Fuel & Fuel Systems
L
Bình luận: 0Lượt xem: 2,640
localhost
Link download http://www.mediafire.com/?gtf45glnnwt Fuel & Fuel Systems About Gasoline................................................................................................ 2 Octane Rating ........................................................................................................................................................2 Detonation..............................................................................................................................................................2 Pre-Ignition.............................................................................................................................................................2 Motor Octane Rating..............................................................................................................................................2 Research Octane Number .....................................................................................................................................3 (R+M)/2 Method .....................................................................................................................................................3 Specific Gravity ......................................................................................................................................................3 Reid Vapor Pressure..............................................................................................................................................3 Aviation Gasoline ...................................................................................................................................................3 Alcohol ........................................................................................................... 4 Types of Alcohol.....................................................................................................................................................4 Air-to-Alcohol Ratio ................................................................................................................................................4 Cost........................................................................................................................................................................4 Race Fuel Specifications................................................................................... 5 Racing Gasoline.....................................................................................................................................................5 Fuel System Plumbing Recommendations............................................................ 6 Carbureted Gasoline Engines................................................................................................................................6 Fuel Injector Selection...................................................................................... 7 Brake Specific Fuel Consumption (BSFC)..............................................................................................................7 Injector Sizing.........................................................................................................................................................7 Fuel Pressure.........................................................................................................................................................7 Injector Flow Rates At Various Pressures ..............................................................................................................7 Horsepower Support ..............................................................................................................................................7 Estimated Injector Size by Airflow..........................................................................................................................8 Impedance .............................................................................................................................................................8
