after warm-up condition or not there is air intake.
(The idle position
switch
Idle (700 rpm) 500-1,300
o If the voltage is high, the probable
cause is:
must be ON.) 1) Deposits adhered to the throttle
valve
2) Increased engine resistance
o If the voltage or idling speed is
abnormal even though each part of
the engine is normal, the probable
cause is:
1) Improper adjustment of the idle
speed control and/or the throttle
position sensor
2) Malfunction of the motor position
sensor or the related circuit.
3 1 - 3 9
MPI SYSTEM
Check points
Motor position
sensor
o Sensor data
o Item No.15
Check conditions
Test
specification
The compressor Air conditioner 800-1,800 o If the engine speed does not
clutch must be switch ON increase when the air conditioner
activated when (800 rpm) switch is switched from OFF to ON,
the air condi- check the DC motor drive circuit
tioner switch is o Check the air conditioner system
switched ON.)
Air conditioner 900-1,900 o Check the inhibitor switch and the
switch: ON signal circuit
Shift lever: “D”
range (700
rpm)
Crank signal
o Service data
o Item No.18
Engine coolant
temperature
sensor
o Service data
o Item No.21
Crank angle
sensor
o Service data
o Item No.22
o Ignition switch: OFF o Ignition switch-ST signal circuit
ON check
o Ignition switch check
o Ignition switch: Engine coolant Temperature o Engine coolant temperature sensor
ON, or engine temperature °C (°F) or related circuit malfunction
running °C (°F)
-20 (-4) -20 (-4)
0 (32) 0 (32)
20 (68) 20 (68)
40 (104) 40 (104)
80 (176) 80 (176)
o Engine: idle Engine coolant Idle rpm o If the idle speed suddenly increases,
(Check with the temperature a malfunction of the crank angle
ignition switch °C (°F) sensor or improper contact of the
ON.)
-20 (-4) 1,500-1,700
0 (32) 1,350-1,550
20 (68) 1,150-1,350
40 (104) 950-1,150
80 (176) 650-850
3 1 - 4 0
MPI SYSTEM
Test
specification
Barometric pres- o Ignition switch: Altitude m (ft.) Pressure o Barometric pressure sensor or
sure sensor ON mm Hg related circuit malfunction.
o Service data
0 (0) 760
(If the barometric pressure sensor
o Item No.25 pressure is low at high speed,
600 (1,968) 710 clogging of the air cleaner element
1,200 (3,937) 660
is probable.)
1,800 (5,905) 610
o Engine: Gradually close Decreases.
2,000 rpm the air-intake
duct by hand.
Idle switch
o Service data
o Item No.26
Power-steering
switch
o Service data
o Item No.27
o Ignition switch: Throttle valve ON o Idle position switch or related circuit
ON idling position malfunction
(Checking by
Open the throt- OFF
o Improper adjustment of the acceldepressing
the erator cable or the cruise control
accelerator pedal
tle valve slightly.
cable.
several times) o Misadjusted fixed SAS.
o Engine: Idle Steering OFF o Power steering oil-pressure
wheel neutral switch or signal circuit malfunction
position
(wheels
straight-ahead
direction)
Steering
wheel half
turn
ON
Air-conditioner
switch
o Service data
o Item No.28
o Engine: idle Air-conditioner
(The air condi- switch “OFF”
tioner compressor
will be
activated when
Air-conditioner
the air-condiswitch
“ON”
tioner switch is
ON.)
OFF
ON
o Check the air conditioner system.
Inhibitor switch
o Service data
o Item No.29
o Ignition switch: Shift lever: “P”, “N” o Malfunction of the inhibitor
ON “P” or “N” switch or the signal circuit.
(A/T models
only)
Shift lever: “D”, “2”, “L”, o Improper adjustment of the control
“D”, “2”, “L” “R”
cable between the shift lever and
or “R”
the inhibitor switch.
3 1 - 4 1
MPI SYSTEM
Test
specification
EGR temperature o Engine: warm Engine Temperature o Check the EGR temperature
sensor condition °C (°F) sensor.
[California vehicle o Check the EGR control system.
only)
700 rpm 70 (158)
(Idle) or less
o Check the EGR valve.
o Service data o Check the EGR control solenoid
o Item No.43 3,500 rpm 70 (158) valve.
o Disconnect or more o Check the EGR control vacuum.
the vacuum
hose (yellow)
stripe from the
A port nipple
of the throttle
body, and
pinch the hose
end with your
fingers.
Injectors
o Actuator test
o Item No.1-4
Injector
o Service data
o Item No.41
o Engine: idle Injector No. Engine o If the idling condition doesn’t
after warm-up
1
(Cut off the
Unstable idle
change, check the cylinder.
1) Check the injector operation
injectors in 2 sound.
sequence dur- 2) Check the spark plug and
ing idle after
3
high-tension cable.
engine warm- 4 3) Check the power transistor unit
up; check the and control circuit.
idle condition.) 4) Check injecting condition
o Engine: warmed Engine Activation o If the injector activation time is
up condition time (msec.) unusually long or short, there is a
700 rpm 2.2-2.9
malfunction of the air-flow sensor,
(Idle)
engine coolant temperature sensor,
intake-air temperature sensor, or
2,000 rpm 1.8-2.6 barometric pressure sensor.
Rapid racing Increases
long, increased engine resistance or
leakage of compression pressure is
probable.
Ignition advance o Engine: warmed Engine speed
(power transistor) up (rpm)
o Service data o Timing light: set
o Item No.44
700 (Idle)
2,000
Ignition
advance
(°BTDC)
8 - 1 2
2 6 - 3 4
o If the ignition advance and actual
ignition timing are different, adjust
the ignition timing.
[The ignition timing may fluctuate
during idling, but this is not a
problem. The advance is greater
(approx. 5°) at high altitude.]
3 1 - 4 2
MPI SYSTEM
Check points
Air conditioner
relay
o Service data
o Item No.49
Check conditions
Test
specification
o Engine: idle Air conditioner Air conditioner o If the air conditioner relay output is
after warm-up switch relay abnormal, check the air conditioner
OFF OFF
signal input circuit and the air
(compressor
conditioner system.
clutch nono
If the activation of the air condiactivation)
tioner compressor clutch is not
normal, check the compressor
ON ON (compres- clutch and the relay circuit.
sor clutch
activation)
Purge control o Ignition switch: Actuator forced Operation o Check the purge control solenoid
solenoid valve ON actuation sound is valve.
o Actuator test (Engine stop) audible o Check the purge control solenoid
o Item No.8 valve drive circuit.
EGR control o Ignition switch: Actuator forced Operation o Check the EGR control solenoid
[California vehicle (Engine stop) audible o Check the EGR control solenoid
only) valve drive circuit.
o Actuator test
o Item No.10
3 1 - 4 3
MPI SYSTEM
MPI SYSTEM COMPONENTS INSPECTION
Air Flow Sensor (AFS)
1. Connect a voltmeter between 6 and 3 of AFS connector.
Terminal 6 : Sensor ground
Terminal 3 : AFS output
2. Warm the engine and bring it to a normal idle.
3. Measure the voltage between terminals.
Engine speed (rpm) Output voltage (V)
Idling
3,000
2.7-3.2
NOTE
If the air flow sensor fails, the intake air volume cannot
be measured and as a result, normal fuel injection control
is no longer available. The vehicle can be run, however,
by a preset map value.
Barometric Pressure Sensor
1. Connect a voltmeter between terminals 5 and 6 of the
barometric pressure sensor connector.
Terminal 5 : Barometric sensor output
3. Slowly cover about half of the air cleaner air intake, checking
for a change in voltage.
Pressure
Fall
Voltage
Drop
3 1 - 4 4
MPI SYSTEM
Reference
Pressure mmHg (kPa, psi) (20, 2.9) (49, 6.9) (103, 15)
150 350 760
Central voltage (V) 0.79 1.84 4.00
4. Replace the air flow sensor if necessary.
intake Air Temperature Sensor
1. Disconnect the air flow sensor connectors.
2. Measure the resistance between the terminals 4 and 6.
Terminal 4 : intake air temperature output
3.
4.
Temperature ºC (ºF) Resistance (KD)
0 (32) 5.4-6.6
20 (68) 2.33-2.97
80 (176) 0.31-0.43
Measure the resistance while heating the sensor using a
hair drier.
Higher Smaller
If the value deviates from the standard value or the
resistance remains unchanged, replace the air flow sensor
assembly.
Engine Coolant Temperature Sensor
1. Remove the engine coolant temperature sensor from the
intake manifold.
2. With the sensing portion of the engine coolant temperature
sensor immersed in hot water, check resistance. The sensor
should be held with its housing 3 mm (0.12 in.) away from
the surface of the hot water.
3 1 - 4 5
MPI SYSTEM
3.
0 (32) 5.9
20 (68) 2.5
40 (104) 1.1
80 (176) 0.3
If the resistance deviates from the standard value greatly,
replace the sensor.
Throttle Position Sensor (TPS)
1. Disconnect the throttle position sensor connector.
2. Measure the resistance between terminals 1 and 4 of the
Terminal 1 : Sensor ground
Terminal 4 : Sensor power
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.5-6.5 Kfi
3 1 - 4 6
MPI SYSTEM
3. Connect an analog type ohmmeter between terminals 1 and
3.
Terminal 3 : Sensor output
4. Slowly open the throttle valve from the idle position to the
fully open position and check that the resistance values
change smoothly with the opening of the throttle valve.
Standard value . . . . . . . . . . . . . . . Approx 0.5 - (3.5-6.5) kfl
5. If the resistance is out of specification, or if the change is
not smooth, replace the throttle position sensor.
