Link download
http://www.mediafire.com/?nqleonjz3zj
Cooling Systems
Cooling System Modifications............................................................................ 2
Thermal Efficiency..................................................................................................................................................2
Cooling System Goals............................................................................................................................................2
Nucleate Cooling Phase ........................................................................................................................................2
Types of Coolant ....................................................................................................................................................2
System Pressure....................................................................................................................................................3
Stock Cooling Systems ..........................................................................................................................................3
Mechanical Water Pumps ......................................................................................................................................3
Electric Water Pumps.............................................................................................................................................3
Coolant Flow ..........................................................................................................................................................4
Basic Flow Modifications........................................................................................................................................4
Radical Modifications .............................................................................................................................................4
Reverse Flow Systems ..........................................................................................................................................4
Cooling Fans ................................................................................................... 5
Stock Clutch Fans..................................................................................................................................................5
Flex Fans ...............................................................................................................................................................5
Electric Fans ..........................................................................................................................................................5
Fan Shrouds...........................................................................................................................................................6
Radiators ....................................................................................................... 7
Copper Brass vs. Aluminum ..................................................................................................................................7
Cross Flow vs. Down Flow.....................................................................................................................................7
Single vs. Dual Pass ..............................................................................................................................................7
Cooling Systems
