Cho em hỏi đây là bộ phận gì trên ô tô?
SinhVienNTU
Bình luận: 3Lượt xem: 1,494
caibang9x
Hydraulic tappet or hydraulic valve lifter n. small component in the valve train, usually between camshaft and valve, or rocker arm and valve, which maintains zero valve clearance by automatically expanding when a clearance develops; uses the hydraulic principle that liquids cannot be compressed and consists basically of a small check valve, piston and cylinder: Con đội thủy lực (động cơ)
- Vào xem ảnh đây bác nhé: https://oto-hui.com/threads/con-doi-thuy-luc-hydraulic-lifter-trong-he-thon-phan-kho-khi.97515/
