[ECAE] 22.12.2011 Engine Cranks But Wont Start
Duyleauto
Bình luận: 0Lượt xem: 891
Duyleauto
If you want to start the engine to operate. You need three things to happen inside the egine. There are compression, ignition and air fuel mixture. If it is without any thing of those components the engien will not operation. But on one day you when you get up early and start the engine to go to your office. The engine can not operate and you don't know what to to.
And now you don't worry about that after you read this topic. Below we have written about the reason which it can cause the engine will not start. Please read and if you have problems don't hesitate to contact us.
Composed and written by buctuong_lua16
http://data.oto-hui.com/j8vn6ggbkqx7.html