Tightening torque
Throttle position sensor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1.5-2.5 Nm (15-25 kg.cm, 1.1-1.8 lb.ft)
Idle Switch
1. Disconnect the ISC motor connector.
2. Check for continuity between the terminal 3 and the body
ground.
Terminal 3 : Idle Switch
Accelerator pedal Continuity
Depressed Non-conductive (MI)
Released Conductive (On)
Motor Position Sensor (MPS)
1. Connect an ohmmeter between terminals 4 and 1 of the
motor position sensor connector.
Terminal 1 : Sensor power
Terminal 4 : Sensor ground
2. Measure the resistance of the terminals.
Standard value . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-6 kfi
3. Attach an ohmmeter between terminals 2 and 4 of the motor
Terminal 2 : MPS output
4. Connect a 6V battery between terminals 2 and 1 of the ISC
motor connector and check to see that resistance changes
smoothly when the ISC motor is activated.
Standard value . . . . . . . . . . . . . . . . . . Approx 0.5 - (4-6) k0
3 1 - 4 8
MPI SYSTEM
5. If the standard value is not achieved, or if the change is not
smooth, replace the ISC servo assembly.
No.1 Cylinder TDC Sensor And Crankshaft
Angle Sensor
1. Connect a voltmeter between terminals 1 and 2, and 1 and
3.
Terminal 2 : Crank angle signal
Terminal 3 : No.1 TDC signal
2. Measure the output voltage of the terminals while cranking
the engine.
Sensor
No.1 cylinder
TDC sensor
Terminal
Ground
Voltage
0.2-1.2V
(The needle fluctuates)
Crankshaft
angle sensor
Ground 1.8-2.5V
3. When the voltage is abnormal, check the sensor power and
ground circuit, and if nothing unusual is found, disassemble
the distributor and check it.
Oxygen Sensor
NOTE
1) Before checking, warm up the engine until engine coolant
temperature reaches 80 to 95ºC (176 to 203ºF)
2) Use an accurate digital voltmeter.
1. Disconnect the oxygen sensor connector and connect a
voltmeter to the oxygen sensor connector.
2. While increasing engine RPM, measure the oxygen sensor
output voltage.
3 1 - 4 9
MPI SYSTEM
Engine
Oxygen sensor
output voltage
Remarks
Increase RPM Min. 0.6V Richens air/fuel mixture
Tightening torque
Oxygen sensor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
39-49 Nm (400-500 kg.cm, 29-36 lb.ft)
Vehicle Speed Sensor
The vehicle speed sensor uses a reed type switch. The speed
sensor built in the speedometer converts the speedometer gear
revolution (vehicle speed) into pulse signals, which are sent to
the ECU.
Inhibitor Switch (For A/T)
Refer to Group 45.
Injectors
Operation Check
Using a multi-use tester, check as described below.
o Cut off the fuel injection of the injectors in sequence.
o Check the operation time of the injectors.
Operation Sound Check
using a stethoscope, check the operation sound (tick, tick) during
idle or cranking. Check that the sound is produced at shorter
intervals as the engine speed increases.
NOTE
1) Other injectors may produce sound as they operate even
if the injector being checked does not operate.
2) Ensure that the sound from an adjacent injector is not
being transmitted along the delivery pipe to an inoperative
injector.
3 1 - 5 0
MPI SYSTEM
Resistance Measurement Between Terminals
1. Disconnect the connector for the injector.
2. Measure the resistance between the terminals.
Standard value . . . . . . . . . . . . . . . . 13-16 Cl [at 20°C (68ºF)]
3. Connect the connector for the injector.
Idle Speed control (ISC) Servo
1. Measure resistance between terminal 1 and 2 using an
ohmmeter.
Standard value : 5-35 Sz [at 20°C (68ºF)]
2. Connect 6V DC to terminals 1 and 2 and check that the idle
speed control servo extends and retracts by itself.
If the idle speed control servo does not move, replace the
idle speed control servo assembly.
CAUTION
Apply only a 6V DC or lower voltage. Application of higher
voltage could cause locking of the servo gears.
4. If the servo does not operate, replace it as an assembly.
3 1 - 5 1
MPI SYSTEM
Control Relay
CAUTION
When applying battery voltage directly, make sure that it is
applied to the correct terminal. Otherwise, the relay could be
damaged.
NOTE
Failure of the control relay interrupts power supply to the fuel
pump, injectors and ECU, resulting in start failure.
1. Check continuity between the terminals when the relay coil
is energized and when it is not.
NOTE
In the following tables, the arrows indicate the direction
of the current flow.
Confirm circuit tester polarity before checking continuity.
o Coils L1 and L2
Condition Measuring
terminals Continuity
Not
energized
1 - 4
3 - 8
2 - 8
Non-conductive (MI)
Conductive (approx. 950)
Energized
6 - 7 Conductive (approx. 35R)
1 - 4 Conductive (On)
NOTE
“Energized” means voltage applied across terminals 6 and
7.
o Coil L3
NOTE
“Energized” means voltage applied across terminals 5 and
7.
2. If the result is not satisfactory, replace the control relay.
3 1 - 5 2
MPI SYSTEM
Power Transistor
The power transistor is installed on the intake manifold; it
functions to control the ignition timing by controlling the ignition
coil primary current by signals from the ECU.
1. Disconnect the power transistor connector.
2. Connect a power supply of 1.5V (one dry cell) between the
power transistor and then check for continuity between
terminals 3 and 2 under power-ON and power-OFF
conditions.
NOTE
1) When checking for continuity, connect the ohmmeter
to terminal 2 on the positive side and terminal 1 on
the negative side.
2) Check with an analog-type circuit tester.
3 1 - 5 3
INJECTOR AND THROTTLE BODY (MPI)
COMPONENTS
TORQUE : Nm (kg.cm, lb.ft)
REMOVAL
1. Release residual pressure from the fuel line to prevent fuel
from spilling.
CAUTION
fuel from leaking out due to residual pressure in the fuel
line.
3 1 - 5 4
2. Remove the delivery pipe with the fuel injector and pressure
regulator.
CAUTION
1. Be careful not to drop any injectors when removing the
delivery pipe.
2. Be aware that fuel may flow out when removing the
injector.
INSPECTION
1. Measure the resistance of the injectors between the
terminals using an ohmmeter.
Resistance . . . . . . . . . . . . . . . . . . . . .13-16n [at 20°C (68ºF)]
2. If the resistance is not within specifications, replace the
injector.
INSTALLATION
1. Install a new grommet and O-ring to the injector.
2. Apply a coating of solvent, spindle oil or gasoline to the
O-ring of the injector.
3. While turning the injector to the left and right, install it on
to the delivery pipe.
4. Be sure the injector turns smoothly.
NOTE
If it does not turn smoothly, the O-ring may be jammed;
remove the injector and re-insert it into the delivery pipe
and re-check.
3 1 - 5 5
5. When installing the delivery pipe, check to be sure that the
insulator is correctly inserted into the delivery pipe’s
installation hole.
6. When connecting the fuel pressure regulator to the delivery
pipe, apply light oil or fuel to the O-ring, and then insert,
being careful not to damage the O-ring.
7. When connecting the high pressure fuel hose to the delivery
pipe, apply fuel to the hose union, and then insert, being
3 1 - 5 6
THROTTLE BODY (MPI)
THROTTLE BODY
COMPONENTS
REMOVAL
CAUTION
The throttle valve must not be removed.
3 1 - 5 7
THROTTLE BODY (MPI)
1. Remove the throttle position sensor by unscrewing the
Phillips-head screws.
NOTE
Except when necessary for replacement, the throttle
position sensor must not be removed.
2. Remove the ISC servo assembly.
NOTE
1) Except when necessary for replacement, the ISC servo
assembly should not be removed.
2) The ISC servo assembly should not be disassembled.
3. Use an open-end wrench or box wrench to remove the
adjustment screw.
INSPECTION
Cleaning Throttle Body components
1. Clean all components. The following components must not
be cleaned by immersion in cleaning solvents.
o ISC servo assembly
The insulation of these components will be damaged if they
are immersed in a cleaning solvent. They should be cleaned
by using only a piece of cloth.
2. Check for restriction of the vacuum port or passage. Clean
the vacuum passage by using compressed air.
3 1 - 5 8
FUEL TANK
COMPONENTS
REMOVAL
1. To reduce the internal pressure of the fuel lines and hoses,
first start the engine and then disconnect the electrical fuel
pump connector.
NOTE
Be sure to reduce the fuel pressure before disconnecting
the fuel line and hose otherwise fuel will spill out.
3 1 - 5 9
FUEL TANK (MPI)
2. Disconnect the battery cable from the negative terminal of
the battery.
3. Remove the fuel tank cap.
4. Remove the drain plug and drain the fuel.
5. Disconnect the return hose and vapor hose.
6. Disconnect the fuel gauge unit connector.
3 1 - 6 0
FUEL TANK (MPI)
7. Disconnect the high pressure hose from the fuel tank.
8. Detach the fuel filler hose and leveling hose.
9. Loosen the two self-locking nuts, that hold the tank in
position and remove the two tank bands.
10. Remove the fuel vapor hose and the fuel tank.
INSPECTION
1. Check the hoses and the pipes for cracks or damage.
2. Check the fuel tank cap for proper operation.
3. Check the fuel tank for deformation, corrosion or cracking.
4. Check the inside fuel tank for dirt or foreign material.
5. Check the in-tank fuel filter for damage or restriction.
3 1 - 6 1
FUEL TANK (MPI)
6. Test the two-way valve for proper operation.
7. To check the two-way valve, lightly breathe into the inlet and
outlet. If air passes through after slight resistance, then the
valve is good.
INSTALLATION
1. Confirm that the pad is fully bonded to the fuel tank, and
install the fuel tank by tightening the self-locking nuts to the
tank bands until the rear end of the tank band contacts the
body.
