Ford/Mazda IDS v73 05.2011
hyundai
Bình luận: 0Lượt xem: 1,718
hyundai
3.82 GB
The Vehicle Commnication Module (VCM) is a high performance, ruggedized, vehicle serial communications gateway. This device provides multiple vehicle serial communication interfaces to meet the requirements of all Ford Motor Company vehicles. The VCM unit is housed in a magnesium enclosure with a tough, protective, plastic cover for the PCMCIA expansion slot which can, for example, be used for wireless LAN cards or memory expansion. The VCM device contains five LED status indicators to provide the user with a visual mode of internal VCM, vehicle, and host device (e.g. NGS Classic’s T-Handle, PC, Pocket PC/PDS, and Laptop/IDS) operation .
The VCM also has detachable cables for connection to industry standard high-speed host interfaces as well as to the vehicle under test. The VCM 2007.7 DVD includes both IDS (Integrated Diagnostic Software) and PDS (Portable Diagnostic Software) tools .
Product Contents
• VCM
• PDS
• Cables
• Case
Application Overview:
Integrated Diagnostic Software (IDS) is the next generation diagnostic tool. IDS integrates WDS software modified to run on an off-the-shelf laptop with the Vehicle Communication Module (VCM) currently used in NGS+ and PDS, and a new Vehicle Measurement Module (VMM) .
Vehicle Diagnostic Connectors:
The VCM 16-pin DLC cable is used to connect the VCM to the vehicle. The VCM and VMM connect to the laptop through the Ethernet-USB Adapter Cable (H406/H416) .
Links:
http://en.oto-hui.com/a2386/ford/mazda-ids-v73-05-2011.html
