Download Inventor 2010 Tutorials
L
Bình luận: 0Lượt xem: 4,403
localhost
Getting Started Guides (pdf)
Autodesk Inventor 2010 Getting Started Guide
Autodesk Inventor 2010 Routed Systems Getting Started Guide
Autodesk Inventor 2010 Simulation Getting Started Guide
Tutorials (chm)
Download Autodesk Inventor 2010 Tutorials
Download Autodesk Inventor Routed System 2010 Tutorials
Download Autodesk Inventor Simulation 2010 Tutorial
Overview
Autodesk Inventor 2010 comes with several new features to compete with Pro/Engineer and SolidWorks. Simulation, Routed Systems, Tooling and Mold Design has several new functionalities that will definitely test other high end 3D software. A trial download of Autodesk Inventor 2010 for US and Canadian users with just filling a simple form.
What’s New
1. Plastic Part Design
Autodesk Inventor 2010 design software also offers plastic parts designers maximum flexibility by combining native Inventor geometry with exterior surface models designed using the Autodesk® Alias software family of products or other Industrial design applications. In addition, Inventor software helps to automate key aspects of the design of injection molds for plastic parts.
2. Layout Design
Getting the initial design concept right is the key to a successful project. Move your initial design studies from paper by using the new sketch block capabilities in Autodesk Inventor 2010 to develop initial concept sketches and kinematic models.
3. Simulation
The enhanced simulation environment provides improved support for motion simulation and static and modal finite element analysis at both the part and assembly level.
4. BIM Interoperability
The enhanced AEC Exchange tool in Autodesk Inventor 2010 simplifies the exchange of data for use in building design. AEC Exchange allows users to publish data files with simplified 3D representations and intelligent connection points for use in building models created using Autodesk® Revit® MEP and Autodesk® Revit® Architecture software.
5. Usability and Productivity
Autodesk Inventor 2010 enhances usability and productivity with the introduction of a modern task-based user interface and a large group of user-requested enhancements.
Reference