2. Connect the leveling hose to the tank and approximately 40
mm (1.6 in.) at the filler neck.
3. When connecting the filler hose, the end with the shorter
straight pipe should be connected to the tank side.
4. Connect the vapor hose and return hose.
When attaching the fuel hose to the line, be sure that the
hose is attached as shown in the illustration.
3 1 - 6 2
FUEL TANK (MPI)
5. To connect the high pressure hose to the fuel pump,
temporarily tighten the flare nut by hand; then tighten it to
the specified torque. Be careful that the fuel hose does not
twist.
Tightening torque
High pressure hose flare nut . . . . . . . . . . . . . . . . . . . . . . . . .
31-41 Nm (320420 kg.mm, 23-30 lb.ft)
CAUTION
When tightening the flare nut, be careful not to bend or
twist the line to prevent damage to the fuel pump
connection.
6. Connect the electrical fuel pump and fuel gauge unit
connector.
7. Tighten the drain plug to the specified torque.
Tightening torque
Drain plug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
15-25 Nm (150-250 kg.cm, 11-18 lb.ft)
3 1 - 6 3
FUEL LINE AND VAPOR LINE (MPI)
REMOVAL
1. Remove the upper eye bolt while holding the fuel filter nut
securely and remove the high pressure fuel hose.
CAUTION
1) Be sure to reduce the fuel pressure before disconnecting
the fuel line and hose, otherwise fuel will spill
out.
2) Cover the hose connection with a shop towel to
prevent splashing of fuel that could be caused by
residual pressure in the fuel line.
2. Remove the lower eye bolt while holding the fuel filter nut
assembly.
filter from the bracket.
4. Remove the fuel return hose and line.
5. Remove the fuel vapor hose and line.
3 1 - 6 4
INSPECTION
1. Check the hoses and pipes for cracking bending, deformation
or restrictions.
2. Check the canister for restrictions.
3. Check the fuel filter for restrictions and damage.
If a problem is found, repair or replace parts as necessary.
INSTALLATION
1. Install the fuel vapor hose and return hoses.
o If the fuel line has a stepped section, connect the fuel
hose to the line securely, as shown in the illustration.
o If the fuel line does not have a stepped section, connect
the fuel hose to the line securely.
2. Install the fuel filter, and tighten the fuel filter bracket.
3. Insert the main line on the filter and tighten the eye bolts
while holding the fuel filter nuts.
4. Install the clips and make sure that they do not interfere with
other components.
5. When installing the check valve, install it so that the valve
is facing in the direction as shown in the illustration.
ENGINE CONTROL (MPI)
ENGINE CONTROL
TORQUE : Nm (kg.cm, Ib.ft)
REMOVAL
1. Remove the bushing and inner cable of the accelerator arm
side.
2. After disconnecting the accelerator switch connector, loosen
the bolts of the accelerator arm bracket and remove.
3 1 - 6 6
INSPECTION
1. Check the inner and outer cable for damage.
2. Check the cable for smooth movement.
3. Check the accelerator arm for deformation.
4. Check the return spring for deterioration.
5. Check the connection of the bushing to end metal fitting.
6. Check the accelerator switch for proper operation.
INSTALLATION
1. When installing the return spring and accelerator arm, apply
multi-purpose grease around each moving point of the
accelerator arm.
2. Apply the sealant to the bolt mounting hole, and tighten the
accelerator arm bracket.
Tightening torque
Accelerator arm bracket bolts . . . . . . . . . . . . . . . . . . . . . . . . .
8-12 Nm (80-120 kg.cm, 5.8-7.2 lb.ft)
3. Securely install the resin bushing of the accelerator cable
on the end of the accelerator arm.
4. Apply multipurpose grease around the cable end.
3 1 - 6 7
GENERAL (FBC)
GENERAL INFORMATION (FBC SYSTEM)
The Feedback Carburetor (FBC) system provides a positive
air-fuel ratio control for maximum reduction of emissions. The
Electric Control Unit (ECU) receives signals from various sensors
and then modulates two solenoid valves (FBSV, SCSV) installed
on the carburetor to control the air-fuel ratio.
The ECU also controls the ignition timing, electric choke, throttle
opener by switching on-off the solenoid valves.
FBSV : Feedback Solenoid Valve
SCSV : Slowcut Solenoid Valve
ECU : Electric Control Unit
3 1 - 6 9
GENERAL
SPECIFICATIONS
Fuel tank
Capacity
Fuel filter
Type [In-line filter]
Type [In-tank filter]
Fuel pump
Type
Driven by
Feed pressure
Carburetor
Type
Identification mark
M/T
A/T
Throttle bore
Primary
Secondary
Feedback solenoid valve (FBSV)
Type
Coil resistance
Slow cut solenoid valve (SCSV)
Type
Coil resistance
Type
Regulating voltage (When throttle
valve fully closed)
Coil resistance
Bow vent valve (BVV)
Type
Vacuum orifice
Mixture control valve (MCV)
Type
Dash pot
Type
Operating rpm (When SAS 2 touches
free lever)
Outer venturi dia.
Primary
Secondary
Inner venturi dia.
Primary
Secondary
45 lit. (11.9 U.S.gal., 9.9 Imp.gal.)
Cartridge type
Open type
Mechanical diaphragm type
Camshaft
19-25 kPa (2.76-3.63 psi) at 2,500 rpm
Down-draft, 2-barrel, feed back type
472 (For Canada), 474 (For Federal)
475 (For Federal)
30 mm (1.181 in.)
32 mm (1.260 in.)
Duty cycle solenoid
54-66 fl [At 20°C (68ºF)l
Duty cycle solenoid
48-60 fl [At 20°C (68ºF)]
Variable resistor type (Rotary type)
0.25V
3.5-6.5 KD
Vacuum type
0.3 mm (0.012 in.)
Vacuum type
Conventional type
Approx. 1,800 rpm
20 mm (0.787 in.)
25 mm (0.984 in.)
9-14 mm (0.354-0.551 in.)
9-12 mm (0.354-0.472 in.)
3 1 - 7 0
GENERAL (FBC)
Main jet
Primary
Secondary
Main air jet
Primary - First
Second
Secondary
Pilot jet
Primary
Secondary
Pilot air jet
Primary - First
Second
Secondary
Main nozzle
Primary
Secondary
Throttle valve plate
Thickness
Primary
Secondary
Fuel closing angle
Primary
Secondary
Full opening angle
Enrichment jet
Slow air jet
Accelerating pump
Diaphragm dia.
Pump jet dia.
Choke
Type
Choke valve operating angle
Bimetal
Temperature constant
Spring constant
Choke breaker opening
First stage
Second stage
Input sensor
Type
Resistance
#83.8
#145
#80
#60
#70
#46.3
#70
#120
#200
#100
2.6 mm (0.102 in.)
2.8 mm (0.110 in.)
1.0 mm (0.040 in.)
1.5 mm (0.060 in.)
15º
90º
#50
#110
24 mm (0.945 in.)
0.35 mm (0.014 in.)
Automatic (Electric type)
25º (When fully closed)
90° (When fully opened)
1.0 deg/ºC
60 gr.mm/deg.
1.4-1.6 mm (0.056,0.064 in.)
2.9-3.1 mm (0.116-0.124 in.)
Thermistor type
2.5 KR [at 20°C (68ºF)]
0.3 Ka [at 80°C (176ºF)l
3 1 - 7 1
GENERAL (FBC)
Oxygen sensor
Type
Vacuum switch
Type
Operating condition - ON
OFF
Top gear sensing switch
Output actuator
Cold mixture heater
Type
Secondary air control solenoid valve
Type
Resistance
Advance control solenoid valve
Type
Resistance
Cold advance control solenoid valve
Type
Resistance
Throttle opener control solenoid valve
Type
Resistance
Zirconia sensor
Contact type switch
More than 40 kPa (5.8 psi)
Less than 26 kPa (3.9 psi)
Reed switch type
Contact type switch
Positive Temperature Coefficient (PTC) heater
ON-OFF solenoid valve
38-44fi [at 20°C (68ºF)]
38-440 [at 20°C (68ºF)]
38--44fi [at 20°C (68ºF)]
3 1 - 7 2
GENERAL (FBC)
SERVICE STANDARD
Basic ignition timing BTDC 5º ± 1º
Curb idle speed 700 ± 50 rpm
Throttle opener adjusting rpm for electrical load 800 ± 50 rpm
Throttle opener adjusting rpm for air conditioner load 900 ± 25 rpm
TIGHTENING TORQUE
Nm kg.cm lb.ft
Accelerator arm bracket to body 8 - 1 2 8 0 - 1 2 0 5.8-8.7
Accelerator cable guide to body 3 - 5 3 0 - 5 0 2.2-3.6
Carburetor attaching bolt 1 5 - 2 0 150-200 1 1 - 1 4
Engine coolant temperature sensor 2 0 - 4 0 200-400 1 4 - 2 9
Oxygen sensor 3 9 - 4 9 400-500 2 9 - 3 6
Fuel tank drain plug 7 8 - 9 8 800-1,000 5 8 - 7 2
LUBRICANT
Grease for accelerator arm pin and return spring Multipurpose grease SAE J310a, NLGI grade #3
or equivalent
3 1 - 7 3
GENERAL (FBC)
SPECIAL TOOLS
3 1 - 7 4
GENERAL (FBC)
TROUBLESHOOTING
to start with inspection of the basic systems. If you experience
one of the followings, (A) engine start failure, (B) unstable idling
or (C) poor acceleration, you should first check the following
basic systems.
