pham.thang1912
A/C = Air Conditioner
A/T = Automatic Transaxle
ABS = Anti-Lock Brake System
ACIS = Acoustic Control Induction System
CAN = Controller Area Network
CPU = Central Processing Unit
DLC3 = Data Link Connector 3
E.F.I. = Electronic Fuel Injection
EBD = Electronic Brake Force Distribution
EC = Electrochromic
ECM = Engine Control Module
ECT = Electronic Control Transmission
ECU = Electronic Control Unit
EPS = Electric Motor Power Steering
FL = Fusible Link
HID = High Intensity Discharge
IC = Integrated Circui
J/B = Junction Block
LED = Light Emitting Diode
LH = Left-Hand
R/B = Relay Block
RH = Right-Hand
SRS = Supplemental Restraint System
VSV = Vacuum Switching Valve
VVT = Variable Valve Timing
w/ = With
w/o = Without
EC = Electrochromic
FL = Fusible Link
LH = Left-Hand
R/B = Relay Block
RH = Right-Hand
w/ = With
w/o = Without