1. Power supply
1) Battery
2) Fusible link
3) Fuse
2. Body ground
3. Fuel supply
1) Fuel line
2) Fuel filter
3) Fuel pump
4. Ignition system
1) Spark plug
3) Distributor
4) Ignition coil
1) PCV system
2) EGR system
3) Vacuum leak
6. Others
1) Ignition timing
2) Idle speed
Troubles with the FBC system are often caused by poor
contact of harness connector. It is, therefore, important to
check harness connector contact.
3 1 - 7 5
GENERAL (FBC)
Fuel Tank and Fuel Line
Symptom
Engine malfunctions due to
insufficient fuel supply
Evaporative emission control
malfunctions (Pressure released
when fuel tank cap is removed)
Probable cause
Clogged fuel filter or in-tank fuel filter
in the pump)
Misrouted vapor lines
Disconnected vapor line piping joint
Folded, belt, cracked or clogged vapor line
(two-way valve)
Remedy
Repair or replace
Clean or replace
Replace
the fuel tank and fuel line
Clean or replace
Replace
Correct
Correct
Replace
Replace
Replace
3 1 - 7 6
GENERAL (FBC)
Carburetor and FBC System
Symptom
Engine will not start
or start to hard
stalls
Carburetor
FBC system
Carburetor
FBC system
Probable cause
Choke valve remains open-cold engine
Improper choke breaker operation
Electric choke malfunction
Needle valve sticking or clogged
malfunction
Vacuum hose disconnected or damaged
Slow-cut solenoid valve malfunction
Feedback solenoid valve malfunction
Vacuum switch malfunction-cold engine
Faulty ECU
Harness broken/short-circuited or
loose connection
Choke valve malfunction
Improper fast idle-cold engine
Improper idle adjustment
Primary pilot jet clogged
Dash pot malfunction
malfunction
Throttle position sensor malfunction
Engine speed sensor malfunction
Timing control system malfunction
Throttle opener control system
malfunction
connector not connected securely
Remedy
Clean choke bore and linkage
Check and adjust choke breaker
Check electric choke body and
choke valve operation
Repair or replace
Check by using checker (Check
component and replace if faulty)
Repair or replace
Check component
Check component
Check component
Replace
Repair or replace
Adjust fast idle speed
Adjust idle speed
Check choke body and choke
valve operation
Clean up or replace
Adjust
Check drive signal by using
checker
Check component
Repair or replace
Check component and adjust
Check harness for continuity
Check system. If faulty, check
components
components
Repair or replace
3 1 - 7 7
GENERAL (FBC)
Symptom
Engine hesitates or
poor acceleration
Engine dieseling
(runs after ignition
switch is turned off)
Carburetor
FBC system
Carburetor
FBC system
Poor fuel mileage Carburetor
Probable cause
Acceleration pump malfunction
Choke valve remains closed-hot engine
Main jet clogged
Enrichment jet clogged
Secondary valve operation abnormal
malfunction
Cold mixture heater relay control system
connector not connected properly
Air conditioner power relay control
system malfunction
Engine idle speed too high
Choke valve operation abnormal
Enrichment valve kept open
Remedy
Clean pump discharge. rate
Check choke valve operation
Clean up
Clean up
Check valve operation
checker
Check component
Check with checker (Replace
if faulty)
components
components and replace if faulty)
Check harnesses for continuity
components
Repair or replace
Check system
Adjust idle speed
Check component
Adjust idle speed
Check choke body and valve
operation
Repair or replace
3 1 - 7 8
GENERAL (FBC)
Symptom
Poor fuel mileage FBC system
Probable cause
malfunction
Oxygen sensor malfunction
Remedy
(Check component and replace
if faulty)
if faulty)
components
checker
Check component
checker
Check components
Repair or replace
3 1 - 7 9
GENERAL (FBC)
FBC System Component
1. Electric Control Unit (ECU)
Based on the information- from various sensors, the ECU
determines (computes) ideal setting for varying operating
conditions and drives the output actuators to control the
air-fuel ratio.
The ECU consists of an 8-bit microprocessor, random access
memory (RAM), read only memory (ROM) and input/output
(l/O) interface.
3 1 - 8 0
GENERAL (FBC)
2. Engine Coolant Temperature Sensor
The engine coolant temperature sensor is installed in the
engine coolant passage of the intake manifold. This coolant
sensor is a thermistor. The ECU determines engine
temperature by the sensor output voltage and utilize it to
provide optimum fuel enrichment when the engine is cold.
3. Throttle Position Sensor (TPS)
The TPS is a rotary type variable resistor that rotates together
with the carburetor throttle shaft to sense the throttle valve
angle. As the throttle shaft rotates, the TPS output voltage
changes and the ECU detects the throttle valve opening
based on the change of the voltage.
Using the TPS output signal, engine speed signal and other
signals, the ECU maintains the optimum air-fuel ratio.
4. Engine Speed Sensor
The ignition coil negative terminal voltage makes sudden
increase twice per crankshaft revolution synchronously with
ignition timing.
By sensing this ignition coil negative terminal voltage change
and measuring the time between peak voltages, the ECU
computes the engine speed, judges the engine operating
mode and controls the air-fuel ratio and ignition timing.
GENERAL (FBC)
5. Oxygen Sensor
1) The oxygen sensor installed on the exhaust manifold
makes use of the principles of solid electrolyte oxygen
concentration cell. The‘ oxygen concentration cell is
characterized by sharp change of the output voltage in
the vicinity of the stoichiometric air-fuel ratio.
2) Using such characteristics, the oxygen sensor senses the
oxygen concentration in the exhaust gas and feeds it to
the ECU. The ECU then judges if the air-fuel ratio is
richer or leaner as compared to the stoichiometric ratio
and provides feedback control to adjust the air-fuel ratio
to the stoichiometric ratio where the emission purification
rate of the three way catalytic converter is the
optimum.
6. Vacuum Switch
The vacuum switch is a contact type switch that is operated
by intake manifold vacuum. When the throttle valve closes,
the intake manifold vacuum acts on the vacuum switch to
close its contact.
By this action, the voltage on the ECU side is grounded and
the ECU senses that the throttle valve opening is near idle.
3 1 - 8 2
GENERAL (FBC)
7. Feedback Solenoid Valve (FBSV)
The FBSV is installed in the carburetor float chamber cover.
The ECU controls the air-fuel ratio by controlling the duty
cycle of the FBSV.
The higher is the duty ratio, the leaner becomes the air-fuel
ratio.
NOTE
The duty cycle control means control of the solenoid valve
energization rate by changing the ON time ratio T2/T1
(called duty ratio) of 10 Hz pulse.
8. Slow Cut Solenoid Valve (SCSV)
The SCSV is located in the carburetor float chamber cover.
The ECU controls the carburetor slow system fuel flow by
controlling the duty cycle of the SCSV.
3 1 - 8 3
GENERAL (FBC)
FBC System Operation
1. The air-fuel ratio control is maintained by the ECU in one
of two operating modes.
1) Closed loop control (Feedback control)
After engine warm-up, the air-fuel ratio control is made
by the feedback control based on the oxygen sensor
signal.
The oxygen sensor output voltage changes sharply at the
stoichiometric ratio. The control unit senses this oxygen
sensor signal and provides feedback control to the FBSV
maintaining the stoichiometric ratio that will give the
best purification rate of the 3-catalyst converter may be
accurately kept. In this state, the SCSV is kept wide open
(100% duty).
2) Open loop control (No feedback control)
During engine start, warm-up operation, high load
operation and deceleration, the air-fuel ratio is in
open-loop. The ECU controlled based on map values*
established previously for engine speed, throttle valve
opening angle and engine coolant temperature, to
improve startability and driveability.
During deceleration, the SCSV limits fuel flow for better
fuel economy and for prevention of overheating of the
catalysts.
* Map value is a value previously established and
stored in ROM in ECU.
2. When the FBSV is energized, the main fuel jet is closed to
leaving the primary main jet passage as the only fuel
passage.
This reduces the amount of fuel, resulting in leaner air-fuel
mixture.
3. When the FBSV is de-energized, the main fuel jet is opened
to provide two fuel passages including the primary main jet
passage. Since this will increase the amount of fuel, richer
air-fuel mixture is obtained.
With the ON-OFF operation of SCSV, the slow fuel passage
is opened and closed.
The air-fuel ratio at deceleration is controlled in this manner.
3 1 - 8 4
GENERAL (FBC)
Distributor Advance Control System
(Ignition Timing Control System)
The distributor vacuum advance is a dual diaphragm type having
main vacuum chamber and sub-vacuum chamber. To control the
ignition timing, the ECU energizes the solenoid valves in the
respective vacuum circuits of main vacuum chamber and
subvacuum chamber.
1. Main Vacuum Timing Control
1) When the engine speed is near the idle speed (1,200 rpm
or less), the ECU energizes the distributor advance
control solenoid valve. By this action the carburetor D
port vacuum is introduced to the main vacuum chamber
which resets the ignition timing.
NOTE
The D port vacuum is zero when the throttle valve is
at idle position, and increases with the valve opening
angle.
3 1 - 8 5
GENERAL (FBC)
2. Sub-vacuum Timing Control
2) When the engine speed increases to 1,200 rpm the ECU
turns off the distributor advance control solenoid valve.
Intake manifold vacuum is routed to the main vacuum
chamber increasing ignition advance.
When the engine starts to warm up [engine coolant
temperatures: below 80°C (176°F), the solenoids are
energized, allowing D port vacuum to reach main
vacuum chamber.
o Control at low altitude [approx. 1,200 m (3,900 ft.) or
lower]
1) When the engine coolant temperature is low [50°C
(122°F) or lower], the ECU energizes the distributor cold
advance control solenoid valve. By this action, the intake
manifold vacuum no longer leaks to atmosphere and
instead is introduced to the sub-vacuum chamber. As a
result, the timing advanced by the main vacuum advance
is additionally advanced by a fixed angle (5°C in crank
angle).
2) During warm-up operation or when the engine coolant
temperature is- high [over 50°C (122°F)], the ECU
de-energizes the distributor cold advance control
solenoid valve circuit. As a result, the intake manifold
vacuum leaks to atmosphere, which prevents timing
advance.
o Control at high altitude [approx, 1,200 m (3,900 ft.) or over)
At high altitude, the HAC is closed and hence the intake
manifold vacuum does not leak to atmosphere from the HAC.
Independently of the distributor cold advance control solenoid
valve, the intake manifold vacuum acts on the sub-vacuum
chamber, causing the timing to advance by a fixed angle (5°
in crank angle). [For Federal]
3 1 - 8 6
GENERAL (FBC)
Throttle Opener System (For power steering,
electrical load)
If the power steering oil pressure switch is turned on by high
pump pressure the throttle opener control solenoid valve is
energized to introduce intake manifold vacuum to the throttle
opener. The throttle valve opens slightly, preventing engine
speed drop caused by power steering load.
When the engine speed drops below the set speed (1,200 rpm),
the ECU keeps the power transistor on. When the electrical load
switch is turned on for lighting etc., the throttle opener control
solenoid valve is energized, allowing intake manifold vacuum to
the throttle opener to open the throttle valve slightly, preventing
engine speed drop caused by electrical load.
3 1 - 8 7
GENERAL (FBC)
Throttle Opener Switch (For A/C)
When the engine speed is below the set speed (1,200 rpm), the
ECU keeps the power transistor on. When the air conditioner
relay is turned on the throttle opener control solenoid valve is
opener. The throttle valve opens slightly preventing engine
speed drop caused by air conditioner load.
Air Conditioner Power Relay Control System (For A/T)
When the throttle valve opening increases (over 74°) during
acceleration etc., the ECU turns off the air conditioning power
relay for about 5 seconds. As a result, even if the air conditioner
switch it is, the air compressor is not driven and hence the
engine load is reduced, improving acceleration performance.
3 1 - 8 8
GENERAL (FBC)
Cold Mixture Heater (CMH) Relay Control
System
The cold mixture heater is a Positive Temperature Coefficient
(PTC) heater installed between the carburetor and intake
manifold.
When the engine coolant temperature is below 60°C (140°F), the
ECU energizes the cold mixture heater relay. The closed relay
supplies voltage to the cold mixture heater. The cool air-fuel
mixture is heated and atomized by the heater before it reaches
the combustion chamber for improved combustion.
3 1 - 8 9
GENERAL (FBC)
Electric Auto Choke System
In the carburetor electric choke system, a bimetal choke spring
is heated by an electric heater (PTC heater*).
As the bimetal spring is heated by the heater after start-up, the
bimetal opens the choke valve gradually by thermal expansion
and pushes down the stopper lever.
The lower the temperature when the engine is started, the
tighter the bimetal closes the choke valve, thus improving at cold
weather starting.
*PTC heater : Positive Temperature Coefficient heater
3 1 - 9 0
GENERAL (FBC)
1. Choke Valve and Fast Idle Cam Operation
1) Before starting the engine, the throttle valve is in normal
idle opening state.
2) Before starting the engine, depress the accelerator pedal
to the floor, and the fast idle cam will turn clockwise.
Release the accelerator pedal, and the lever will ride on
the fast idle cam and the throttle valve will open.
3) When the engine starts, the intake manifold vacuum is
applied to the choke breaker to slightly open the choke
valve, preventing a rich air-fuel mixture.
4) Shortly after starting of engine, the bimetal is heated by
the heater and expands to open the choke valve gradually
and push down the stopper lever.
At this time, the engine speed increases gradually.
5) Depress the accelerator pedal, and the fast idle cam will
turn counterclockwise. Release the accelerator pedal and
the lever will ride on the lower step of fast idle cam and
the throttle valve will close slightly, decreasing the
engine speed. After warming up the engine for a while,
depress the accelerator pedal and the throttle valve will
be further closed.
By repeating this procedure, the fast idle cam is released
and the throttle valve comes to have a normal idle
opening.
3 1 - 9 1
GENERAL (FBC)
2. Operation of Choke Opener
If the engine has been started with the throttle valve lever
on the highest fast idle cam step then the engine speed will
increase with the engine coolant temperature. This results
in the engine overrun. In order to prevent such overrun, the
choke opener is provided.
1) When the thermo valve closes as the engine coolant
temperature rises [65°C (149°F)], the intake manifold
vacuum acts on the fast idle breaker.
2) The fast idle breaker forces the fast idle cam to
counterclockwise so that the lever will rest on the lowest
detent of cam, closing the throttle valve to decrease the
engine speed.
3. Electric Auto Choke Relay
The electric choke relay is normally closed (ON) and it opens
when its coil is energized.
During engine cranking or for approx. 80 seconds at an
engine coolant temperature of -10 to 18°C (-14 to 64°F),
the ECU energizes the electric choke relay coil. This prevents
heating of the electric choke heater, until the engine has
started.
3 1 - 9 2
SERVICE ADJUSTMENT PROCEDURES (FBC)
FBC SYSTEM
Inspection
If FBC system components (sensors, carburetor control unit--
computer, solenoid, etc.) fail, one of the following situations may
be encountered.
2. Unstable idle.
If any of above conditions is noted, first perform basic engine
checks (ignition system malfunctions, incorrect engine
adjustment, etc.). The FBC system can be checked by use of
FBC checker and FBC harness connector. Inspection
procedure is as follows.
CAUTION
1) Before battery terminals are disconnected, make sure
that ignition switch is OFF. If battery terminals are
disconnected while engine is running or when ignition
switch is in ON position, malfunction of computer
could result.
2) Disconnect battery cables before charging battery.
3) When battery is connected, be sure not to reverse
polarity.
4) Make sure that harness connectors are securely
connected. Take care not to allow entry of water or
oil into connectors.
1.
2.
3.
4.
5.
6.
Turn ignition switch to OFF.
Remove the harness connector “A” (13 poles) and connector
“B” (7 poles) from carburetor control unit (computer).
Set check switch of FBC checker to OFF.
Set select switch of checker to A.
Connect the FBC harness connector to the connectors of FBC
checker, and then connect FBC harness connector to
carburetor control unit and harness connectors. Place FBC
checker on front passenger’s seat.
Perform checks according to the “FBC System Check
Procedure Chart”.
7.
8.
9.
If check shows any departure from specifications, check
corresponding sensor and related electrical wiring, repair or
replace.
After repair or replacement, recheck with FBC checker to
confirm that repaired or replaced parts is performing well.
3 1 - 9 3
10. Turn the ignition switch to OFF.
11. Disconnect connectors of FBC checker and FBC harness
connector from carburetor control unit and body side harness
connectors.
12. Connect body side harness connector to carburetor control
unit.
Check Procedure Chart
3 1 - 9 4
3 1 - 9 5
IDLE SPEED CHECK AND ADJUSTMENT
Checking Conditions:
o Engine coolant temperature is 80 to 95°C (176 to 205°F).
o Engine lubricant temperature is over 80°C (176°F).
o Lights, electric cooling fan and all accessories are off.
o Transaxle is in neutral.
1. Set timing light and tachometer.
2. Start the engine and let it idle.
3. Check the basic ignition timing and adjust if necessary.
Ignition timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . BTDC 5° ± 1°
NOTE
When the basic ignition timing is to be adjusted at a high
altitude, disconnect the vacuum hose (yellow stripe hose)
from the distributor sub-vacuum chamber and temporarily
close the disconnected hose end with an appropriate plug.
4. Run the engine for more than 5 seconds at an engine speed
of 2,000 to 3,000 rpm.
5. Run the engine at idle for 2 minutes.
6. Set the engine speed to the specified valve body adjusting
the idle speed adjusting screw No. 1 (SAS-1).
Curb idle rpm . . . . . . . . . . . . . . . . 700 ± 50 rpm
CAUTION
Do not touch SAS-2. The idle speed adjusting screw
(SAS-2) is the preset screw that determines the relationship
between the throttle valve and free lever, and has
been accurately set at the factory. If this setting is
disturbed, throttle opener adjustment and dash pot
adjustment cannot be done accurately.
3 1 - 9 6
THROTTLE OPENER ADJUSTMENT
For Operation Under Electrical Load
The procedure that follows is to check and adjust the idle speed
control operation of the throttle opener when electric load is
applied.
1.
2.
3.
4.
5.
6.
Make sure curb idle speed is within the specified speed. If
outside the specified limits, readjust the speed to the
nominal specification.
By using the auxiliary lead wire, activate the idle-up control
solenoid valve, apply the intake manifold vacuum to the
idle-up actuator and activate the idle-up actuator.
Open the throttle slightly (to an engine speed of about 2,000
rpm), and then slowly close it.
Adjust the engine speed to the specified speed with the
idle-up adjusting screw.
Throttle opener adjusting rpm (For electrical load)
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 800 ± 50 rpm
After repeating step 3, check the engine speed.
Remove the auxiliary lead wire used in step 2, and reconnect
the idle-up solenoid valve wiring.
For Operation Under Air Conditioner Load
control operation of the throttle opener when air conditioning
load is applied.
1.
2.
3.
4.
5.
Start the engine.
Set the tachometer
Turn on the air conditioner switch.
NOTE
The solenoid valve with open and the intake manifold
vacuum will act on the throttle opener to fully actuate it.
Check the engine speed during this operation.
Throttle opener adjusting rpm (For A/CON). . . . . . . . . . . . . .
900 ± 25 rpm
If the engine speed is out of specification, adjust using the
throttle (for air conditioner) adjusting screw.
3 1 - 9 7
THROTTLE POSITION SENSOR (TPS)
ADJUSTMENT
1. Loosen the accelerator cable enough.
2. Loosen the speed adjusting screw No. 1 (SAS 1) and No. 2
(SAS 2) sufficiently to close the throttle valve completely.
Record the number of turns loosened.
NOTE
Turning the screw counterclockwise closes the valve.
At this time, the fast idle control should have been
released (the lever not resting on the fast idle cam).
3. Connect voltmeter (digital type) between 2 and 3 of TPS
connector pins.
NOTE
Do not disconnect the TPS connector from the chassis
harness.
4. Turn the ignition switch to ON. (Engine will not start.)
5. Measure the TPS output voltage.
Standard value : 250 mV
6. If the output voltage is not correct turn the TPS body to
adjust to specification.
NOTE
Turning the TPS body clockwise increases the output
voltage.
7. Turn the ignition switch to OFF.
8. Tighten SAS 1 and SAS 2 by the same number of turns as
loosened in step (2) to return them to initial state.
9. Adjust free play of the accelerator cable.
10. Start the engine and check that the idle speed as specified.
3 1 - 9 8
DASH POT CHECK AND ADJUSTMENT
o Engine coolant temperature : 80 to 95°C (176 to 205°F).
o Lights, electric cooling fan and accessories : Set to OFF
o Transaxle : Neutral.
1. Start the engine and run at idle.
2. Open the throttle valve for full stroke of the rod until the
free lever contacts SASS.
3. Close the throttle valve until SAS2 contacts the free lever
and check the engine speed at that moment.
4. If engine is not as specified, adjust dash pot setting by
turning SAS3.
5. Release the free lever and verify that the engine returns to
idle speed slowly.
3 1 - 9 9
ELECTRIC CHOKE SYSTEM CHECK AND INSPECTION
CAUTION
All carburetors have a tamper-proof choke. The choke-related
parts are factory adjusted. The choke adjustment is not
required during service, except when major carburetor
overhaul or choke calibration related parts adjustments are
needed by state or local inspections.
1. Check that the alignment marks on the electric choke and
bimetal assembly are lined up.
If not, align the marks.
Misalignment Symptom
Clockwise deviation Better startability but plugs more
likely to be sooty
Counterclockwise Poorer startability and more likely
deviation to stall
2. Check that the engine coolant temperature is below 10°C
(50°F).
3. Start the engine and check operation of the choke valve and
fast idle cam, with hand on the electric choke body.
Electric choke body Gets gradually hotter after engine start
Choke valve Opens as bimetal temperature rises
Fast idle cam Fast idle control is released as engine
coolant temperature rises and fast idle
breaker operates
4. If the electric choke body remains cool even after the engine
is started, check the electric choke.
3 1 - 1 0 0
INSPECTION OF CHOKE BREAKER SYSTEM
o Check conditions of the choke valve according to procedures given in the table below.
Engine coolant
temperature
Lower than
10°C (50°F)
Lower than
10°C (50°F)
Checking condition Normal choke valve operation Probable cause of trouble
Before engine start Closes fully
Start engine and run idle
(fully depress accelerator
pedal and then start)
Opens slowly and slightly
(immediately after starting)
[gap approx. 1.5 mm (0.059
in.)]
Faulty bimetal assembly
of linkage operation
o Clogged delay valve
o Broken diaphragm
(chamber A)
Disconnect vacuum hose
(yellow stripe) from choke
breaker during idling
Stationary o Faulty thermo valve
Step
1
2
3 Lower than
10°C (50°F)
4 Higher than
25°C (77°F)
Connect vacuum hose
(yellow stripe) and run
engine idle
When closed lightly with
finger, stops at larger opening
than step 2 [gap approx. 3 mm
(0.118 in.)]
o Broken diaphragm
(chamber B)
3 1 - 1 0 1
1. After inspection of the choke breaker system, disconnect the
vacuum hose from the choke breaker and make the following
check.
2. With the engine idling, close the choke valve lightly with a
finger until the choke valve stops. Then, measure the choke
valve to choke bore clearance.
Standard value : 1.4-1.6 mm (0.055-0.063 in.)
3. If the clearance is not as specified, stop the engine, remove
the bimetal assembly and adjust the rod end opening for
standard clearance.
NOTE
When removing the bimetal assembly, put a mark on the
Information
4. Reconnect the removed yellow stripe vacuum hose and
measure the choke valve to choke bore clearance as in step
(2).
Standard value : 2.0-3.1 mm (0.114-0.122 in.)
5. If the clearance is out of specification, adjust by the adjusting
screw.
Information
Adjusting screw
turning direction
Clockwise
Counterclockwise
3 1 - 1 0 2
Valve
clearance
Small
Large
Expected result
plug more likely to get
sooty
Poor startability and stall
more likely
Fast Idle And Adjustment
Inspection Conditions
o Lights, electric cooling fan and accessories : Set to OFF.
o Air cleaner : Removed
o Tachometer installed
1. Disconnect the vacuum hose (white stripe) from the choke
opener.
2. Set the lever on the second highest step of fast idle cam.
3. Start the engine and check the fast idle speed.
Standard value:
Vehicles with a manual transaxle 2,800 rpm
Vehicles with an automatic transaxle 2,700 rpm
4. If the fast idle speed is out of specification, adjust with the
fast idle adjusting screw.
Information
Adjusting direction Valve Fast idle speed
Clockwise Large Increases
Counterclockwise Small Decreases
5. Connect the vacuum hose removed in step 1 to the choke
opener and check that the choke opener cancels fast idle.
Choke Heater Inspection
1.
2.
Disconnect the electric choke heater connector and check
continuity of the heater.
Normal state:
Should be conductive [approx. 60 resistance at 20°C
(68°F)]
If the heater is not conductive, replace the electric choke
body (Bimetal assembly).
3 1 - 1 0 4
INSPECTION AND ADJUSTMENT OF
ACCELERATOR CABLE FREE PLAY
1. Run the engine until it reaches the specified idle speed.
2. Confirm that the accelerator inner cable has no slack.
3. If it shows slack, adjust it as follows:
1) Loosen the adjusting nut so that the throttle lever is free.
2) Turn the accelerator adjusting nut to the point where the
throttle lever just starts moving, then back off one turn
and secure the lock nut.
FUEL GAUGE UNIT REPLACEMENT
1. Remove the plug located on the trunk floor.
2. Disconnect the fuel gauge unit connectors.
3. Remove the fuel gauge unit.
4. After installing the fuel gauge unit, confirm that the unit is
grounded.
5. When installing the plug on trunk floor, apply a specified
sealant around the plug mounting surface.
3 1 - 1 0 5
FUEL TANK (FBC)
FUEL TANK
COMPONENTS
REMOVAL
CAUTION
When removing parts such as a fuel tank, rear suspension,
etc., use a garage jack at the front of vehicle (Refer to
GENERAL GROUP), to prevent the vehicle from tilting.
When working on fuel tank, be sure the ignition is switched
off. Avoid any source of heat or sparks, such as lights,
smoking, etc.
Prior to working on the fuel tank or lines, remove the fuel filler
cap to release any pressure in the tank.
3 1 - 1 0 6
FUEL TANK (FBC)
1. Remove the drain plug to drain the fuel tank.
NOTE
Do not disconnect the in-tank filter except when the filter
is replaced.
2. Loosen the fuel hose (main and return) clamps and
disconnect the fuel hoses.
3. Disconnect the filler hose and breather hose from the filler
neck.
4. After removing the protector (if so equipped) and fuel tank
mounting band, drop the fuel tank slightly and disconnect the
fuel gauge unit harness.
5. Remove the fuel tank.
6. Remove the fuel gauge unit as necessary.
INSPECTION
Check the following and replace defective parts as necessary.
1.
2.
3.
4.
Leaky fuel tank
If leaks are evident, clean the fuel tank interior and exterior
and check for rust formation, corrosion, damage and cracks.
A badly corroded or damaged fuel tank should be replaced.
Clogged, cracked, damaged or rusty fuel pipe.
NOTE
When cleaning the fuel tank, avoid using cleaners which
may affect the terne-coated inside surface of the tank.
Use trichloroethylene, neutral emulsion type cleaner, etc.
Peeled or damaged pad on top of tank
If the pad is to be rebonded, clean the top surface of the tank,
apply adhesive to the entire pad bonding area, and bond the
pad securely.
Test two-way valve for proper operation.
outlet. If the air passes through after slight resistance, then
the valve is good.
INSTALLATION
1. Confirm that the pad is fully bonded to the fuel tank, then
install the fuel tank by tightening the tank band until its end
touches the floor.
2. Connect all hoses and tubes correctly.
CAUTION
When installing the hoses. Be sure not to mix up the
hoses.
Improper installation can cause fuel leakage.
3. Slowly slide the in-tank filter over the in-tank outlet pipe and
tighten the drain plug to the specified torque.
3 1 - 1 0 7
FUEL LINE (FBC)
FUEL LINE
COMPONENTS
3 1 - 1 0 8
FUEL LINE (FBC)
REMOVAL AND INSTALLATION
1. Pipes should be secured firmly with clips and clamps to
prevent looseness.
2. With the hoses and pipes are installed, make sure that they
are not distorted or loose.
3. Route the hoses and tubes correctly and fit their ends
securely.
4. Install clips and clamps in correct direction to make sure that
they do not interfere with neighboring objects.
INSPECTION
1. Check the hoses and pipes for cracks, bend, deformation,
deterioration or clogging.
2. Check the fuel filter for clogging or damage.
3. Check the canister for clogging.
4. Check the overfill limiter (two-way valve) and the fuel check
valve for malfunction.
Overfill Limiter Simple Test
A simple way of inspecting the overfill limiter is to remove, and
then air is lightly blown into either the inlet or outlet by mouth.
If the air passes after a slight resistance, overfill limiter is in good
condition.
5. Check purge control valve as follows:
1) Make sure that the engine coolant is between 80 and
95°C (176 and 205°F).
2) Disconnect the purge control hose from the carburetor
and blow into the purge hose. The valve should not allow
airflow. Then start the engine and increase the engine
speed to 1,500 to 2,000 rpm and blow into the purge
hose. If the valve is not open, check for clogged or broken
vacuum hose, or malfunctioning thermo valve.
FUEL FILTER REPLACEMENT
1. Remove the fuel tank cap to release the fuel tank pressure.
2. Disconnect the fuel hoses from the fuel filter, and then
remove the fuel filter.
CAUTION
1) Whenever the fuel filter is replaced, always inspect the
flex hoses for deterioration and cracking, and replace
as necessary.
2) Ensure the installation is secure and the fuel line
routing is in the original configuration.
3 1 - 1 0 9
FUEL PUMP (FBC)
FUEL PUMP
REMOVAL
1. Disconnect the battery ground cable.
2. Disconnect the fuel inlet, outlet and return hoses at fuel
pump.
3. Remove the two fuel pump mounting bolts, and remove the
fuel pump and push rod.
4. Remove the fuel pump gaskets and insulator.
INSPECTION
Checking Leakage
If there is oil or fuel leaks from breather hole, oil seal or
diaphragm in fuel pump is defective. Replace fuel pump
assembly.
3 1 - 1 1 0
FUEL PUMP (FBC)
Inlet Valve Test
To test the inlet valve, connect a vacuum gauge on the inlet
fitting while the line is disconnected.
1. Start engine or turn over with starting motor.
2. There should be a noticeable vacuum present.
3. If blow-back is present, inlet valve is not seating properly and
a new pump should be installed.
4. If fuel pump does not perform to above test requirements,
a new fuel pump should be installed.
Pressure Test
1. Disconnect the hose at the carburetor and connect a fuel
pressure gauge.
2. Disconnect the fuel return hose from the pump and plug the
fuel pump return pipe as shown in illustration.
3. Check pressure while the engine is idling. Replace the pump,
if required.
Standard pressure (at camshaft rpm 2,500). . . . . . . . . . . . . .
19-25 kPa (0.19-0.26 kg/cm2, 2.76-3.63 psi)
Fuel Flow Rate Test (Volume)
1. Disconnect the carburetor fuel hose and insert the end into
a beaker.
2. Disconnect the fuel return hose from the fuel pump and plug
the fuel pump return pipe.
3. Start the engine and measure the amount of fuel pumped
within one minute.
Volume (at camshaft rpm 2,500). . . . . . . . . . . . . . . . . . . . . . . .
0.6 lit/min. (0.85 U.S.qt, 0.72 Imp.qt.)
INSTALLATION
1. Turn crankshaft to place piston in No. 1 cylinder at top dead
center on compression stroke.
NOTE
This is to minimize cam lift for ease of installation.
2. Insert the push rod into the cylinder head.
3. Install the new gasket and insulator, and then install the fuel
pump. Tighten the bolts firmly.
4. Reconnect the fuel hoses to the fuel pump nipples and install
the hose clamps.
5. Start and run the engine. Check for fuel or oil leak.
3 1 - 1 1 1
FUEL PUMP (FBC)
FUEL PUMP TROUBLESHOOTING
3 1 - 1 1 2
CARBURETOR
CARBURETOR
CONSTRUCTION
3 1 - 1 1 3
CARBURETOR
COMPONENTS
1. Throttle return spring
2. Damper spring
3. Throttle return spring bracket
4. Throttle opener/dash pot
5. Hose
6. Vacuum delay valve
7. Hose
8. Screw
9. Pin
10. Float
11. Needle valve
12. Needle valve seat
13. O-ring
14. Packing
15. Retainer
16. Feedback solenoid valve (FBSV)
17. O-ring
18. O-ring
19. Retainer
20. Slow cut solenoid valve (SCSV)
21. O-ring
22. O-ring
23. Plate
24. Bimetal assembly
25. Packing
26. Connector
27. Cover
28. Diaphragm
29. Spring seat
30. Spring
31. Housing
32. Spring
33. Diaphragm
34. Valve
35. Mixture control valve (MCV) assembly
36. Gasket
37. Cover
38. Spring
39. Diaphragm
40. Body
41. Spring
42. Diaphragm
43. Bracket
44. Cover
45. Spring
46. Diaphragm
47. Body
48. Main air jet (primary)
49. Pilot jet (primary)
50. Pilot jet (secondary)
51. Float chamber cover
3 1 - 1 1 4
CARBURETOR
COMPONENTS
52. Bracket
53. Float chamber cover gasket
54. Steel ball
55. Weight
56. Ball
57. Plug
58. O-ring
59. Ball
60. Screw
61. Gasket
62. Main jet (primary)
63. Main jet (secondary)
64. Cover
65. Spring
66. Diaphragm
67. Enrichment jet valve 82. Throttle lever
68. Enrichment jet 83. Cam follower
69. Spring 84. Fast idle adjusting screw
70. Ball 85. Free lever
71. Pump cover assembly 86. Abutment plate
72. Diaphragm 87. idle speed adjusting screw (SAS-2)
73. Spring 88. Spring
74. Pump body 89. Secondary lever
75. Gasket 90. Idle speed adjusting screw (SAS-1)
76. Mixing body 91. Plug
77. Vacuum hose 92. Mixture adjusting screw (MAS)
78. Depression chamber 93. Throttle body
79. Throttle position sensor (TPS)
80. Lever
94. Idle speed adjusting screw (SAS-3)
81. Adjusting screw
3 1 - 1 1 5
CARBURETOR
REMOVAL
1. Disconnect battery ground cable.
2. Remove air cleaner.
3. Disconnect the throttle cable from carburetor.
4. Disconnect the vacuum hoses from carburetor.
5. Disconnect connectors for solenoid valves and TPS.
6. Place a container under fuel fittings of carburetor to catch
any fuel that may be trapped in fuel line and disconnect the
fuel hoses from the carburetor inlet nipples.
7. Remove carburetor mounting bolts and carefully remove the
carburetor from engine. Hold carburetor level to avoid spilling
fuel from fuel bowl.
DISASSEMBLY
1. Remove the throttle return spring from the throttle lever and
throttle return spring bracket unscrewing two screws.
2. Remove the dash pot rod from the free lever.
3. Unscrewing two screws, remove the bracket with two
connectors and off the connectors.
3 1 - 1 1 6
CARBURETOR
4. Pull the hose with delay valve off the nipple of choke breaker.
5. Remove the float chamber cover screws “B” to remove the
throttle body.
6. Remove the screws “A” to remove the float chamber cover
from main body.
7. To remove the float chamber cover assembly, insert a screw
driver blade between the enrichment cover and the float
chamber cover as illustrated and lightly pry and lift up slowly.
CAUTION
Do not apply excessive force.
8. Remove the pin and then remove the float and needle valve.
CAUTION
1) Do not let the float drop or supply collapsing load.
2) Use care not to damage the end of the needle valve.
CARBURETOR
9. Using flat blade screwdrivers, pry up the needle valve seat
at both edges to remove.
CAUTION
Use care not to damage the float chamber cover when
pushing up the needle valve seat.
10. Remove the retainer of the feedback solenoid valve (FBSV).
11. Using a screwdriver or other tool with a thin flat end, push
the stopper portion and remove the two terminals from
behind the connector.
NOTE
Unless the terminals are removed from the connector, the
feedback solenoid valve cannot be removed from the float
chamber cover.
12. Pull out the FBSV from the float chamber cover.
3 1 - 1 1 8
CARBURETOR
13. Remove the retainer and pull out the slow cut solenoid
valve.
14.
15.
16.
the stopper section and remove the two terminals from
To remove the bimetal assembly, grind away the head of the
two rivets of the bimetal assembly using a hand grinder or
other tool and remove the screw.
Remove the plate and the bimetal assembly.
17. Using a screwdriver or other tool with a thin flat end, push
the stopper section and remove the terminal from behind the
connector.
CARBURETOR
18. Remove the three screws attaching the Bowl Vent Valve
(BVV) cover to the float chamber.
19. Remove the plastic vent hosing, housing cover and the two
springs.
20. Remove the bowl vent valve diaphragm shaft.
CAUTION
Carefully pull the diaphragm out of the float chamber
cover so that rubber vent seal slides off the diaphragm
shaft.
NOTE
Be careful not to misplace the two small springs
positioned on either side of the plastic vent housing.
21. Unscrewing the three screws attaching the Mixture Control
Valve (MCV) assembly, remove the MCV assembly.
3 1 - 1 2 0
22. Remove the three screws attaching the choke vacuum
breaker cover, then remove the choke break cover, springs,
diaphragm and linkage assembly.
CARBURETOR
NOTE
Of the two diaphragm springs, the outer one is longer.
23. Remove the choke bracket.
24. Unscrewing the four screws, remove the choke opener.
3 1 - 1 2 1
CARBURETOR
25. Remove the pilot jets and main air jet.
NOTE
When removing the jets, use a screwdriver that is an exact
fit for their slot and work carefully to prevent damage.
26. Carefully lift and swing up the roll-over device weight from
the bottom of the float chamber, then use a magnet to
remove the roll-over steel ball.
NOTE
Remove the float chamber gasket and pour the remaining
fuel contained in the float chamber into a container.
27. Remove the accelerator pump outlet check ball and weight.
NOTE
Invert the chamber to remove the accelerator pump outlet
check ball and weight located at the gasket surface.
28. Separate the float chamber from the throttle body.
3 1 - 1 2 2
CARBURETOR
29. Remove the main jets.
NOTE
When removing the main jets, use a screwdriver that is
an exact fit and work carefully to prevent damage.
30.
31.
32.
Remove the three screws attaching the enrichment valve
cover to the enrichment housing on the float chamber.
Remove the cover, spring and diaphragm.
Unscrew the enrichment valve from the housing.
33. Using a screwdriver, loosen the enrichment jet and take out
the spring and ball from the enrichment jet valve.
CAUTION
The valve has many small parts. Do not lose them.
34. Remove the four screws (thread sealant supplied) attaching
the accelerator pump cover to the float chamber.
35. Remove the accelerator pump cover, diaphragm, spring,
pump body and gaskets.
3 1 - 1 2 3
CARBURETOR
NOTE
When reinstalling, apply thread sealant to the screws and
be sure the pump body, gasket and cover are properly
positioned.
36. Remove the E-clip and outside washer on the secondary
throttle shaft and slide the diaphragm spring link off the
throttle shaft.
37. Remove the two screws attaching the diaphragm bracket to
throttle body and remove the secondary throttle diaphragm.
38.
39.
40.
41.
Using a 10 mm wrench, remove the nut attaching the
accelerator pump lever to the throttle shaft.
With the impact driver, remove two screws attaching the
throttle position sensor to the throttle body.
Remove the E-clip holding the throttle position sensor onto
the throttle shaft.
For removal of plug, clamp carburetor in a vice and drill a
2mm (5/64 in.) pilot hole in the casting surrounding the idle
mixture adjusting screw (MAS) then redrill the hole to 3mm
(1/8 in.)
Insert a blunt punch into the hole and drive out plug.
3 1 - 1 2 4
REASSEMBLY
Perform reassembly in reverse of disassembly procedure, paying
special attention to the following items:
1. Clean all parts before assembly.
2. Check to be sure that no clogging is in the air passages and
fuel passages.
3. Check for smooth operation of throttle and choke linkage. If
the operation is not smooth, clean them up. Then may be
replaced at this time to ensure proper carburetor performance.
4. When replacing a main or a pilot jet, the old jet and the new
jet must be of the same size, because the jet is selected after
exact flow measurement by factory.
5. Do not reuse the O-rings and gasket. Replace them with new
ones at every reassembly.
Service Point of Reassembly
1. Make sure that correct jets are installed at correct positions.
Note the size symbol stamped on each jet for identification.
Identification mark
Main jet
Primary . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . # 83.8
Secondary . . . . . . . . . . . . . . . .. . . . . . . . . . . . . . . . # 145
Pilot jet
Primary . . . . . . . . . . . . . . . . . . . . . . .. . . . . ... # 46.3
Secondary. . . . . . . .. . . . . . . . . . . . . . . . . . . . . . . # 70
2. Bimetal assembly
1) Fit the bimetal end over the choke valve lever.
CARBURETOR
2) Install the plate and temporarily tighten the screw.
3) Align the mating marks.
4) Set the rivet as illustrated.
7) Install terminal to the connector at correct position.
5) While keeping the mating marks aligned, install the
bimetal assembly with a hand riveter or similar tool.
6) Tighten the screw.
3 1 - 1 2 6
CARBURETOR
INSPECTION
General Description
Check the following and repair or replace parts if necessary.
1.
2.
3.
4.
5.
6.
7.
Check the fuel paths (jets) and air paths (jets or orifices) for
clogging. If clogged, wash thoroughly with cleaning solvent
or detergent and blow by compressed air. Do not use metal
wire or other metal pieces.
Check the diaphragms for damage and cracks.
Check that the needle valve operates lightly. If the valve is
hard to slide or is binding, repair or replace. If there is
overflow, poor valve to seat contact is suspected. Check
thoroughly.
Check the fuel inlet filter (located above the needle valve)
for clogging and damage.
Check the float operation. Check the float and lever for
deformation and damage and replace if necessary.
Check operation of the throttle valve, chock valve and link.
If they do not operate lightly, wash well and apply engine
oil sparingly to their shaft.
Check the float chamber cover and main body for damage
and cracks.
1. Apply battery voltage directly to the slow cut solenoid valve
terminals.
2. Check that the valve operates with a click.
3. Using a circuit tester, check that there is no continuity
between the solenoid valve body and terminals.
CARBURETOR
4. Measure resistance between the terminals.
SCSV coil resistance . . . . . . . . . . 48-60 fl [at 20°C (68°F)]
1. Apply battery voltage directly to the feedback solenoid valve
terminals.
2. Check that the valve. operates with a click.
3. Check that the jet is free from clogging.
4. Using a circuit tester, check that there is not continuity
3 1 - 1 2 8
CARBURETOR
5. Measure resistance between the terminals.
FBSV coil resistance . . . . . . . . . . . 54-66 0 [at 20°C (68°F)]
Bimetal Assembly
Using a circuit tester, measure resistance between the terminal
and body.
Bimetal resistance . . . . . . . . . . . . . Approx. 6 0 [at 20°C (68°F)l
Dash Pot
Check that the dash pot operates normally. Resistance must be
felt when the dash pot is pulled. When the rod is released it
must return quickly to the original position. If no resistance is
felt when it is pulled, the diaphragm or the check valve is broken.
If the rod returns slowly, the check valve is binding. In either
case, replace the dash pot.
Secondary Throttle Chamber (Depression Chamber)
Check the secondary throttle chamber diaphragm for damage.
First, push up fully and closing tightly the nipple with a finger,
release the rod. The diaphragm is intact if the rod does not return
to the initial position while the nipple is held closed with a finger.
If the rod returns, the diaphragm is broken. Replace the
secondary throttle chamber.
CARBURETOR
1. Measure resistance between terminals 1 and 2 of the
throttle position sensor.
TPS resistance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.5-6.5 Kn
2. Check the body for crack and damage.
Fast Idle Opening
1. Set the lever on the mark (scribed line) of fast idle cam.
2. Measure the primary valve to throttle bore clearance.
Fast opening (drill diameter)
M/T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.93 mm (0.037 in.)
A/T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.02 mm (0.040 in.)
3. If the clearance is out of specification, adjust using the fast
idle adjusting screw for the standard value.
Adjusting screw Valve opening
Clockwise Larger
Counterclockwise Smaller
Fast idle rpm
Increases
Decreases
3 1 - 1 3 0
CARBURETOR
Unloader Opening
1. Lightly press the choke valve with a finger to fully close it.
2. In this state, fully open the throttle valve and measure the
choke valve to choke bore clearance.
Standard value. . . . . . . . . 1.9-2.1 mm (0.075-0.083 in.)
3. If the clearance is out of specification, bend the throttle lever
at illustrated portion to adjust the clearance to the standard
value.
Choke Breaker
CAUTION
Check and adjust with the bimetal assembly removed.
2. Push the choke breaker rod toward the diaphragm and
measure the choke valve to choke bore clearance.
Standard value
1st stage . . . . . . 1.4-1.6 mm (0.055-0.063 in.)
2nd stage . . . . . . . 2.9-3.1 mm (0.114-0.122 in.)
3. If the clearance is out of specification, adjust by bending the
throttle lever at illustrated portion.
3 1 - 1 3 1
CARBURETOR
INSTALLATION
1.
2.
3.
4.
5.
6.
7.
8.
9.
Inspect the mating surfaces of carburetor and intake
manifold. Be sure both surfaces are clean and free of nicks,
burrs or other damage.
Place a new carburetor gasket on intake manifold surface.
Carefully place the carburetor on intake manifold.
Install carburetor mounting bolts and tighten alternately, a
little at time, to compress carburetor gasket evenly. The bolts
must be drawn down tightly to prevent vacuum leakage
between the carburetor and intake manifold.
Connect the throttle cable, vacuum hoses and fuel hoses.
Check carefully for worn of loose vacuum hose connections.
Check to be sure the choke valve opens and closes fully
when operated.
Check to see that full throttle travel is obtained.
Install air cleaner. The air cleaner should be cleaned or
10. Connect battery cable.
CAUTION
The practice of priming an engine by pouring gasoline into
the carburetor air horn for starting after servicing the fuel
system should be strictly avoided. Cranking the engine and
priming by depressing the accelerator pedal several times
should be adequate.
11. Set carburetor idle speed and mixture adjustment.
3 1 - 1 3 2
ENGINE CONTROL (FBC)
ENGINE CONTROL
REMOVAL
Accelerator Cable
1. Loosen the accelerator cable adjusting nut.
2. Disconnect the accelerator cable from either the throttle
lever.
3. Disconnect the accelerator cable from the accelerator arm.
4. Disconnect the accelerator cable guide from the fire wall,
and then remove the accelerator cable.
Accelerator Pedal
1. Loosen the accelerator cable adjusting nut, and disconnect
the accelerator cable from the accelerator arm and remove
the accelerator pedal.
2. Remove the return spring from the accelerator arm.
3. Remove the cotter pin from the accelerator arm shaft, and
then remove the accelerator arm from the accelerator arm
bracket.
INSPECTION
1. Check the inner and outer cables for damage.
3. Check the accelerator arm for bending.
5. Check for connection of accelerator cable to end fitting.
INSTALLATION
1. Apply the specified multipurpose grease around the each
moving point of the pedal.
Recommended multipurpose grease . . . . . . . . . . . . . . . . . . . . .
grade #2 or equivalent
3 1 - 1 3 4
2.
3.
4.
5.
To prevent entry of exhaust fumes, apply semi-drying type
sealant to the bolt mounting hole, and then tighten the
Make sure that the accelerator cable is laid without sharp
bends.
Inspect the play of accelerator cable.
Install parts and torque to specification.
3 1 - 1 3 5
What do you mean?
